Implement bootloader in NCS SDK
Until now I was working on an application based on the nRF5 SDK: it is this application that is used by my customers.
Now I would like to use the NCS SDK to continue to have the latest features and bug fixes.
Here I almost finished redeveloping my new application (based on NCS SDK) to work like my old one (based on nRF5 SDK) but I have a problem with the bootloader...
My board (contains an nrf 52840) has no buttons and no external memory (so I will have to overwrite existing code when I do an update) but does have a UART.
I need to be able to update the application but also the bootloader.
Here are my questions:
  • I think I have to go into recovery mode to be able to update in this situation? But how can I do it if I don't have a button?
  • The update files will be sent by another microcontroller on the board via the uart: can you tell me more about what I need so that the other microcontroller can communicate with the nrf 52840 to send the files to the bootloader? (files ? protocol ?)
  • Is it possible to update a device that would work with the nRF5 SDK (secure_bootloader_uart_mbr_pca10056) to keep the old bootloader but updating the softdevice+app with the new application (NCS SDK)?
THANKS
    The following should work:
           nrf_power_gpregret_set(NRF_POWER, 0xB1);
           NVIC_SystemReset();
    Andreas
  • Thanks for your answer but how can I call this function in the NCS SDK?
    The lines I gave you was how to use it in NCS.
    To test it you can for instance add this code to a basic hello world and see that GPREGRET changes. When you want to use it in your project, change gpregret_set to use the magic 0xB1 instead of increment it.
    Open a new hello_world in vs code and modify it to include the following lines and see that gpregret changes value.
    #include <hal/nrf_power.h>
            uint8_t val = nrf_power_gpregret_get(NRF_POWER);
            printk("Old GPREGRET val: %u\n", val);
            nrf_power_gpregret_set(NRF_POWER, ++val);
            k_sleep(K_MSEC(1000));
            NVIC_SystemReset();
    Andreas
  • Thank you
    Currently I only have the MCUboot + app but I would also like to add the NSIB in addition.
    Here is the problem I have: if I load the .hex of the complete project, there is no problem (it boots into the application and it works). Now if I try to update the bootlaoder I notice that it writes the file instead of the application and not in s1... Do you have any idea why?
    There is a small peculiarity to my project: I defined CONFIG_SINGLE_APPLICATION_SLOT=y so as not to have to double the memory of my application (works very well if I only have the MCUboot).
    My chil_image/mcuboot.conf:
    #-------------------------------------------- MCUBoot--------------------------------------------
    # Bootloader version (To make s1_image bootable with nRF Secure Immutable Bootloader, the value of CONFIG_FW_INFO_FIRMWARE_VERSION for s1_image must be bigger than the one for original image):
    CONFIG_FW_INFO_FIRMWARE_VERSION=1
    # Declare for single slot and partition size for MCUBoot
    CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10000
    CONFIG_UPDATEABLE_IMAGE_NUMBER=1
    # Signature:
    CONFIG_BOOT_SIGNATURE_KEY_FILE="C:/DocTA/Soft/TA-Smart-BT840P/Application/child_image/mcuboot/key/mcuboot_private.pem"#"mcuboot/key/mcuboot_private.pem"  # add a signature key file to this bootloader. This option only accepts the private key of an ECDSA key pair, as build system scripts automatically extract the public key at build time. The file path is relatively to the application directory.
    CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
    # The build won't fit on the partition allocated for it without size optimizations.
    CONFIG_SIZE_OPTIMIZATIONS=y
    CONFIG_MULTITHREADING=y
    # Logs
    CONFIG_LOG=y
    CONFIG_RTT_CONSOLE=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_LOG_BACKEND_UART=n
    CONFIG_LOG_MODE_DEFERRED=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_PRINTK=y
    CONFIG_LOG_BUFFER_SIZE=16384
    CONFIG_LOG_MODE_OVERFLOW=y
    #---------------------------------------- Serial Recovery ----------------------------------------
    # Enable MCUboot Serial Recovery
    CONFIG_MCUBOOT_SERIAL=y
