I am attempting to interface a Winbond flash device with the NRF52. The datasheet does not specify the idle state of MOSI when reading from the device. However, I cannot make the flash chip work with the NRF52. In the attached image, an Arduino successfully sends a command to the devices (0x06H) then reads a register (0x05H) and gets the expected result (0x02H).
As you can see here, a NRF52 sending the same sequence of commands (roughly speaking) does not get a response. I've tried a number of different frequencies and both mode 0 and 3, which are the two modes the flash chip supports.
The one obvious difference between the Arduino's output and the NRF52's output is the state of MOSI in between transfers. Although the flash memory specifies a D/C during idle periods I would like to try setting MOSI high during idle periods.
Is there a way to do this?
