UART RX Callback not triggering
Hello devzone,
I am using Nordic's NUS(Nordic uart service) example and i changed pin configuration to according to our custom board.
TX_done callback working fine but there is a problem with RX_done callback it is not triggering once in a while
here is a code snippet regarding the problem
static const struct device *uart = DEVICE_DT_GET(DT_NODELABEL(uart0));
static struct k_work_delayable uart_work;
K_SEM_DEFINE(nus_write_sem, 0, 1);
struct uart_data_t
	void *fifo_reserved;
	uint8_t data[UART_BUF_SIZE];
	uint16_t len;
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	ARG_UNUSED(dev);
	static size_t aborted_len;
	struct uart_data_t *buf;
	static uint8_t *aborted_buf;
	static bool disable_req;
	switch (evt->type)
	case UART_TX_DONE:
		// LOG_DBG("UART_TX_DONE");
		// if ((evt->data.tx.len == 0) ||
		//     (!evt->data.tx.buf)) {
		// 	return;
		// if (aborted_buf) {
		// 	buf = CONTAINER_OF(aborted_buf, struct uart_data_t,
		// 			   data);
		// 	aborted_buf = NULL;
		// 	aborted_len = 0;
		// } else {
		// 	buf = CONTAINER_OF(evt->data.tx.buf,
		// 			   struct uart_data_t,
		// 			   data);
		// k_free(buf);
		// buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
		// if (!buf) {
		// 	return;
		// if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS)) {
		// 	LOG_WRN("Failed to send data over UART");
	case UART_RX_RDY:
		LOG_DBG("UART_RX_RDY");
		buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
		buf->len += evt->data.rx.len;
		if (disable_req)
			return;
		// TODO: newly added
		// if (evt->data.rx.buf[buf->len - 1] == '\n')
		if ((evt->data.rx.buf[buf->len - 1] == '\n') || (evt->data.rx.buf[buf->len - 1] == '\r'))
			disable_req = true;
			uart_rx_disable(uart);
			data_from_host = 1;
			memset(host_data, '\0', sizeof(host_data));
			memcpy(host_data, evt->data.rx.buf, (strlen(evt->data.rx.buf) - 2));
	case UART_RX_DISABLED:
		LOG_DBG("UART_RX_DISABLED");
		disable_req = false;
		//TODO:Commenting newly
		buf = k_malloc(sizeof(*buf));
		if (buf)
			buf->len = 0;
			LOG_WRN("Not able to allocate UART receive buffer");
			k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
			return;
		uart_rx_enable(uart, buf->data, sizeof(buf->data),
					   UART_RX_TIMEOUT);
	case UART_RX_BUF_REQUEST:
		LOG_DBG("UART_RX_BUF_REQUEST");
		if (buf)
			buf->len = 0;
			uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
	case UART_RX_BUF_RELEASED:
		LOG_DBG("UART_RX_BUF_RELEASED");
		buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t,
						   data);
		if (buf->len > 0)
			k_fifo_put(&fifo_uart_rx_data, buf);
			k_free(buf);
	case UART_TX_ABORTED:
		LOG_DBG("UART_TX_ABORTED");
		if (!aborted_buf)
			aborted_buf = (uint8_t *)evt->data.tx.buf;
		aborted_len += evt->data.tx.len;
						   data);
		uart_tx(uart, &buf->data[aborted_len],
				buf->len - aborted_len, SYS_FOREVER_MS);
static void uart_work_handler(struct k_work *item)
	if (buf)
		buf->len = 0;
		return;
	uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_RX_TIMEOUT);
static int uart_init(void)
	int err;
	struct uart_data_t *rx;
	if (!device_is_ready(uart))
		LOG_ERR("UART device not ready");
		return -ENODEV;
	rx = k_malloc(sizeof(*rx));
	if (rx)
		rx->len = 0;
		return -ENOMEM;
	k_work_init_delayable(&uart_work, uart_work_handler);
	err = uart_callback_set(uart, uart_cb, NULL);
	if (err)
		return err;
	return uart_rx_enable(uart, rx->data, sizeof(rx->data),
						  UART_RX_TIMEOUT);
and am using NRF connect sdk (v2.3.0)
  • Hi Theja,
    You need to give us the source code and also the context in which you are triggering UART trasactions (TX/RX). Without that, it is not possible for us to test and see why you are missing one UART_RX_RDY event.