    CONFIG_UART_CONSOLE=n
    CONFIG_MCUBOOT_INDICATION_LED=y
    # Enable wait for DFU functionality (If any mcumgr commands are run before these 5 seconds have passed, the device will enter Serial Recovery Mode)
    CONFIG_BOOT_SERIAL_WAIT_FOR_DFU=y
    CONFIG_BOOT_SERIAL_WAIT_FOR_DFU_TIMEOUT=5000
    My prj.conf:
    #------------------------- NSIB (nRF Secure Immutable Bootloader) -------------------------
    CONFIG_SECURE_BOOT=y # add the immutable bootloader
    CONFIG_SB_SIGNING_KEY_FILE="C:/DocTA/Soft/TA-Smart-BT840P/Application/child_image/mcuboot/key/mcuboot_private.pem"
    CONFIG_BUILD_S1_VARIANT=y
    CONFIG_SB_NUM_VER_COUNTER_SLOTS=120
    CONFIG_FW_INFO=y # add additional logs --> prj_minimal.conf allow to desactivate
    # ---------------------------------------- MCUboot ----------------------------------------
    CONFIG_BOOTLOADER_MCUBOOT=y # add MCUboot as upgradable bootloader
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    My partitions:
    Mon fichier pm_static.yml:
    b0_container: 0x0 -> 0x9000 (0x9000)
    	b0: 0x0 -> 0x8000 (0x8000)
    	provision: 0x8000 -> 0x9000 (0x1000)
    s0: 0x9000 -> 0x19200 (0x10200)
    	s0_pad: 0x9000 -> 0x9200 (0x200)
    	s0_image: 0x9200 -> 0x19200 (0x10000)
    		mcuboot: 0x9200 -> 0x19200 (0x10000)
    EMPTY_0: 0x19200 -> 0x1a000 (0xe00)
    s1: 0x1a000 -> 0x2a200 (0x10200)
    	s1_pad: 0x1a000 -> 0x1a200 (0x200)
    	s1_image: 0x1a200 - 0x2a200 (0x10000)
    EMPTY_1: 0x2a200 -> 0x2b000 (0xe00)
    mcuboot_primary: 0x2b000 -> 0xe0000 (0xB5000)
    	mcuboot_pad: 0x2b000 -> 0x2b200 (0x200)
    	mcuboot_primary_app: 0x2b200 -> 0xe0000 (0xb4e00)
    		app_image: 0x2b200 -> 0xe0000 (0xb4e00)
    mcuboot_secondary: 0xe0000 -> 0xf0000 (0x10000)
    settings_storage: 0xf0000 -> 0x100000 (0x10000)
    sram_primary: 0x20000000 -> 0x20040000 (0x40000)
    Here it's what I did to update the bootloader:
    1. Reboot device (button on the PCA10056)
    2. Send the cmd: mcumgr -c my_config image upload Application\TA_Smart\zephyr\signed_by_mcuboot_and_b0_s1_image_update.bin
    -> file of  54.27 KB
    Here are the MCUboot logs:
    SEGGER J-Link V7.80c - Real time terminal output
    J-Link OB-SAM3U128-V2-NordicSemi compiled Sep 21 2022 09:57:39 V1.0, SN=683294247
    Process: JLink.exe
    [01:51:45.227,630] <inf> mcuboot: Erasing range 0x%jx:0x%jx
    [01:51:45.312,072] <inf> mcuboot: Writing at 0x0 until 0x128
    [01:51:45.315,246] <inf> mcuboot: RX: 0x0
    [01:51:45.318,603] <inf> mcuboot: TX
    [01:51:45.464,691] <inf> mcuboot: RX: 0x0
    [01:51:45.468,048] <inf> mcuboot: TX
    [01:51:45.605,621] <inf> mcuboot: RX: 0x0
    [01:51:45.608,978] <inf> mcuboot: TX
    [01:51:45.749,725] <inf> mcuboot: Writing at 0x128 until 0x27c
    [01:51:45.753,387] <inf> mcuboot: RX: 0x0
    [01:51:45.756,713] <inf> mcuboot: TX
    [01:51:45.907,165] <inf> mcuboot: Writing at 0x27c until 0x3d0
    [01:51:45.910,827] <inf> mcuboot: RX: 0x0
    [01:51:45.914,154] <inf> mcuboot: TX
    [01:51:46.049,072] <inf> mcuboot: Writing at 0x3d0 until 0x524
    [01:51:46.052,734] <inf> mcuboot: RX: 0x0
    [01:51:46.056,060] <inf> mcuboot: TX
    [01:51:46.191,192] <inf> mcuboot: Writing at 0x524 until 0x678
    [01:51:46.194,824] <inf> mcuboot: RX: 0x0
    [01:51:46.198,181] <inf> mcuboot: TX
    [01:51:46.332,183] <inf> mcuboot: Writing at 0x678 until 0x7cc
    [01:51:46.335,845] <inf> mcuboot: RX: 0x0
    [01:51:46.339,569] <inf> mcuboot: TX
    [01:51:46.491,149] <inf> mcuboot: Writing at 0x7cc until 0x920
    [01:51:46.494,812] <inf> mcuboot: RX: 0x0
    [01:51:46.498,168] <inf> mcuboot: TX
    [01:51:46.633,575] <inf> mcuboot: Writing at 0x920 until 0xa74
    [01:51:46.637,207] <inf> mcuboot: RX: 0x0
    [01:51:46.640,563] <inf> mcuboot: TX
    [01:51:46.773,986] <inf> mcuboot: Writing at 0xa74 until 0xbc8
    [01:51:46.777,648] <inf> mcuboot: RX: 0x0
    [01:51:46.780,975] <inf> mcuboot: TX
    [01:51:46.915,374] <inf> mcuboot: Writing at 0xbc8 until 0xd1c
    [01:51:46.919,006] <inf> mcuboot: RX: 0x0
    [01:51:46.922,363] <inf> mcuboot: TX
    [01:51:47.072,998] <inf> mcuboot: Writing at 0xd1c until 0xe70
    [01:51:47.076,660] <inf> mcuboot: RX: 0x0
    [01:51:47.080,017] <inf> mcuboot: TX
    [01:51:47.215,362] <inf> mcuboot: Writing at 0xe70 until 0xfc4
