Download and Setup
- Download Embedded Studio >= v3.10e
- Download and install the J-Link Software and Documentation Pack >= v6.10g
- Download and unzip Nordic's nRF5 SDK >= v12.0.1
Note: It is recommended, but not necessary, to use the most recent releases of the above software.
Importing a Keil uVision project
Note: From nRF5 SDK v14.1, Segger Embedded studio projects are officially supported. If using v14.1 or newer, please use the native SES-projects instead of the "import" function.
- Open
SEGGER Embedded Studio 3.10e - Select
Tools -> Package Manager...and install theCMSIS-CORE Support Package
- Select
File -> Import IAR EWARM / Keil MDK Project... - Navigate to your local nRF5 SDK and in
NRF5_SDK/examples/ble_peripheral/ble_app_beacon/selectpca10040/s132/arm5_no_packs/ble_app_beacon_pca10040_s132.uvprojx - The
Import Build Configurationwindow will pop-up. Make sure you select to use Embedded Studio'sInternal Toolchain (GCC/Clang)for now...
Nuances
If you've used Keil uVision with Nordic's SDK before, you might remember that each example BLE project contains a dummy project configuration for easy flashing of the SoftDevice. We don't need this in Embedded Studio and it can cause confusion so let's delete it.
- Select
Project -> Build Configurations...and underPublic Configurationsselectflash_s132_nrf52_3.0.0_softdeviceand delete it by clicking the-symbol in the upper right-hand corner of the pop-up window.
Your build configurations should look like this now:
And your project explorer:
Adding nRF5 MDK Files
Keil uVision uses Device packs for Startup/System Setup. This pack contains the nRF5 startup assembly files arm_startup_nrf52.s and the system setup files system_nrf52.c along with some header files. We will need to manually add these files to our Embedded Studio project.
- Download ses_nrf51_startup.s and ses_nrf52_startup.s and save them into
NRF5_SDK/components/toolchain/embedded_studio/(create the folder) - Remove
Cortex_M_Startup.sfrom theInternal Filesfolder in theProject Explorer - Right click the
Internal Filesfolder and selectAdd Existing File... - In
NRF5_SDK/components/toolchain/selectsystem_nrf52.c - Do the same for
NRF5_SDK/components/toolchain/embedded_studio/ses_nrf52_startup.s
Your project explorer should look like this now:
- Select
Project -> Edit Options...and then select thePreprocessortab - Add
../../../../../../components/deviceto theUser Include Directoriesfield to include the device header files in our Embedded Studio project
Your user include directories should look like this now:
Peer Manager/Flash Data Storage
Most of the examples in the SDK use Peer Manager. Peer Manager uses Flash Data Storage and Flash Storage. To indicate where information from Peer Manager (e.g bonding information) should be store page tags in flash (section variables) is used. These page tags need to be written to flash. To do so, flash_placement.xml and thumb_crt0.s have to be added and modified. Thanks to @RK and @Håkon Alseth in this post.
Flash_placement.xml can be located in the project folder, for example: ..\nRF5_SDK_xxx\examples\ble_peripheral\ble_app_gls\pca10040\s132\arm5_no_packs
You have to generate flash_placement.xml using text editor, notepad for example. After that you can import it by right click on the project name and choose "Import Section placement"
For SDK v14 please use these updated files:
flash_placement.xml should then look like the following (SDK 12):
<!DOCTYPE Linker_Placement_File>
<Root name="Flash Section Placement">
<MemorySegment name="$(FLASH_NAME:FLASH)">
<ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START:)" />
<ProgramSection alignment="4" load="Yes" name=".init" />
<ProgramSection alignment="4" load="Yes" name=".init_rodata" />
<ProgramSection alignment="4" load="Yes" name=".text" />
<ProgramSection alignment="4" load="Yes" name=".dtors" />
<ProgramSection alignment="4" load="Yes" name=".ctors" />
<ProgramSection alignment="4" load="Yes" name=".rodata" />
<ProgramSection alignment="4" load="Yes" name=".ARM.exidx" address_symbol="__exidx_start" end_symbol="__exidx_end" />
<ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" />
<ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" />
<ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" />
