Connecting the npm1300 to a custom board
Good Day.
I'm trying to run the "npm1300_fuel_gauge" example on a custom board (nRF52840), but I'm getting errors that I don't know how to fix.
The first thing I did was to get the PMIC configuration overlay file (config.overlay) through nPM PowerUP. Then I transferred the code from config.overlay to the custom board device tree file (custom_board_nrf52840.dts). I plan to connect the PMIC via I2C1.
custom_board_nrf52840.dts -->
&i2c1 {
	compatible = "nordic,nrf-twi";
	/* Cannot be used together with spi1. */
	status = "okay";
	pinctrl-0 = <&i2c1_default>;
	pinctrl-1 = <&i2c1_sleep>;
	npm1300_ek_pmic: pmic@6b {
		compatible = "nordic,npm1300";
		reg = <0x6b>;
		npm1300_ek_gpio: gpio-controller {
			compatible = "nordic,npm1300-gpio";
			gpio-controller;
			#gpio-cells = <2>;
			ngpios = <5>;
		npm1300_ek_regulators: regulators {
			compatible = "nordic,npm1300-regulator";
	npm1300_ek_buck1: BUCK1 {
	 regulator-min-microvolt = <1000000>;
	 regulator-max-microvolt = <3300000>;
	 retention-microvolt = <1200000>;
	npm1300_ek_buck2: BUCK2 {
	 retention-microvolt = <1800000>;
	npm1300_ek_ldo1: LDO1 {
	 regulator-initial-mode = <NPM1300_LDSW_MODE_LDSW>;
	 // soft-start-microamp = <10000>;
	npm1300_ek_ldo2: LDO2 {
	npm1300_ek_charger: charger {
	 compatible = "nordic,npm1300-charger";
	 term-microvolt = <4200000>;
	 term-warm-microvolt = <3600000>;
	 // term-current-percent = <10>;
	 current-microamp = <100000>;
	 // trickle-microvolt = <2900000>;
	 dischg-limit-microamp = <1000000>;
	 vbus-limit-microamp = <500000>;
	 thermistor-ohms = <10000>;
	 thermistor-beta = <3380>;
	 charging-enable;
	npm1300_ek_leds: leds {
	 compatible = "nordic,npm1300-led";
	 nordic,led0-mode = "error";
	  nordic,led1-mode = "charging";
	  nordic,led2-mode = "host";
custom_board_nrf52840-pinctrl.dtsi -->
i2c1_default: i2c1_default {
		group1 {
			psels = <NRF_PSEL(TWIM_SDA, 0, 15)>,
				<NRF_PSEL(TWIM_SCL, 0, 17)>;
			bias-pull-up;
	i2c1_sleep: i2c1_sleep {
		group1 {
			low-power-enable;
The following errors occur in the .dts file (see screenshot).
I know that these values should be taken from the "fuel_gauge.h" file, but that doesn't happen for some reason.
I see an error in the prj.conf file too (see screenshot).
When building the project, I see the following information -->
I have not changed the CMakeLists.txt files.
# Copyright (c) 2023 Nordic Semiconductor ASA
cmake_minimum_required(VERSION 3.20.0)
set(SHIELD npm1300_ek)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(my_npm1300_fuel_gauge)
add_subdirectory(src)
Can you please tell me where I am making a mistake when transferring this example to my custom board?
Thank you.
  • A bit of a nitpick, but since your only red ring was where you included batter_model, it is good to check:
    Did you remember to use it for the init as well?
  • The TTE=nan could be either an error with the floats themselves or with the print statement.
    To check which:
    Could you debug the application, and add a Watch for the tte and ttf values?
  • Hi Sigurd.
    Now the value of TTE and TTF are calculated. The text files contain TTE and TTF measurement results, the reading update time is 10 seconds.