    [01:51:47.219,024] <inf> mcuboot: RX: 0x0
    [01:51:47.222,351] <inf> mcuboot: TX
    [01:51:47.357,604] <inf> mcuboot: Erasing range 0x%jx:0x%jx
    [01:51:47.442,047] <inf> mcuboot: Writing at 0xfc4 until 0x1118
    [01:51:47.445,709] <inf> mcuboot: RX: 0x0
    [01:51:47.449,066] <inf> mcuboot: TX
    [01:51:47.583,587] <inf> mcuboot: Writing at 0x1118 until 0x126c
    [01:51:47.587,249] <inf> mcuboot: RX: 0x0
    [01:51:47.590,576] <inf> mcuboot: TX
    [01:51:47.725,646] <inf> mcuboot: Writing at 0x126c until 0x13c0
    [01:51:47.729,309] <inf> mcuboot: RX: 0x0
    [01:51:47.732,635] <inf> mcuboot: TX
    [01:51:47.868,011] <inf> mcuboot: Writing at 0x13c0 until 0x1514
    [01:51:47.871,673] <inf> mcuboot: RX: 0x0
    [01:51:47.875,000] <inf> mcuboot: TX
    [01:51:48.024,780] <inf> mcuboot: Writing at 0x1514 until 0x1668
    [01:51:48.028,411] <inf> mcuboot: RX: 0x0
    [01:51:48.031,768] <inf> mcuboot: TX
    [01:51:48.165,100] <inf> mcuboot: Writing at 0x1668 until 0x17bc
    [01:51:48.169,189] <inf> mcuboot: RX: 0x0
    [01:51:48.172,546] <inf> mcuboot: TX
    [01:51:48.306,396] <inf> mcuboot: Writing at 0x17bc until 0x1910
    [01:51:48.310,058] <inf> mcuboot: RX: 0x0
    [01:51:48.313,385] <inf> mcuboot: TX
    [01:51:48.465,148] <inf> mcuboot: Writing at 0x1910 until 0x1a64
    [01:51:48.468,811] <inf> mcuboot: RX: 0x0
    [01:51:48.472,595] <inf> mcuboot: TX
    [01:51:48.606,628] <inf> mcuboot: Writing at 0x1a64 until 0x1bb8
    [01:51:48.610,290] <inf> mcuboot: RX: 0x0
    [01:51:48.613,616] <inf> mcuboot: TX
    [01:51:48.748,046] <inf> mcuboot: Writing at 0x1bb8 until 0x1d0c
    [01:51:48.751,708] <inf> mcuboot: RX: 0x0
    [01:51:48.755,035] <inf> mcuboot: TX
    [01:51:48.890,930] <inf> mcuboot: Writing at 0x1d0c until 0x1e60
    [01:51:48.895,019] <inf> mcuboot: RX: 0x0
    [01:51:48.898,345] <inf> mcuboot: TX
    [01:51:49.032,928] <inf> mcuboot: Writing at 0x1e60 until 0x1fb4
    [01:51:49.036,590] <inf> mcuboot: RX: 0x0
    [01:51:49.039,947] <inf> mcuboot: TX
    [01:51:49.173,828] <inf> mcuboot: Erasing range 0x%jx:0x%jx
    [01:51:49.258,270] <inf> mcuboot: Writing at 0x1fb4 until 0x2108
    [01:51:49.261,901] <inf> mcuboot: RX: 0x0
    [01:51:49.265,258] <inf> mcuboot: TX
    [01:51:49.393,035] <inf> mcuboot: Writing at 0x2108 until 0x225c
    [01:51:49.396,697] <inf> mcuboot: RX: 0x0
    [01:51:49.400,024] <inf> mcuboot: TX
    [01:51:49.534,301] <inf> mcuboot: Writing at 0x225c until 0x23b0
    [01:51:49.537,963] <inf> mcuboot: RX: 0x0
    [01:51:49.541,320] <inf> mcuboot: TX
    [01:51:49.676,940] <inf> mcuboot: Writing at 0x23b0 until 0x2504
    [01:51:49.680,603] <inf> mcuboot: RX: 0x0
    [01:51:49.684,356] <inf> mcuboot: TX
    [01:51:49.818,450] <inf> mcuboot: Writing at 0x2504 until 0x2658
    [01:51:49.822,082] <inf> mcuboot: RX: 0x0
    [01:51:49.825,439] <inf> mcuboot: TX
    [01:51:49.958,587] <inf> mcuboot: Writing at 0x2658 until 0x27ac
    [01:51:49.962,249] <inf> mcuboot: RX: 0x0
    [01:51:49.965,606] <inf> mcuboot: TX
    [01:51:50.117,370] <inf> mcuboot: Writing at 0x27ac until 0x2900
    [01:51:50.121,032] <inf> mcuboot: RX: 0x0
    [01:51:50.124,389] <inf> mcuboot: TX
    [01:51:50.258,758] <inf> mcuboot: Writing at 0x2900 until 0x2a54
    [01:51:50.262,420] <inf> mcuboot: RX: 0x0
    [01:51:50.265,747] <inf> mcuboot: TX
    [01:51:50.404,693] <inf> mcuboot: Writing at 0x2a54 until 0x2ba8
    [01:51:50.408,782] <inf> mcuboot: RX: 0x0
    [01:51:50.412,109] <inf> mcuboot: TX
    [01:51:50.547,058] <inf> mcuboot: Writing at 0x2ba8 until 0x2cfc
    [01:51:50.550,689] <inf> mcuboot: RX: 0x0
    [01:51:50.554,046] <inf> mcuboot: TX
    [01:51:50.688,415] <inf> mcuboot: Writing at 0x2cfc until 0x2e50
    [01:51:50.692,077] <inf> mcuboot: RX: 0x0
    [01:51:50.695,404] <inf> mcuboot: TX
    [01:51:50.829,132] <inf> mcuboot: Writing at 0x2e50 until 0x2fa4
    [01:51:50.833,221] <inf> mcuboot: RX: 0x0
    [01:51:50.836,547] <inf> mcuboot: TX
    [01:51:50.970,672] <inf> mcuboot: Erasing range 0x%jx:0x%jx
    [01:51:51.055,114] <inf> mcuboot: Writing at 0x2fa4 until 0x30f8
    [01:51:51.058,776] <inf> mcuboot: RX: 0x0
    [01:51:51.062,103] <inf> mcuboot: TX
    [01:51:51.190,490] <inf> mcuboot: Writing at 0x30f8 until 0x324c
    [01:51:51.194,122] <inf> mcuboot: RX: 0x0