<ProgramSection alignment="4" keep="Yes" load="Yes" runin=".fs_data_run" name=".fs_data" />
</MemorySegment>
<MemorySegment name="$(RAM_NAME:RAM);SRAM">
<ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START:$(SRAM_START:))" />
<ProgramSection alignment="4" load="No" name=".fast_run" />
<ProgramSection alignment="4" load="No" name=".data_run" />
<ProgramSection alignment="4" load="No" name=".tdata_run" />
<ProgramSection alignment="4" load="No" keep="Yes" name=".fs_data_run" address_symbol="__start_fs_data" end_symbol="__stop_fs_data" />
<ProgramSection alignment="4" load="No" name=".bss" />
<ProgramSection alignment="4" load="No" name=".tbss" />
<ProgramSection alignment="4" load="No" name=".non_init" />
<ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
<ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack" />
<ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
</MemorySegment>
<MemorySegment name="$(FLASH2_NAME:FLASH2)">
<ProgramSection alignment="4" load="Yes" name=".text2" />
<ProgramSection alignment="4" load="Yes" name=".rodata2" />
<ProgramSection alignment="4" load="Yes" runin=".data2_run" name=".data2" />
</MemorySegment>
<MemorySegment name="$(RAM2_NAME:RAM2)">
<ProgramSection alignment="4" load="No" name=".data2_run" />
<ProgramSection alignment="4" load="No" name=".bss2" />
</MemorySegment>
</Root>
Thumb_crt0.s is located in the Segger Embedded studio install folder: ..\SEGGER\SEGGER Embedded Studio <v. xx>\source
In thumb_crt0.s, fs_data should be added, it can be added after tdata (thanks to @RK):
ldr r2, =__tdata_end__
bl memory_copy
# ADD HERE ...
ldr r0, =__fs_data_load_start__
ldr r1, =__fs_data_start__
ldr r2, =__fs_data_end__
bl memory_copy
# TO HERE ...
Building
Our project should build successfully now:
- Build the project by selecting
Build -> Build ble_app_beacon_pca10040_s132or by simply hittingF7
Notice that the compiled binary is placed at the beginning of FLASH and SRAM. This project requires a SoftDevice so let's reserve the correct amount of room for it.
- Select
Project -> Edit Options...and then select theLinkertab - Paste the following into the
Section Placement Macrosfield (SDKv12):
FLASH_START=0x1F000
SRAM_START=0x20002000
Your Project Options should look like this now:
- Re-build the project by selecting
Build -> Rebuild ble_app_beacon_pca10040_s132or by simply hittingAlt + F7
Now you should see that space has been reserved in FLASH and SRAM for the SoftDevice:
Fine-Tuning
- Select
Project -> Edit Options...and then select thePreprocessortab - Add the definition
NO_VTOR_CONFIGto thePreprocessor Definitionsfield (this tells Embedded Studio to expect a SoftDevice to be present and that it will forward exceptions/interrupts to the application)
Your Preprocessor Definitions should look like this now:
Flashing the SoftDevice with our application
- Select
Project -> Edit Options...and then select theLoadertab - Add the absolute path to the SoftDevice
NRF5_SDK/components/softdevice/s132/hex/s132_nrf52_3.0.0_softdevice.hexto theAdditional Load File[0]field
Your Loader options should look like this now:
Running
- Connect your nRF5 Development Kit to your computer and turn it on
- Run the application by selecting
Debug -> Build and Runor hittingCtrl + F5
Your Output log should look like this now:
The application should be running on your nRF5 DK and LED1 should be blinking. You should be able to scan for and find the beacon using nRF Connect.
Debugging
- Select
Debug -> Goor simply hitF5
You should see that you have entered the debugging interface now:
Notice that our application has ran until the first line in main() and is halted. You should experiment with debugging in Embedded Studio. It has all the debugging features you would expect from a professional IDE and more (makes sense as SEGGER makes the debuggers as well).
Peer manager
To make peer manager (SDK 10(?), SDK 11, SDK 12) work with Segger Embedded Studio the modifications in this post are needed.
Troubleshooting
- Embedded Studio Reference Manual
- SEGGER's Embedded Studio Forum for Embedded Studio specific questions
- Nordic's Devzone and Technical Support for nRF5 specific questions
If you are stuck, previous blog posts (although deprecated) may help you fix your problem (also see the questions section):
shilpa
+1
ArtemS
in reply to shilpa
ArtemS
in reply to shilpa
