Currently using a custom board that has the nRF52810 onboard along side an ESP32. I am wanting to update the firmware for the nrf chip from the ESP32 over UART. The...
I have not used Segger Embedded Studio before.
I loaded the "ble_app_pwr_profiling", and clicked on "Build and Run".
This is what the output shows:
Building ‘ble_app_pwr_profiling_pca10056_s140...
We have unit testing working with the Zephyr Unity/CMock setup, however the test runner (test_runner_generate) ignores preprocessor directives (#ifdef) and removes them when...
Hi.
Can you please tell me if there is a way to disable the SHPHLD button in nPM1300? In my application, at certain times it is necessary to disable the SHPHLD button so...
In C:ncs\v2.6.1\zephyr\subsys\bluetooth\shell\bt.c, compare line 3237 with line 4291 and you will see that the compilation flags are not used correctly regarding cmd_chan_map...
I ran across my devices reporting
Natenczas Wojski
from a UDS service that was included when running a sample HRS https://www.bluetooth.com/specifications/specs/user-data...
Hi guys, my setup:
- nRf Connect 2.6.0
- VS Code 1.88.1
- Apple Macbook M3 Max (ARM64 CPU)
- nRF52840-DK
I created a new project based on the zephyr button sample...
I am currently in the process of creating a custom pcb board that uses the nrf52840 processor in order to send bluetooth packets out from my board. I have successfully been...
I'm trying to configure the nRF Desktop Application for an Adafruit nRF52840 Feather that's plugged into a custom FeatherWing. The nRF52840 Feather is a supported board so...
Hi.
We have been trying to get the audio application to work using an external I2S microphone, but have recently run into the following problem when trying to send audio...
We are using SDK 17.0.2, which does not support the rev 3 APProtect features.
We would like to update the SDK in the future, but are looking for a shorter-term solution...
Hi Nordic
Sample: asset_tracker_v2 (with only changes to overlay-azure.conf) SDK: 2.5.2 Modem FW: nrf9160_1.3.5
I have followed this tutorial https://learn.microsoft.com...
NRF5 SDK v17.0.1
Custom board
I'm trying to take ADC measurements for a device which is powered by battery. The ADC input is fixed and should stay relatively constant...