    [01:51:51.197,479] <inf> mcuboot: TX
    [01:51:51.331,634] <inf> mcuboot: Writing at 0x324c until 0x33a0
    [01:51:51.335,266] <inf> mcuboot: RX: 0x0
    [01:51:51.338,623] <inf> mcuboot: TX
    [01:51:51.489,227] <inf> mcuboot: Writing at 0x33a0 until 0x34f4
    [01:51:51.492,889] <inf> mcuboot: RX: 0x0
    [01:51:51.496,246] <inf> mcuboot: TX
    [01:51:51.629,516] <inf> mcuboot: Writing at 0x34f4 until 0x3648
    [01:51:51.633,148] <inf> mcuboot: RX: 0x0
    [01:51:51.636,505] <inf> mcuboot: TX
    [01:51:51.772,888] <inf> mcuboot: Writing at 0x3648 until 0x379c
    [01:51:51.776,550] <inf> mcuboot: RX: 0x0
    [01:51:51.779,876] <inf> mcuboot: TX
    [01:51:51.914,215] <inf> mcuboot: Writing at 0x379c until 0x38f0
    [01:51:51.917,846] <inf> mcuboot: RX: 0x0
    [01:51:51.921,203] <inf> mcuboot: TX
    [01:51:52.071,868] <inf> mcuboot: Writing at 0x38f0 until 0x3a44
    [01:51:52.075,531] <inf> mcuboot: RX: 0x0
    [01:51:52.078,857] <inf> mcuboot: TX
    [01:51:52.213,714] <inf> mcuboot: Writing at 0x3a44 until 0x3b98
    [01:51:52.217,346] <inf> mcuboot: RX: 0x0
    [01:51:52.220,703] <inf> mcuboot: TX
    [01:51:52.358,001] <inf> mcuboot: Writing at 0x3b98 until 0x3cec
    [01:51:52.361,663] <inf> mcuboot: RX: 0x0
    [01:51:52.365,020] <inf> mcuboot: TX
    [01:51:52.499,237] <inf> mcuboot: Writing at 0x3cec until 0x3e40
    [01:51:52.502,899] <inf> mcuboot: RX: 0x0
    [01:51:52.506,652] <inf> mcuboot: TX
    [01:51:52.642,089] <inf> mcuboot: Writing at 0x3e40 until 0x3f94
    [01:51:52.645,751] <inf> mcuboot: RX: 0x0
    [01:51:52.649,078] <inf> mcuboot: TX
    [01:51:52.796,020] <inf> mcuboot: Erasing range 0x%jx:0x%jx
    [01:51:52.880,462] <inf> mcuboot: Writing at 0x3f94 until 0x40e8
    [01:51:52.884,094] <inf> mcuboot: RX: 0x0
    [01:51:52.887,451] <inf> mcuboot: TX
    [01:51:53.020,629] <inf> mcuboot: Writing at 0x40e8 until 0x423c
    [01:51:53.024,291] <inf> mcuboot: RX: 0x0
    [01:51:53.027,648] <inf> mcuboot: TX
    [01:51:53.163,452] <inf> mcuboot: Writing at 0x423c until 0x4390
    [01:51:53.167,114] <inf> mcuboot: RX: 0x0
    [01:51:53.170,471] <inf> mcuboot: TX
    [01:51:53.304,962] <inf> mcuboot: Writing at 0x4390 until 0x44e4
    [01:51:53.308,624] <inf> mcuboot: RX: 0x0
    [01:51:53.311,981] <inf> mcuboot: TX
    [01:51:53.446,990] <inf> mcuboot: Writing at 0x44e4 until 0x4638
    [01:51:53.450,653] <inf> mcuboot: RX: 0x0
    [01:51:53.453,979] <inf> mcuboot: TX
    [01:51:53.587,738] <inf> mcuboot: Writing at 0x4638 until 0x478c
    [01:51:53.591,400] <inf> mcuboot: RX: 0x0
    [01:51:53.594,726] <inf> mcuboot: TX
    [01:51:53.729,431] <inf> mcuboot: Writing at 0x478c until 0x48e0
    [01:51:53.733,093] <inf> mcuboot: RX: 0x0
    [01:51:53.736,450] <inf> mcuboot: TX
    [01:51:53.871,856] <inf> mcuboot: Writing at 0x48e0 until 0x4a34
    [01:51:53.875,488] <inf> mcuboot: RX: 0x0
    [01:51:53.879,272] <inf> mcuboot: TX
    [01:51:54.027,618] <inf> mcuboot: Writing at 0x4a34 until 0x4b88
    [01:51:54.031,677] <inf> mcuboot: RX: 0x0
    [01:51:54.035,034] <inf> mcuboot: TX
    [01:51:54.168,090] <inf> mcuboot: Writing at 0x4b88 until 0x4cdc
    [01:51:54.171,752] <inf> mcuboot: RX: 0x0
    [01:51:54.175,079] <inf> mcuboot: TX
    [01:51:54.310,699] <inf> mcuboot: Writing at 0x4cdc until 0x4e30
    [01:51:54.314,361] <inf> mcuboot: RX: 0x0
    [01:51:54.317,718] <inf> mcuboot: TX
    [01:51:54.467,590] <inf> mcuboot: Writing at 0x4e30 until 0x4f84
    [01:51:54.471,252] <inf> mcuboot: RX: 0x0
    [01:51:54.474,578] <inf> mcuboot: TX
    [01:51:54.608,764] <inf> mcuboot: Erasing range 0x%jx:0x%jx
    [01:51:54.693,237] <inf> mcuboot: Writing at 0x4f84 until 0x50d8
    [01:51:54.696,868] <inf> mcuboot: RX: 0x0
    [01:51:54.700,225] <inf> mcuboot: TX
    [01:51:54.828,521] <inf> mcuboot: Writing at 0x50d8 until 0x522c
    [01:51:54.832,183] <inf> mcuboot: RX: 0x0
    [01:51:54.835,540] <inf> mcuboot: TX
    [01:51:54.971,343] <inf> mcuboot: Writing at 0x522c until 0x5380
    [01:51:54.975,006] <inf> mcuboot: RX: 0x0
    [01:51:54.978,332] <inf> mcuboot: TX
    [01:51:55.113,250] <inf> mcuboot: Writing at 0x5380 until 0x54d4
    [01:51:55.117,309] <inf> mcuboot: RX: 0x0
    [01:51:55.120,666] <inf> mcuboot: TX
    [01:51:55.254,791] <inf> mcuboot: Writing at 0x54d4 until 0x5628