    You could also attach the debug logs (LOG_DBG) of your run, so that we could see the sequence in which uart events are triggered and handled. This will aid us to attempt to replicate the problem at our end..
  • Hi Susheel,
    Thanks for replying have attached a source file
     * Copyright (c) 2018 Nordic Semiconductor ASA
    /** @file
     *  @brief Nordic UART Service Client sample
    #include <errno.h>
    #include <zephyr/kernel.h>
    #include <zephyr/device.h>
    #include <zephyr/sys/byteorder.h>
    #include <zephyr/bluetooth/hci.h>
    #include <zephyr/bluetooth/conn.h>
    #include <zephyr/bluetooth/uuid.h>
    #include <zephyr/bluetooth/gatt.h>
    #include <bluetooth/services/nus.h>
    #include <bluetooth/services/nus_client.h>
    #include <bluetooth/gatt_dm.h>
    #include <bluetooth/scan.h>
    #include <zephyr/settings/settings.h>
    #include <zephyr/drivers/uart.h>
    #include "fstorage.h"
    // #include "led.h"
    #include "timers.h"
    #include "protocol.h"
    // #include <bluetooth/hci_vs.h>
    #define SLEEP_TIME_MS 1000
    #define LED_PIN 17
    #define LOG_MODULE_NAME central_uart
    LOG_MODULE_REGISTER(LOG_MODULE_NAME);
    /* UART payload buffer element size. */
    #define UART_BUF_SIZE 64
    #define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
    #define KEY_PASSKEY_REJECT DK_BTN2_MSK
    #define NUS_WRITE_TIMEOUT K_MSEC(150)
    #define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
    #define UART_RX_TIMEOUT 50
    // #define UART_RX_TIMEOUT 100
    extern int last_packet_number_received;
    extern uint32_t utc_seconds_received;
    extern uint8_t time_received_from_host;
    uint32_t global_time;
    uint8_t time_string[20] = {'\0'};
    uint8_t ack_received_from_host;
    extern uint8_t restart_scan;
    latest_config_t latest_config;
    char addr[30];
    volatile uint8_t host_data[64] = {'\0'};
    volatile uint8_t data_from_host = 0;
    volatile uint8_t data_received_over_connection[128] = {'\0'};
    volatile uint8_t data_received = 0;
    uint8_t recd_packet = 0;
    uint8_t max_response_wait_time_from_host = 0;
    uint8_t ack_string[15] = {'\0'};
    uint8_t buffer[20];
    struct uart_data_t
    	uint16_t len;
    static K_FIFO_DEFINE(fifo_uart_tx_data);
    static K_FIFO_DEFINE(fifo_uart_rx_data);
    static struct bt_conn *default_conn;
    static struct bt_nus_client nus_client;
    static void ble_data_sent(struct bt_nus_client *nus, uint8_t err, const uint8_t *const data, uint16_t len)
    	ARG_UNUSED(nus);
    	// struct uart_data_t *buf;
    	/* Retrieve buffer context. */
    	// thej
    	// buf = CONTAINER_OF(data, struct uart_data_t, data);
    	// k_free(buf);
    	// k_sem_give(&nus_write_sem);
    	// if (err)
    	// 	LOG_WRN("ATT error code: 0x%02X", err);
    	//to here
    static uint8_t ble_data_received(struct bt_nus_client *nus, const uint8_t *data, uint16_t len)
    	ARG_UNUSED(nus);
    	int err;
    	//if(data_received == 0)
    		memset(data_received_over_connection, '\0', sizeof(data_received_over_connection));
    		memcpy(data_received_over_connection, data, len);
    		data_received = 1;
    	return BT_GATT_ITER_CONTINUE;
    	ARG_UNUSED(dev);
    	//thej
    	int len = 0;
    	switch (evt->type)
    	case UART_TX_DONE:
    		// 	return;
    		// 			   data);
    		// 	aborted_len = 0;
    		// } else {
    		// 			   data);
    		// k_free(buf);
    		// if (!buf) {
    		// 	return;
    	case UART_RX_RDY:
    		// if (disable_req)
    		// 	return;
    		// TODO: need to remove the block
    		// for(int i=0; i<64; i++)
    		// 	if(buf->data[i] == '\n')
    		// 		len = i;
