After update from nrf SDK 2.4.0 to 2.4.1 I can not add build configuration in VSCode - "No Boards Found"
I have
  • updated from sdk 2.4.0 to 2.4.1.
  • Created a  multicore hello_world application from samples inside VScode
  • Proceeded to create a build configuration but the tool does not find any boards. The pull down scrollbox is not being populated. It holds the default value: "No boards Found". This irrespective if I select Compatible boards, nordic boards or all boards in the radio buttons.
I have installed the two sdk's in the recommended locations c:\ncs
I notice that the toolchain is still using the same toolchain as v2.4.0
Any idea what is missing here.
  • i notice that the folder structure for c:\ncs\v2.4.0 is different from c:\ncs\v2.4.1. Is that to expect?
    The latter only holds the folders C:\ncs\v2.4.1\.west and C:\ncs\v2.4.1\nrf (with some content)
    Should the update tool install a new set of boards files to C:\ncs\v2.4.1\zephyr\boards? If yes, then this has not worked for me and would be a good explanation of the previous reported problem.
    Could you verify the installation method of the SDK? Was it through the Toolchain Manager?
    If so, then you might be able to resolve the issue by updating the SDK/Toolchain as shown in the image
    Andreas
  • Thanks for quick reply. yes i used this tool. Did not know this option. Will try.
    Should I apply to v2.4.0 as you show or both.. I guess both-
  • I applied the update sdk then toolchain for 2.4.0 then 2.4.1. But no apparent change.
    Can you confirm that the folder structure of 2.4.1 is supposed to be similar to 2.4.0?
    I notice that there is at least one error message (MalformedConfig) in the logfile of the Tc. Manager v1.2.5
    In copy the last lines of this file below-
    -------- logfile ----------
    2023-08-04T11:33:49.859Z DEBUG return self._get(lambda cf: cf.get(option), default, configfile)
    File "C:\ncs\toolchains\31f4403e35\opt\bin\Lib\site-packages\west\configuration.py", line 219, in _get
    2023-08-04T11:33:49.860Z DEBUG for cf in self._whence(configfile):
    File "C:\ncs\toolchains\31f4403e35\opt\bin\Lib\site-packages\west\configuration.py", line 240, in _whence
    2023-08-04T11:33:49.861Z DEBUG raise MalformedConfig('local configuration file not found')
    west.configuration
    2023-08-04T11:33:49.861Z DEBUG .MalformedConfig: local configuration file not found
    2023-08-04T11:33:50.600Z DEBUG usage: west [-h] [-z ZEPHYR_BASE] [-v] [-V] <command> ...
    west: error: argument <command>: invalid choice: 'zephyr-export' (choose from 'init', 'update', 'list', 'manifest', 'diff', 'status', 'forall', 'help', 'config', 'topdir', 'selfupdate')
    2023-08-04T11:33:50.671Z DEBUG Sending usage data {"category":"pc-nrfconnect-toolchain-manager-dev","action":"Clone nRF Connect SDK successfully","label":"v2.4.1; win32; x64"}
    2023-08-04T11:33:50.673Z DEBUG Sending usage data {"category":"pc-nrfconnect-toolchain-manager-dev","action":"Clone nRF Connect SDK time consumed","label":"0 min; v2.4.1"}
    2023-08-04T11:33:50.674Z INFO Finished cloning version v2.4.1 of the nRF Connect SDK after approximately 0 minute(s)
    2023-08-04T11:34:02.021Z DEBUG Sending usage data {"category":"pc-nrfconnect-toolchain-manager-dev","action":"Install toolchain from nrfutil","label":"v2.4.1; C:\\ncs\\toolchains\\31f4403e35"}
    Yes, the folder structure should be similar. NCS consists of multiple repositories as shown in the image here and you should expect that all of these repositories are present
    I assume you've already tried to do so, but could you remove the SDK installation and attempt a reinstall of 2.4.1?
    Andreas