    [01:51:55.258,453] <inf> mcuboot: RX: 0x0
    [01:51:55.261,779] <inf> mcuboot: TX
    [01:51:55.396,789] <inf> mcuboot: Writing at 0x5628 until 0x577c
    [01:51:55.400,451] <inf> mcuboot: RX: 0x0
    [01:51:55.403,808] <inf> mcuboot: TX
    [01:51:55.538,452] <inf> mcuboot: Writing at 0x577c until 0x58d0
    [01:51:55.542,541] <inf> mcuboot: RX: 0x0
    [01:51:55.545,867] <inf> mcuboot: TX
    [01:51:55.680,908] <inf> mcuboot: Writing at 0x58d0 until 0x5a24
    [01:51:55.684,570] <inf> mcuboot: RX: 0x0
    [01:51:55.687,896] <inf> mcuboot: TX
    [01:51:55.822,296] <inf> mcuboot: Writing at 0x5a24 until 0x5b78
    [01:51:55.825,958] <inf> mcuboot: RX: 0x0
    [01:51:55.829,315] <inf> mcuboot: TX
    [01:51:55.965,026] <inf> mcuboot: Writing at 0x5b78 until 0x5ccc
    [01:51:55.968,688] <inf> mcuboot: RX: 0x0
    [01:51:55.972,045] <inf> mcuboot: TX
    [01:51:56.107,482] <inf> mcuboot: Writing at 0x5ccc until 0x5e20
    [01:51:56.111,145] <inf> mcuboot: RX: 0x0
    [01:51:56.114,898] <inf> mcuboot: TX
    [01:51:56.265,777] <inf> mcuboot: Writing at 0x5e20 until 0x5f74
    [01:51:56.269,439] <inf> mcuboot: RX: 0x0
    [01:51:56.272,796] <inf> mcuboot: TX
    [01:51:56.407,318] <inf> mcuboot: Erasing range 0x%jx:0x%jx
    [01:51:56.491,760] <inf> mcuboot: Writing at 0x5f74 until 0x60c8
    [01:51:56.495,422] <inf> mcuboot: RX: 0x0
    [01:51:56.498,748] <inf> mcuboot: TX
    [01:51:56.629,089] <inf> mcuboot: Writing at 0x60c8 until 0x621c
    [01:51:56.632,751] <inf> mcuboot: RX: 0x0
    [01:51:56.636,108] <inf> mcuboot: TX
    [01:51:56.770,568] <inf> mcuboot: Writing at 0x621c until 0x6370
    [01:51:56.774,230] <inf> mcuboot: RX: 0x0
    [01:51:56.777,557] <inf> mcuboot: TX
    [01:51:56.928,222] <inf> mcuboot: Writing at 0x6370 until 0x64c4
    [01:51:56.931,884] <inf> mcuboot: RX: 0x0
    [01:51:56.935,241] <inf> mcuboot: TX
    [01:51:57.069,854] <inf> mcuboot: Writing at 0x64c4 until 0x6618
    [01:51:57.073,516] <inf> mcuboot: RX: 0x0
    [01:51:57.076,873] <inf> mcuboot: TX
    [01:51:57.213,348] <inf> mcuboot: Writing at 0x6618 until 0x676c
    [01:51:57.217,437] <inf> mcuboot: RX: 0x0
    [01:51:57.220,764] <inf> mcuboot: TX
    [01:51:57.354,095] <inf> mcuboot: Writing at 0x676c until 0x68c0
    [01:51:57.357,757] <inf> mcuboot: RX: 0x0
    [01:51:57.361,114] <inf> mcuboot: TX
    [01:51:57.510,375] <inf> mcuboot: Writing at 0x68c0 until 0x6a14
    [01:51:57.514,038] <inf> mcuboot: RX: 0x0
    [01:51:57.517,364] <inf> mcuboot: TX
    [01:51:57.651,519] <inf> mcuboot: Writing at 0x6a14 until 0x6b68
    [01:51:57.655,151] <inf> mcuboot: RX: 0x0
    [01:51:57.658,508] <inf> mcuboot: TX
    [01:51:57.793,762] <inf> mcuboot: Writing at 0x6b68 until 0x6cbc
    [01:51:57.797,393] <inf> mcuboot: RX: 0x0
    [01:51:57.800,750] <inf> mcuboot: TX
    [01:51:57.934,417] <inf> mcuboot: Writing at 0x6cbc until 0x6e10
    [01:51:57.938,049] <inf> mcuboot: RX: 0x0
    [01:51:57.941,406] <inf> mcuboot: TX
    [01:51:58.093,688] <inf> mcuboot: Writing at 0x6e10 until 0x6f64
    [01:51:58.097,351] <inf> mcuboot: RX: 0x0
    [01:51:58.100,708] <inf> mcuboot: TX
    [01:51:58.234,161] <inf> mcuboot: Erasing range 0x%jx:0x%jx
    [01:51:58.318,603] <inf> mcuboot: Writing at 0x6f64 until 0x70b8
    [01:51:58.322,265] <inf> mcuboot: RX: 0x0
    [01:51:58.325,622] <inf> mcuboot: TX
    [01:51:58.454,589] <inf> mcuboot: Writing at 0x70b8 until 0x720c
    [01:51:58.458,251] <inf> mcuboot: RX: 0x0
    [01:51:58.461,578] <inf> mcuboot: TX
    [01:51:58.593,231] <inf> mcuboot: Writing at 0x720c until 0x7360
    [01:51:58.596,893] <inf> mcuboot: RX: 0x0
    [01:51:58.600,219] <inf> mcuboot: TX
    [01:51:58.736,328] <inf> mcuboot: Writing at 0x7360 until 0x74b4
    [01:51:58.739,990] <inf> mcuboot: RX: 0x0
    [01:51:58.743,713] <inf> mcuboot: TX
    [01:51:58.876,831] <inf> mcuboot: Writing at 0x74b4 until 0x7608
    [01:51:58.880,493] <inf> mcuboot: RX: 0x0
    [01:51:58.883,850] <inf> mcuboot: TX
    [01:51:59.020,477] <inf> mcuboot: Writing at 0x7608 until 0x775c
    [01:51:59.024,139] <inf> mcuboot: RX: 0x0
    [01:51:59.027,496] <inf> mcuboot: TX
    [01:51:59.176,086] <inf> mcuboot: Writing at 0x775c until 0x78b0
    [01:51:59.179,748] <inf> mcuboot: RX: 0x0
    [01:51:59.183,074] <inf> mcuboot: TX
    [01:51:59.317,260] <inf> mcuboot: Writing at 0x78b0 until 0x7a04
