nRF9160-DK as JTAG programmer to nRF7002-DK or Thingy:53
Hi
I am preparing a project for the MAKE IT MATTER contest.
During experiments I broke the USB connector on the nRF7002-DK.
Fortunately we already have downloaded the Light Bulb firmware on nRF 7002-DK and tested before the USB was broken. We have now a working Light Bulb module but no apparent way to reprogram it.
Looking for alternatives, a solution could be connecting the DK via JTAG connector + flat cable + JTAG programmer. Reading Nordic documentation we see that another DK can be used as a JTAG programmer.
So here some questions:
1 - How exactly nRF9160-DK (as JTAG programmer - debugger) can be connected with the nRF7002-DK using the JTAG flat cable?
2 - What is needed is to be able to discover the target device (nRF7002-DK) inside VS code or nRF Connect programmer.
3 - If that can be done can I do the same with Thingy:53 and how exactly?
4 - Can the other micro USB connector (nRF5340 USB) be used to program the nRF5340 chip?
5 - And finally is any way to externally solder / connect a USB connector? The tracks on the original Micro USB are damaged.
Note : I have been through a similar post 2 years ago  nRF9160 DK as a Debugger for a second nRF9160 DK:
devzone.nordicsemi.com/.../nrf9160-dk-as-a-debugger-for-a-second-nrf9160-dk
But my target board is different
nRF5340-DK was ordered as well some time ago but it will not be here on time
I appreciate any help since the nRF7002-DK can not programmed in time for the contest.
So getting the nRF7002 to life is crucial.
Regards
Vasilis
    The last hours I did some progress but was unable to program the target (nRF7002-DK). I got this error in VS code:
    [error] [ Client] - Encountered error -11: Command erase_file executed for 2075 milliseconds with result -11
    [error] [  nRF53] - Failed while detecting device memory block protection status!
    What was done so far:
    1 - Connect the two boards with JTAG cable. nRF9150-DK OUT to nRF7002-DK IN
    2 - Leave the Voltage selector on nRF9260-DK in 1V8 position. When in 3V board is dead.
    3 - Power the nRF7002-DK via nRF5340 USB port
    4 - Plug the USB cable on the debugger port (nRF9160-DK)
    at this point I see a JLINK device discovered. If JTAG flat cable is not connecting the two boards I see that nRF9160 is discovered.
    I suppose that means that nrF9160-DK works OK as a JTAG programmer when the tow boards are connected via flat cable.
    It looks that I can not start programming the nRF7002-DK which now runs the Light Bulb Matter program.
    If I can program it with a blink program that will be a good start.
    What am I doing wrong?
    Thanks for any extra help
    Vasilis
  • eading Nordic documentation we see that another DK can be used as a JTAG programmer.
    Correct! For the nRF7002DK to be programmed you need a programmer that is able to program the onboard SoC.  Since the nRF7002DK uses a nRF5340 you will need a DK that has a onboard programmer that will support it.
    To be on the safe side you should either be using a nRF9160DK or a nRF5340DK, these two will be able to program everything we have including nRF5340 and nRF9160's.
    So since it seams that you have a nRF9160 available you should be fine.
    There are a few ways to program the "external board"(your broken nRF7002DK) so the simplest option according to most is to use a flat ribbon cable. These are easy to use and there is no extra fumbling with cables.
    First and simplest option(if you have a flat ribbon cable)
    Connect the cable to P19 (Debug out) on the DK that you use as your programmer(nRF9160DK or nRF5340DK) then connect the other end of the flat ribbon cable to  P18 (Debug in) on the nRF7002DK.
    So from here:
    To here:
    Second option is to use some cables and connect from P20 on the programmer DK to the external boards P25 trace pads.
    From here:
    The image above is from a nRF5340DK but its the same on the nRF9160 DK. And the custom board will be your broken 7002DK
    To here:
    Its a bit more tricky and you will have to solder on to the pads. GND and VDD also needs to be connected but that can be done to any of the corresponding P1 female headers
    There are other options as well here for method two, but feel free to ask and I will guide you.
    Jonathan
  • Hi Vasilis, looks like approtect is on, try to run a recover first.
    You can do this with either running nrfjprog --recover in the terminal or click on the recover option for connected devices
    Or you can use the nRF connect for Desktop programmer application by clicking on the Erase all button
    Jonathan
  • Hi Jonathan
    Within VS trying to recover I got the message:
    Error recovering device. see output tab
    [11/21/2023, 1:06:31 PM] Unable to resolve configuration with compilerPath "/home/vorrias/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc".  Using "/usr/bin/clang-14" instead.
    Within nRF connect for Desktop programmer I have the erase dimmed
    Regards
    Vasilis
    NOTE: I did not change anything on my DKs.
    I  see your notes afterwords.
    Anyway I am reading your last post to see your directions
  • Still stuck?
    Try to only power the nRF7002DK with two jumper cables, one for VDD and one for GND. Then use the 10pin connector cable.
    If in need of a infographic i can provide one later.
    Jonathan