    		// 		break;
    		// if((buf->data[len] = '\r' ) ||  (buf->data[len] == '\n'))
    		// 	disable_req = true;
    		// 	uart_rx_disable(uart);
    		// 	// buf->len = strlen(buf->data);
    		// 	memset(host_data, '0', sizeof(host_data));
    		// 	memcpy(host_data, buf->data, len);
    		// 	data_from_host = 1;
    			disable_req = true;
    			data_from_host = 1;
    		if (buf)
    			buf->len = 0;
    			return;
    					   UART_RX_TIMEOUT);
    		if (buf)
    			buf->len = 0;
    						   data);
    		if (buf->len > 0)
    			k_free(buf);
    		if (!aborted_buf)
    						   data);
    	if (buf)
    		buf->len = 0;
    		return;
    	int err;
    		return -ENODEV;
    	if (rx)
    		rx->len = 0;
    		return -ENOMEM;
    	if (err)
    		return err;
    						  UART_RX_TIMEOUT);
    static void discovery_complete(struct bt_gatt_dm *dm,
    							   void *context)
    	struct bt_nus_client *nus = context;
    	LOG_INF("Service discovery completed");
    	bt_gatt_dm_data_print(dm);
    	bt_nus_handles_assign(dm, nus);
    	bt_nus_subscribe_receive(nus);
    	bt_gatt_dm_data_release(dm);
    static void discovery_service_not_found(struct bt_conn *conn,
    										void *context)
    	LOG_INF("Service not found");
    static void discovery_error(struct bt_conn *conn,
    							int err,
    							void *context)
    	LOG_WRN("Error while discovering GATT database: (%d)", err);
    struct bt_gatt_dm_cb discovery_cb = {
    	.completed = discovery_complete,
    	.service_not_found = discovery_service_not_found,
    	.error_found = discovery_error,
    static void gatt_discover(struct bt_conn *conn)
    	int err;
    	if (conn != default_conn)
    		return;
    	err = bt_gatt_dm_start(conn,
    						   BT_UUID_NUS_SERVICE,
    						   &discovery_cb,
    						   &nus_client);
    	if (err)
    		LOG_ERR("could not start the discovery procedure, error "
    				"code: %d",
    				err);
    static void exchange_func(struct bt_conn *conn, uint8_t err, struct bt_gatt_exchange_params *params)
    	if (!err)
    		LOG_INF("MTU exchange done");
    		LOG_WRN("MTU exchange failed (err %" PRIu8 ")", err);
    static void connected(struct bt_conn *conn, uint8_t conn_err)
    	int err;
    	if (conn_err)
    		LOG_INF("Failed to connect to %s (%d)", addr, conn_err);
    		if (default_conn == conn)
    			bt_conn_unref(default_conn);
    			default_conn = NULL;
    			err = bt_scan_start(BT_SCAN_TYPE_SCAN_ACTIVE);
    			if (err)
    				LOG_ERR("Scanning failed to start (err %d)",
    						err);
    		return;
    	LOG_INF("Connected: %s", addr);
    	static struct bt_gatt_exchange_params exchange_params;
    	exchange_params.func = exchange_func;
    	err = bt_gatt_exchange_mtu(conn, &exchange_params);
    	if (err)
    		LOG_WRN("MTU exchange failed (err %d)", err);
    	err = bt_conn_set_security(conn, BT_SECURITY_L2);
    	if (err)
    		LOG_WRN("Failed to set security: %d", err);
    		gatt_discover(conn);
    	err = bt_scan_stop();
    	if ((!err) && (err != -EALREADY))
    		LOG_ERR("Stop LE scan failed (err %d)", err);
    	int err;
    	LOG_INF("Disconnected: %s (reason %u)", addr, reason);
    	if (default_conn != conn)
    		return;
    	if (err)
    				err);
    static void security_changed(struct bt_conn *conn, bt_security_t level,
    							 enum bt_security_err err)
    	if (!err)
    		LOG_INF("Security changed: %s level %u", addr, level);
    		LOG_WRN("Security failed: %s level %u err %d", addr,
    				level, err);
    BT_CONN_CB_DEFINE(conn_callbacks) = {
    	.connected = connected,
    	.disconnected = disconnected,
    	.security_changed = security_changed};