    [01:51:59.320,922] <inf> mcuboot: RX: 0x0
    [01:51:59.324,249] <inf> mcuboot: TX
    [01:51:59.458,984] <inf> mcuboot: Writing at 0x7a04 until 0x7b58
    [01:51:59.462,646] <inf> mcuboot: RX: 0x0
    [01:51:59.466,003] <inf> mcuboot: TX
    [01:51:59.599,853] <inf> mcuboot: Writing at 0x7b58 until 0x7cac
    [01:51:59.603,515] <inf> mcuboot: RX: 0x0
    [01:51:59.606,872] <inf> mcuboot: TX
    [01:51:59.756,774] <inf> mcuboot: Writing at 0x7cac until 0x7e00
    [01:51:59.760,437] <inf> mcuboot: RX: 0x0
    [01:51:59.763,763] <inf> mcuboot: TX
    [01:51:59.899,169] <inf> mcuboot: Writing at 0x7e00 until 0x7f54
    [01:51:59.902,832] <inf> mcuboot: RX: 0x0
    [01:51:59.906,188] <inf> mcuboot: TX
    [01:52:00.041,687] <inf> mcuboot: Erasing range 0x%jx:0x%jx
    [01:52:00.126,129] <inf> mcuboot: Writing at 0x7f54 until 0x80a8
    [01:52:00.129,791] <inf> mcuboot: RX: 0x0
    [01:52:00.133,148] <inf> mcuboot: TX
    [01:52:00.261,871] <inf> mcuboot: Writing at 0x80a8 until 0x81fc
    [01:52:00.265,533] <inf> mcuboot: RX: 0x0
    [01:52:00.268,890] <inf> mcuboot: TX
    [01:52:00.402,160] <inf> mcuboot: Writing at 0x81fc until 0x8350
    [01:52:00.405,822] <inf> mcuboot: RX: 0x0
    [01:52:00.409,149] <inf> mcuboot: TX
    [01:52:00.542,938] <inf> mcuboot: Writing at 0x8350 until 0x84a4
    [01:52:00.546,600] <inf> mcuboot: RX: 0x0
    [01:52:00.550,384] <inf> mcuboot: TX
    [01:52:00.685,089] <inf> mcuboot: Writing at 0x84a4 until 0x85f8
    [01:52:00.688,751] <inf> mcuboot: RX: 0x0
    [01:52:00.692,077] <inf> mcuboot: TX
    [01:52:00.842,926] <inf> mcuboot: Writing at 0x85f8 until 0x874c
    [01:52:00.846,588] <inf> mcuboot: RX: 0x0
    [01:52:00.849,914] <inf> mcuboot: TX
    [01:52:00.983,520] <inf> mcuboot: Writing at 0x874c until 0x88a0
    [01:52:00.987,182] <inf> mcuboot: RX: 0x0
    [01:52:00.990,539] <inf> mcuboot: TX
    [01:52:01.126,037] <inf> mcuboot: Writing at 0x88a0 until 0x89f4
    [01:52:01.129,699] <inf> mcuboot: RX: 0x0
    [01:52:01.133,026] <inf> mcuboot: TX
    [01:52:01.268,371] <inf> mcuboot: Writing at 0x89f4 until 0x8b48
    [01:52:01.272,033] <inf> mcuboot: RX: 0x0
    [01:52:01.275,756] <inf> mcuboot: TX
    [01:52:01.410,888] <inf> mcuboot: Writing at 0x8b48 until 0x8c9c
    [01:52:01.414,520] <inf> mcuboot: RX: 0x0
    [01:52:01.417,877] <inf> mcuboot: TX
    [01:52:01.553,497] <inf> mcuboot: Writing at 0x8c9c until 0x8df0
    [01:52:01.557,159] <inf> mcuboot: RX: 0x0
    [01:52:01.560,485] <inf> mcuboot: TX
    [01:52:01.694,274] <inf> mcuboot: Writing at 0x8df0 until 0x8f44
    [01:52:01.698,333] <inf> mcuboot: RX: 0x0
    [01:52:01.701,690] <inf> mcuboot: TX
    [01:52:01.835,174] <inf> mcuboot: Erasing range 0x%jx:0x%jx
    [01:52:01.919,616] <inf> mcuboot: Writing at 0x8f44 until 0x9098
    [01:52:01.923,278] <inf> mcuboot: RX: 0x0
    [01:52:01.926,635] <inf> mcuboot: TX
    [01:52:02.072,418] <inf> mcuboot: Writing at 0x9098 until 0x91ec
    [01:52:02.076,080] <inf> mcuboot: RX: 0x0
    [01:52:02.079,437] <inf> mcuboot: TX
    [01:52:02.214,294] <inf> mcuboot: Writing at 0x91ec until 0x9340
    [01:52:02.217,956] <inf> mcuboot: RX: 0x0
    [01:52:02.221,313] <inf> mcuboot: TX
    [01:52:02.356,872] <inf> mcuboot: Writing at 0x9340 until 0x9494
    [01:52:02.360,534] <inf> mcuboot: RX: 0x0
    [01:52:02.363,891] <inf> mcuboot: TX
    [01:52:02.499,053] <inf> mcuboot: Writing at 0x9494 until 0x95e8
    [01:52:02.502,685] <inf> mcuboot: RX: 0x0
    [01:52:02.506,042] <inf> mcuboot: TX
    [01:52:02.639,587] <inf> mcuboot: Writing at 0x95e8 until 0x973c
    [01:52:02.643,249] <inf> mcuboot: RX: 0x0
    [01:52:02.647,033] <inf> mcuboot: TX
    [01:52:02.781,036] <inf> mcuboot: Writing at 0x973c until 0x9890
    [01:52:02.784,698] <inf> mcuboot: RX: 0x0
    [01:52:02.788,024] <inf> mcuboot: TX
    [01:52:02.923,248] <inf> mcuboot: Writing at 0x9890 until 0x99e4
    [01:52:02.926,879] <inf> mcuboot: RX: 0x0
    [01:52:02.930,236] <inf> mcuboot: TX
    [01:52:03.065,002] <inf> mcuboot: Writing at 0x99e4 until 0x9b38
    [01:52:03.069,061] <inf> mcuboot: RX: 0x0
    [01:52:03.072,418] <inf> mcuboot: TX
    [01:52:03.208,221] <inf> mcuboot: Writing at 0x9b38 until 0x9c8c
    [01:52:03.211,883] <inf> mcuboot: RX: 0x0
    [01:52:03.215,240] <inf> mcuboot: TX
