Connecting the npm1300 to a custom board
Good Day.
I'm trying to run the "npm1300_fuel_gauge" example on a custom board (nRF52840), but I'm getting errors that I don't know how to fix.
The first thing I did was to get the PMIC configuration overlay file (config.overlay) through nPM PowerUP. Then I transferred the code from config.overlay to the custom board device tree file (custom_board_nrf52840.dts). I plan to connect the PMIC via I2C1.
custom_board_nrf52840.dts -->
&i2c1 {
	compatible = "nordic,nrf-twi";
	/* Cannot be used together with spi1. */
	status = "okay";
	pinctrl-0 = <&i2c1_default>;
	pinctrl-1 = <&i2c1_sleep>;
	npm1300_ek_pmic: pmic@6b {
		compatible = "nordic,npm1300";
		reg = <0x6b>;
		npm1300_ek_gpio: gpio-controller {
			compatible = "nordic,npm1300-gpio";
			gpio-controller;
			#gpio-cells = <2>;
			ngpios = <5>;
		npm1300_ek_regulators: regulators {
			compatible = "nordic,npm1300-regulator";
	npm1300_ek_buck1: BUCK1 {
	 regulator-min-microvolt = <1000000>;
	 regulator-max-microvolt = <3300000>;
	 retention-microvolt = <1200000>;
	npm1300_ek_buck2: BUCK2 {
	 retention-microvolt = <1800000>;
	npm1300_ek_ldo1: LDO1 {
	 regulator-initial-mode = <NPM1300_LDSW_MODE_LDSW>;
	 // soft-start-microamp = <10000>;
	npm1300_ek_ldo2: LDO2 {
	npm1300_ek_charger: charger {
	 compatible = "nordic,npm1300-charger";
	 term-microvolt = <4200000>;
	 term-warm-microvolt = <3600000>;
	 // term-current-percent = <10>;
	 current-microamp = <100000>;
	 // trickle-microvolt = <2900000>;
	 dischg-limit-microamp = <1000000>;
	 vbus-limit-microamp = <500000>;
	 thermistor-ohms = <10000>;
	 thermistor-beta = <3380>;
	 charging-enable;
	npm1300_ek_leds: leds {
	 compatible = "nordic,npm1300-led";
	 nordic,led0-mode = "error";
	  nordic,led1-mode = "charging";
	  nordic,led2-mode = "host";
custom_board_nrf52840-pinctrl.dtsi -->
i2c1_default: i2c1_default {
		group1 {
			psels = <NRF_PSEL(TWIM_SDA, 0, 15)>,
				<NRF_PSEL(TWIM_SCL, 0, 17)>;
			bias-pull-up;
	i2c1_sleep: i2c1_sleep {
		group1 {
			low-power-enable;
The following errors occur in the .dts file (see screenshot).
I know that these values should be taken from the "fuel_gauge.h" file, but that doesn't happen for some reason.
I see an error in the prj.conf file too (see screenshot).
When building the project, I see the following information -->
I have not changed the CMakeLists.txt files.
# Copyright (c) 2023 Nordic Semiconductor ASA
cmake_minimum_required(VERSION 3.20.0)
set(SHIELD npm1300_ek)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(my_npm1300_fuel_gauge)
add_subdirectory(src)
Can you please tell me where I am making a mistake when transferring this example to my custom board?
Thank you.
  • backstreet.devisor said:
    3. When I connect the battery (custom model profile) I see a different percentage of charge each time. For example, I connect the battery and the program shows 82 %, I immediately disconnect the EK from the computer and reconnect it and PowerUP shows already 88 % charge. On average, the charge value differs by 5% when you turn it on again. Is this normal program behavior or is something wrong?
    That does not sound correct, no.
    Do you see the same with a Development Kit, or is it only with the custom board?
    4. The charging end time is almost never displayed when charging is turned on (see screenshot). Is this normal?
    I will check this, but i guess it is not.
    Same as above: Do you see this with a DK?
    5. In the fuel_gauge example, there is a file called battery_model.inc in the src folder. I understand that this is the battery profile for the example. How do I add my own battery profile (which I already have)? Do I need to rename it to "battery_model" and replace the existing file or can I add it with an arbitrary name (for example, my_battery.inc)?
    Maybe this: Generating a battery model?
  • Hi Sigurd.
    3.
    I observe this strange behavior both when using only nPM1300 EK when displaying charge level in nPM PowerUP, and when using custom board (host) + nPM1300 EK when displaying battery data via terminal.
    4.
    TTF is also not displayed both when using only EK and when using custom board + EK.  And if you disconnect the charger, the time to discharge (TTE) is displayed incorrectly and jumps from 700 hours to 20 hours (using a 600 mAh battery), with only 1 LED on the user board constantly lit and i2C mode enabled.
    5.
    This link doesn't explain how to integrate the .inc model into your own application. There is only this note,
    but it doesn't answer my question. I already have my battery profile in .inc format and I want to figure out how I can integrate it into my final app.
    Thanks.
    See here, and how they use the battery_model struct in the code.
    If the PowerUP measurements still do not match after you have added the .inc, we can continue looking into that.
    But for now, that is the prime suspect to what goes wrong
  • Hi Sigurd. Thank you for continuing to respond.
    I put my battery file into the program.
    And ran some tests.
    Here is the result (on the screenshot). The time to update the readings is 1 minute.
    As you can see, TTE and TTF are not displayed, although enough time has passed.
    Perhaps this is due to the long refresh period of the readings (1 min)? What is the maximum update time I can set?
    I set the refresh time to 1 second again and the TTE values displayed but were too unstable.
    Thanks.