    static void scan_filter_match(struct bt_scan_device_info *device_info,
    							  struct bt_scan_filter_match *filter_match,
    							  bool connectable)
    	bt_addr_le_to_str(device_info->recv_info->addr, addr, sizeof(addr));
    	LOG_INF("Filters matched. Address: %s connectable: %d",
    			addr, connectable);
    static void scan_connecting_error(struct bt_scan_device_info *device_info)
    	LOG_WRN("Connecting failed");
    static void scan_connecting(struct bt_scan_device_info *device_info,
    	default_conn = bt_conn_ref(conn);
    static int nus_client_init(void)
    	int err;
    	struct bt_nus_client_init_param init = {
    		.cb = {
    			.received = ble_data_received,
    			.sent = ble_data_sent,
    	err = bt_nus_client_init(&nus_client, &init);
    	if (err)
    		LOG_ERR("NUS Client initialization failed (err %d)", err);
    		return err;
    	LOG_INF("NUS Client module initialized");
    	return err;
    BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL,
    				scan_connecting_error, scan_connecting);
    static int scan_init(void)
    	int err;
    	struct bt_scan_init_param scan_init = {
    		.connect_if_match = 1,
    	bt_scan_init(&scan_init);
    	bt_scan_cb_register(&scan_cb);
    	err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_UUID, BT_UUID_NUS_SERVICE);
    	if (err)
    		LOG_ERR("Scanning filters cannot be set (err %d)", err);
    		return err;
    	err = bt_scan_filter_enable(BT_SCAN_UUID_FILTER, false);
    	if (err)
    		LOG_ERR("Filters cannot be turned on (err %d)", err);
    		return err;
    	LOG_INF("Scan module initialized");
    	return err;
    static void auth_cancel(struct bt_conn *conn)
    	LOG_INF("Pairing cancelled: %s", addr);
    static void pairing_complete(struct bt_conn *conn, bool bonded)
    	LOG_INF("Pairing completed: %s, bonded: %d", addr, bonded);
    static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
    	LOG_WRN("Pairing failed conn: %s, reason %d", addr, reason);
    static struct bt_conn_auth_cb conn_auth_callbacks = {
    	.cancel = auth_cancel,
    static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
    	.pairing_complete = pairing_complete,
    	.pairing_failed = pairing_failed};
    void bluetooth_init(void)
    	int err;
    	err = bt_conn_auth_cb_register(&conn_auth_callbacks);
    	if (err)
    		LOG_ERR("Failed to register authorization callbacks.");
    		return;
    	err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
    	if (err)
    		printk("Failed to register authorization info callbacks.\n");
    		return;
    	err = bt_enable(NULL);
    	if (err)
    		LOG_ERR("Bluetooth init failed (err %d)", err);
    		return;
    	LOG_INF("Bluetooth initialized");
    	if (IS_ENABLED(CONFIG_SETTINGS))
    		settings_load();
    void scan_start(void)
    	int err;
    	if (err)
    		LOG_ERR("Scanning failed to start (err %d)", err);
    		return;
    void send_through_uart(uint8_t *data)
    	uart_tx(uart, data, strlen(data), SYS_FOREVER_MS);
    	// TODO: newly added the comment
    	k_msleep(strlen(data));
    static void wait_for_time_from_host(void)
    	uint8_t counter = 0;
    	send_time_request_to_host_controller();
    	while (!time_received_from_host)
    		//TODO: newly implemented
    		if(data_from_host)
    			data_from_host = 0;
    			parse_the_incoming_data_from_host(host_data);
    		counter++;
    		k_msleep(100);
    		if (counter > 50)
    static void wait_for_ack_from_host_controller(void)
    	while (!ack_received_from_host)
    		k_msleep(5);
    		max_response_wait_time_from_host++;
    		if(data_from_host)