    [01:52:03.364,166] <inf> mcuboot: Writing at 0x9c8c until 0x9de0
    [01:52:03.367,828] <inf> mcuboot: RX: 0x0
    [01:52:03.371,612] <inf> mcuboot: TX
    [01:52:03.505,767] <inf> mcuboot: Writing at 0x9de0 until 0x9f34
    [01:52:03.509,429] <inf> mcuboot: RX: 0x0
    [01:52:03.512,756] <inf> mcuboot: TX
    [01:52:03.649,688] <inf> mcuboot: Erasing range 0x%jx:0x%jx
    [01:52:03.734,130] <inf> mcuboot: Writing at 0x9f34 until 0xa088
    [01:52:03.737,792] <inf> mcuboot: RX: 0x0
    [01:52:03.741,119] <inf> mcuboot: TX
    [01:52:03.871,246] <inf> mcuboot: Writing at 0xa088 until 0xa1dc
    [01:52:03.874,908] <inf> mcuboot: RX: 0x0
    [01:52:03.878,234] <inf> mcuboot: TX
    [01:52:04.028,320] <inf> mcuboot: Writing at 0xa1dc until 0xa330
    [01:52:04.031,982] <inf> mcuboot: RX: 0x0
    [01:52:04.035,308] <inf> mcuboot: TX
    [01:52:04.170,745] <inf> mcuboot: Writing at 0xa330 until 0xa484
    [01:52:04.174,407] <inf> mcuboot: RX: 0x0
    [01:52:04.177,764] <inf> mcuboot: TX
    [01:52:04.313,049] <inf> mcuboot: Writing at 0xa484 until 0xa5d8
    [01:52:04.316,711] <inf> mcuboot: RX: 0x0
    [01:52:04.320,068] <inf> mcuboot: TX
    [01:52:04.454,956] <inf> mcuboot: Writing at 0xa5d8 until 0xa72c
    [01:52:04.458,618] <inf> mcuboot: RX: 0x0
    [01:52:04.462,371] <inf> mcuboot: TX
    [01:52:04.611,724] <inf> mcuboot: Writing at 0xa72c until 0xa880
    [01:52:04.615,386] <inf> mcuboot: RX: 0x0
    [01:52:04.618,713] <inf> mcuboot: TX
    [01:52:04.754,089] <inf> mcuboot: Writing at 0xa880 until 0xa9d4
    [01:52:04.757,720] <inf> mcuboot: RX: 0x0
    [01:52:04.761,474] <inf> mcuboot: TX
    [01:52:04.895,019] <inf> mcuboot: Writing at 0xa9d4 until 0xab28
    [01:52:04.898,681] <inf> mcuboot: RX: 0x0
    [01:52:04.902,038] <inf> mcuboot: TX
    [01:52:05.035,919] <inf> mcuboot: Writing at 0xab28 until 0xac7c
    [01:52:05.039,581] <inf> mcuboot: RX: 0x0
    [01:52:05.042,907] <inf> mcuboot: TX
    [01:52:05.193,634] <inf> mcuboot: Writing at 0xac7c until 0xadd0
    [01:52:05.197,296] <inf> mcuboot: RX: 0x0
    [01:52:05.200,622] <inf> mcuboot: TX
    [01:52:05.336,730] <inf> mcuboot: Writing at 0xadd0 until 0xaf24
    [01:52:05.340,393] <inf> mcuboot: RX: 0x0
    [01:52:05.343,750] <inf> mcuboot: TX
    [01:52:05.478,424] <inf> mcuboot: Erasing range 0x%jx:0x%jx
    [01:52:05.562,866] <inf> mcuboot: Writing at 0xaf24 until 0xb078
    [01:52:05.566,528] <inf> mcuboot: RX: 0x0
    [01:52:05.569,885] <inf> mcuboot: TX
    [01:52:05.699,066] <inf> mcuboot: Writing at 0xb078 until 0xb1cc
    [01:52:05.702,728] <inf> mcuboot: RX: 0x0
    [01:52:05.706,054] <inf> mcuboot: TX
    [01:52:05.855,438] <inf> mcuboot: Writing at 0xb1cc until 0xb320
    [01:52:05.859,100] <inf> mcuboot: RX: 0x0
    [01:52:05.862,457] <inf> mcuboot: TX
    [01:52:05.998,809] <inf> mcuboot: Writing at 0xb320 until 0xb474
    [01:52:06.002,441] <inf> mcuboot: RX: 0x0
    [01:52:06.005,798] <inf> mcuboot: TX
    [01:52:06.139,312] <inf> mcuboot: Writing at 0xb474 until 0xb5c8
    [01:52:06.142,974] <inf> mcuboot: RX: 0x0
    [01:52:06.146,331] <inf> mcuboot: TX
    [01:52:06.281,799] <inf> mcuboot: Writing at 0xb5c8 until 0xb71c
    [01:52:06.285,461] <inf> mcuboot: RX: 0x0
    [01:52:06.289,215] <inf> mcuboot: TX
    [01:52:06.438,507] <inf> mcuboot: Writing at 0xb71c until 0xb870
    [01:52:06.442,596] <inf> mcuboot: RX: 0x0
    [01:52:06.445,922] <inf> mcuboot: TX
    [01:52:06.580,230] <inf> mcuboot: Writing at 0xb870 until 0xb9c4
    [01:52:06.583,892] <inf> mcuboot: RX: 0x0
    [01:52:06.587,249] <inf> mcuboot: TX
    [01:52:06.723,083] <inf> mcuboot: Writing at 0xb9c4 until 0xbb18
    [01:52:06.726,745] <inf> mcuboot: RX: 0x0
    [01:52:06.730,072] <inf> mcuboot: TX
    [01:52:06.864,379] <inf> mcuboot: Writing at 0xbb18 until 0xbc6c
    [01:52:06.868,011] <inf> mcuboot: RX: 0x0
    [01:52:06.871,368] <inf> mcuboot: TX
    [01:52:07.023,193] <inf> mcuboot: Writing at 0xbc6c until 0xbdc0
    [01:52:07.026,855] <inf> mcuboot: RX: 0x0
    [01:52:07.030,212] <inf> mcuboot: TX
    [01:52:07.165,649] <inf> mcuboot: Writing at 0xbdc0 until 0xbf14
    [01:52:07.169,311] <inf> mcuboot: RX: 0x0
    [01:52:07.172,637] <inf> mcuboot: TX
    [01:52:07.306,335] <inf> mcuboot: Erasing range 0x%jx:0x%jx
    [01:52:07.390,777] <inf> mcuboot: Writing at 0xbf14 until 0xc068
