Two services on a single device
Here's what we're trying to do. We have a gesture recognition wearable that is intended to be used as a remote control for a smartphone. But some smartphone functions are easier to implement using the HID service and some using a custom service. We have the wearable and the phone connected and both services are shown in nRF Connect but if we pair with the HID service first we cannot connect to the custom service using a custom app on the smartphone. Similarly, if we pair to the custom service first, we cannot use the HID service. How do we get both services to work simultaneously from one device?
  • Logger output and offending code for no mem hardfault:
    <info> app_timer: RTC: initialized.
    <error> app: ERROR 4 [NRF_ERROR_NO_MEM] at C:\Nordic\gestr_GRM_Rev2.0\main.c:3565
    PC at: 0x0002C263
    <error> app: End of error report
        // Enable BLE stack.
    Logger output when trying to exercise both HID and custom (link count set to 2 to avoid the nomem crash):
    Haptic driver interface go!
    LIS3MDL Sensor interface go!
    <debug> nrf_sdh: State request: 0x00000000
    <debug> nrf_sdh: Notify observer 0x00044604 => ready
    <debug> nrf_sdh: State change: 0x00000000
    <debug> nrf_sdh: State change: 0x00000001
    <debug> nrf_sdh_ble: RAM starts at 0x20002BE0
    <debug> nrf_sdh_ble: RAM start location can be adjusted to 0x20002990.
    <debug> nrf_sdh_ble: RAM size for application can be adjusted to 0x3D670.
    <info> ble_bms: Init complete.
    <info> app: HID Keyboard example started.
    <info> app: Fast advertising.
    <debug> nrf_sdh_ble: BLE event: 0x10.
    <info> app: Connected
    <debug> nrf_sdh_ble: BLE event: 0x14.
    <debug> nrf_sdh_ble: BLE event: 0x1A.
    <debug> nrf_sdh_ble: BLE event: 0x50.
    <info> app: on_write: len 2, p_evt_write->data[0]: 1, p_evt_write->data[1]: 0.
    <debug> nrf_sdh_ble: BLE event: 0x12.
    gesture: 3
    <debug> nrf_sdh_ble: BLE event: 0x57.
    gesture: 3
    gesture: 7
    gesture: 2
    gesture: 2
    Note that when exercising the custom interface I get a BLE event 0x57, but no event when exercising the HID interface. Here is the code that goes with that log:
            switch (finalGesture) {
              case L2R:
                //ble_cus_custom_value_update(&m_cus, gestr_cus_key_array[volUp]);
                keys_send( 1, gestr_hid_key_array+finalGesture );
              case R2L:
                //ble_cus_custom_value_update(&m_cus, gestr_cus_key_array[volDown]);
              case U2D:
                ble_cus_custom_value_update(&m_cus, gestr_cus_key_array[mediaPP1]);
              case D2U:
                 //ble_cus_custom_value_update(&m_cus, gestr_cus_key_array[mediaNext]);
                 keys_send( 1, gestr_hid_key_array+D2U );
    In this case, gestures 3 and 7 run the custom service, 2 runs the HID interface. Here is a screenshot of the nRF Connect view of this connection. I have 4 services running, could it be that only two are enabled because of the link count setting?
    Thank you for the update.
    Please make sure to adjust your flash placement macros for the project to match the suggestion from the nrf_sdh_ble module.
    No, the link could should not affect the number of enabled services.
    Have you tried connecting to your peripheral from 2 different centrals, and seeing that all the services work as intended then?
    I expect that there could be some issue on the smartphone side to 'share' the link between the OS and your custom application still, and so this would be a good test to verify that the peripheral is working as intended.
    Karl
  • OK, I got both services to run at the same time by bonding the HID connection and then establishing that first (advertise the HID interface only), and then starting the custom service advertising only after the HID interface is connected in ble_evt_handler. However, when I do this the HID interface doesn't work because I get an attribute missing error 3401 when running sd_ble_gatts_hvx in the ble_hids_inp_rep_send subroutine in the file ble_hids.c. The code compiles and runs without error, but the values are never sent to the smartphone. I've tried restoring the sys attributes using sd_ble_gatts_sys_attr_get and sd_ble_gatts_sys_attr_set but that hasn't worked. Here is the code for the "Connected" case:
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                //apdobaj 27Jun2023 set tx power
                err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_CONN, m_conn_handle, +8);
                attrs = sd_ble_gatts_sys_attr_get(m_conn_handle, p_attr_data, p_len, BLE_GATTS_SYS_ATTR_FLAG_SYS_SRVCS);
                err_code = sd_ble_gatts_sys_attr_get(m_conn_handle, p_attr_data, *p_len, BLE_GATTS_SYS_ATTR_FLAG_SYS_SRVCS);
                //apdobaj connect HID first then custom
                nrf_delay_ms(2);
    #if defined(USE_CUSTOM_SERVICE)
                advertising_init_cus();
                advertising_start_cus();
  • More info: when I disable the custom service, the call to sd_ble_gatts_hvx returns error code 0x0F which I glean is NRF_ERROR_FORBIDDEN. How do I correct that?
    The call to sd_ble_gatts_hvx will fail with the NRF_ERROR_FORBIDDEN return code if the security level of the connection is too low for the security requirements of the characteristic you are attempting to write. Could you bond for second device as well, to see if this resolves the issue?
    Karl