    			// TODO: need to remove the below line
    			// sprintf(buffer, "data_from_host1=%d\r\n",data_from_host);
    			// send_through_uart(buffer);
    			data_from_host = 0;
    		if (max_response_wait_time_from_host == 100)
    void send_ack_to_the_sensor_for_the_last_packet()
    	ack_string[0] = 0xAB;
    	ack_string[1] = (last_packet_number_received & 0xFF000000) >> 24;
    	ack_string[2] = (last_packet_number_received & 0x00FF0000) >> 16;
    	ack_string[3] = (last_packet_number_received & 0x0000FF00) >> 8;
    	ack_string[4] = (last_packet_number_received & 0x000000FF);
    	// bt_nus_client_send(&nus_client, ack_string, strlen(ack_string));
    	bt_nus_client_send(&nus_client, ack_string, 5);
    	// k_msleep(100);
    void stop_scannig_and_restart(void)
    	scan_init();
    	scan_start();
    void stop_the_scanning(void)
    	bt_le_scan_stop();
    void send_the_current_time_to_sensor(void)
    	// if (latest_config.is_time_set)
    		time_string[0] = 0xAA;
    		time_string[1] = (global_time & 0xFF000000) >> 24;
    		time_string[2] = (global_time & 0x00FF0000) >> 16;
    		time_string[3] = (global_time & 0x0000FF00) >> 8;
    		time_string[4] = (global_time & 0x000000FF);
    		time_string[5] = 0;	 //(latest_config.commission[sensor_device_index].upload_interval & 0xFF00) >> 8;
    		time_string[6] = 60; // latest_config.commission[sensor_device_index].upload_interval & 0x00FF;
    		time_string[7] = 0;	 // latest_config.commission[sensor_device_index].index;
    		bt_nus_client_send(&nus_client, time_string, 8);
    		// k_msleep(100);
    void main(void)
    	leds_init();
    	timers_init();
    	led_blink(3);
    	bluetooth_init();
    	uart_init();
    	scan_init();
    	nus_client_init();
    	nrf_fstorage_init();
    	send_through_uart("GND Scanner Application Started\r\n");
    	wait_for_time_from_host();
    	scan_start();
    	for (;;)
    		if(data_from_host)
    			data_from_host = 0;
    		if(data_received)
    			data_received = 0;
    			parse_the_incoming_data_from_sensors(data_received_over_connection);
    		if (recd_packet)
    			recd_packet = 0;
    			ack_received_from_host = 0;
    			send_sensor_data_to_host_controller();
    			wait_for_ack_from_host_controller();
    			// TODO: remove the below lines
    			// k_msleep(500);
    			// if(data_from_host)
    			// 	data_from_host = 0;
    			// 	parse_the_incoming_data_from_host(host_data);
    			// ack_received_from_host = 1;
    			// sprintf(buffer, "data_from_host2=%d\r\n",data_from_host);
    			if (ack_received_from_host)
    				send_ack_to_the_sensor_for_the_last_packet();
    				send_through_uart("else\r\n");
    		if (time_received_from_host)
    			global_time = utc_seconds_received;
    			start_timer();
    			time_received_from_host = 0;
    			latest_config.is_time_set = 1;
    		k_sleep(K_MSEC(100));
    please note that we are using uart to send data from nrf52833 soc to controller and vice versa.
    when receive a data from controller UART_RX_RDY callback will trigger and i will copy the data there.
    the problem what i am getting (UART_RX_RDY is not triggering) is not consistent it will trigger normally but like once in a 5 or 10 minutes its not getting triggered.
  • HI Susheel,
    I have given you a source code any update regarding.
    Thank you so much for you significant patience with this.
    I took over this case for when Susheel went out of office, but I have not seen the same issue as you do.
    Are you still seeing the same issue? If you do, I will try again and update you with my progress.
    Maria
  • Hi Maria thanks for replying,
    Yes, I am seeing the same issue