    [01:52:07.394,439] <inf> mcuboot: RX: 0x0
    [01:52:07.397,796] <inf> mcuboot: TX
    [01:52:07.526,092] <inf> mcuboot: Writing at 0xc068 until 0xc1bc
    [01:52:07.529,754] <inf> mcuboot: RX: 0x0
    [01:52:07.533,081] <inf> mcuboot: TX
    [01:52:07.666,900] <inf> mcuboot: Writing at 0xc1bc until 0xc310
    [01:52:07.670,562] <inf> mcuboot: RX: 0x0
    [01:52:07.673,919] <inf> mcuboot: TX
    [01:52:07.807,067] <inf> mcuboot: Writing at 0xc310 until 0xc464
    [01:52:07.810,729] <inf> mcuboot: RX: 0x0
    [01:52:07.814,514] <inf> mcuboot: TX
    [01:52:07.948,303] <inf> mcuboot: Writing at 0xc464 until 0xc5b8
    [01:52:07.951,965] <inf> mcuboot: RX: 0x0
    [01:52:07.955,291] <inf> mcuboot: TX
    [01:52:08.106,353] <inf> mcuboot: Writing at 0xc5b8 until 0xc70c
    [01:52:08.110,015] <inf> mcuboot: RX: 0x0
    [01:52:08.113,342] <inf> mcuboot: TX
    [01:52:08.247,253] <inf> mcuboot: Writing at 0xc70c until 0xc860
    [01:52:08.250,915] <inf> mcuboot: RX: 0x0
    [01:52:08.254,241] <inf> mcuboot: TX
    [01:52:08.390,380] <inf> mcuboot: Writing at 0xc860 until 0xc9b4
    [01:52:08.394,042] <inf> mcuboot: RX: 0x0
    [01:52:08.397,369] <inf> mcuboot: TX
    [01:52:08.532,806] <inf> mcuboot: Writing at 0xc9b4 until 0xcb08
    [01:52:08.536,468] <inf> mcuboot: RX: 0x0
    [01:52:08.540,161] <inf> mcuboot: TX
    [01:52:08.674,468] <inf> mcuboot: Writing at 0xcb08 until 0xcc5c
    [01:52:08.678,131] <inf> mcuboot: RX: 0x0
    [01:52:08.681,457] <inf> mcuboot: TX
    [01:52:08.817,474] <inf> mcuboot: Writing at 0xcc5c until 0xcdb0
    [01:52:08.821,136] <inf> mcuboot: RX: 0x0
    [01:52:08.824,462] <inf> mcuboot: TX
    [01:52:08.958,709] <inf> mcuboot: Writing at 0xcdb0 until 0xcf04
    [01:52:08.962,799] <inf> mcuboot: RX: 0x0
    [01:52:08.966,125] <inf> mcuboot: TX
    [01:52:09.099,914] <inf> mcuboot: Erasing range 0x%jx:0x%jx
    [01:52:09.184,356] <inf> mcuboot: Writing at 0xcf04 until 0xd058
    [01:52:09.188,018] <inf> mcuboot: RX: 0x0
    [01:52:09.191,345] <inf> mcuboot: TX
    [01:52:09.338,226] <inf> mcuboot: Writing at 0xd058 until 0xd1ac
    [01:52:09.341,888] <inf> mcuboot: RX: 0x0
    [01:52:09.345,245] <inf> mcuboot: TX
    [01:52:09.495,605] <inf> mcuboot: Writing at 0xd1ac until 0xd300
    [01:52:09.499,267] <inf> mcuboot: RX: 0x0
    [01:52:09.502,593] <inf> mcuboot: TX
    [01:52:09.638,153] <inf> mcuboot: Writing at 0xd300 until 0xd454
    [01:52:09.641,784] <inf> mcuboot: RX: 0x0
    [01:52:09.645,141] <inf> mcuboot: TX
    [01:52:09.780,731] <inf> mcuboot: Writing at 0xd454 until 0xd5a8
    [01:52:09.784,393] <inf> mcuboot: RX: 0x0
    [01:52:09.787,750] <inf> mcuboot: TX
    [01:52:09.926,452] <inf> mcuboot: Writing at 0xd5a8 until 0xd6fc
    [01:52:09.930,114] <inf> mcuboot: RX: 0x0
    [01:52:09.933,471] <inf> mcuboot: TX
    [01:52:10.070,190] <inf> mcuboot: Writing at 0xd6fc until 0xd850
    [01:52:10.073,852] <inf> mcuboot: RX: 0x0
    [01:52:10.077,178] <inf> mcuboot: TX
    [01:52:10.153,869] <inf> mcuboot: Writing at 0xd850 until 0xd910
    [01:52:10.156,066] <inf> mcuboot: Erasing range 0x%jx:0x%jx
    [01:52:10.240,844] <inf> mcuboot: RX: 0x0
    [01:52:10.244,201] <inf> mcuboot: TX
    Initially I would recommend you to create a new case since this is a new topic
    Secondly here are a couple of thoughts that you can do for testing before creating this new case:
    1. You should be aware of this warning regarding NSIB
    2.  Regarding MCUboot images. Correct me if I am wrong, but I suspect that you may believe that MCUboot updates work the same as "regular" application updates. It's not quite the same, as the new MCUboot image is uploaded to mcuboot_secondary before it is swapped to s1. Then NSIB reads a flag stating which slot it should run MCUBOOT from, i.e s0 or s1 depending on which is the latest update, and then MCUboot starts the application.
      It might be possible to set https://github.com/nrfconnect/sdk-mcuboot/blob/main/boot/zephyr/Kconfig.serial_recovery#L49 MCUBOOT_SERIAL_DIRECT_IMAGE_UPLOAD and "-n" to upload the image to s1 directly, or it might be possible to use MCUBOOT_SERIAL_DIRECT_IMAGE_UPLOAD and the file that is only signed by b0.
      I haven't tested this at all, so this is a large disclaimer that this might not work at all
    Andreas