    1. Can you please confirm that these TTE values are normal?
    *** Booting nRF Connect SDK v3.5.99-ncs1 ***
    nRF Fuel Gauge version: 0.9.2
    [00:00:00.285,430] <inf> PMIC: PMIC device ok
    V: 3.945, I: 0.028, T: 24.79, SoC: 84.53, TTE: nan, TTF: nan
    V: 3.945, I: 0.022, T: 24.69, SoC: 84.45, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 84.30, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 84.17, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 84.06, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 83.96, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 83.87, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 83.79, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 83.72, TTE: nan, TTF: nan
    V: 3.945, I: 0.028, T: 24.79, SoC: 83.72, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 83.66, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 83.60, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 83.54, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 83.49, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 83.44, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 83.40, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 83.36, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 83.31, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 83.27, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 83.24, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 83.20, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 83.16, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 83.13, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 83.10, TTE: nan, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 83.07, TTE: 2835, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 83.03, TTE: 5042, TTF: nan
    V: 3.916, I: 0.029, T: 24.69, SoC: 83.01, TTE: 6910, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.98, TTE: 8689, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 82.95, TTE: 10368, TTF: nan
    V: 3.916, I: 0.027, T: 24.69, SoC: 82.92, TTE: 11945, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.89, TTE: 13447, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.87, TTE: 14883, TTF: nan
    V: 3.945, I: 0.028, T: 24.69, SoC: 82.87, TTE: 16382, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 82.84, TTE: 17814, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 82.82, TTE: 18830, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.79, TTE: 19850, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 82.77, TTE: 20869, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.75, TTE: 21881, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 82.72, TTE: 22882, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 82.70, TTE: 23869, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.68, TTE: 24842, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.66, TTE: 25801, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.64, TTE: 26744, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 82.62, TTE: 27673, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 82.59, TTE: 28586, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.57, TTE: 29484, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.55, TTE: 30366, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.53, TTE: 31233, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 82.52, TTE: 32083, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 82.50, TTE: 32918, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.48, TTE: 33737, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.46, TTE: 34471, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.44, TTE: 35198, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.42, TTE: 35921, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 82.40, TTE: 36711, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.39, TTE: 37486, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 82.37, TTE: 38244, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 82.35, TTE: 38475, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 82.32, TTE: 38690, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 82.30, TTE: 38888, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 82.28, TTE: 39069, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.26, TTE: 39328, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.24, TTE: 39650, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 82.23, TTE: 40019, TTF: nan
    V: 3.916, I: 0.027, T: 24.69, SoC: 82.21, TTE: 40374, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 82.19, TTE: 40666, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 82.17, TTE: 41006, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.16, TTE: 41381, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.14, TTE: 41785, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 82.13, TTE: 42210, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.11, TTE: 42650, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.10, TTE: 43102, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.08, TTE: 43561, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 82.07, TTE: 44026, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 82.05, TTE: 44381, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 82.03, TTE: 44647, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 82.01, TTE: 44842, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.99, TTE: 44979, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 81.98, TTE: 45177, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 81.96, TTE: 45423, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.94, TTE: 45597, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 81.93, TTE: 45822, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 81.92, TTE: 46225, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 81.90, TTE: 46776, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.89, TTE: 47330, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.87, TTE: 47884, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.85, TTE: 48291, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.83, TTE: 48579, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 81.82, TTE: 48892, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.80, TTE: 49177, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.79, TTE: 49510, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.77, TTE: 49734, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.75, TTE: 49871, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 81.74, TTE: 50059, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 81.73, TTE: 50286, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.71, TTE: 50423, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.69, TTE: 50489, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.68, TTE: 50498, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.66, TTE: 50462, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.65, TTE: 50526, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.63, TTE: 50668, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.61, TTE: 50874, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.60, TTE: 51129, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.58, TTE: 51284, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.57, TTE: 51358, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.55, TTE: 51506, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.54, TTE: 51573, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 81.53, TTE: 51694, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 81.52, TTE: 51856, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.50, TTE: 52071, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 81.49, TTE: 52449, TTF: nan
    V: 3.911, I: 0.027, T: 24.69, SoC: 81.47, TTE: 52775, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.46, TTE: 53124, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.44, TTE: 53344, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.43, TTE: 53602, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 81.42, TTE: 54018, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.41, TTE: 54433, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.39, TTE: 54849, TTF: nan
    V: 3.911, I: 0.027, T: 24.79, SoC: 81.37, TTE: 55050, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.36, TTE: 55152, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.35, TTE: 55312, TTF: nan
    V: 3.916, I: 0.028, T: 24.69, SoC: 81.34, TTE: 55646, TTF: nan
    V: 3.911, I: 0.027, T: 24.69, SoC: 81.32, TTE: 55928, TTF: nan
    V: 3.911, I: 0.027, T: 24.69, SoC: 81.31, TTE: 56172, TTF: nan
    V: 3.911, I: 0.027, T: 24.69, SoC: 81.29, TTE: 56386, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.28, TTE: 56639, TTF: nan
    V: 3.916, I: 0.028, T: 24.79, SoC: 81.27, TTE: 57049, TTF: nan
    V: 3.911, I: 0.027, T: 24.69, SoC: 81.25, TTE: 57387, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.24, TTE: 57740, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.23, TTE: 58098, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.21, TTE: 58459, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.20, TTE: 58824, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.19, TTE: 59034, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.17, TTE: 59122, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.16, TTE: 59265, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.15, TTE: 59299, TTF: nan
    V: 3.911, I: 0.027, T: 24.69, SoC: 81.13, TTE: 59407, TTF: nan
    V: 3.911, I: 0.027, T: 24.79, SoC: 81.12, TTE: 59498, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.11, TTE: 59647, TTF: nan
    V: 3.911, I: 0.027, T: 24.79, SoC: 81.09, TTE: 59769, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.08, TTE: 59792, TTF: nan
    V: 3.906, I: 0.027, T: 24.69, SoC: 81.06, TTE: 59687, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.05, TTE: 59675, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 81.04, TTE: 59803, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.03, TTE: 59965, TTF: nan
    V: 3.911, I: 0.028, T: 24.69, SoC: 81.01, TTE: 60158, TTF: nan
    V: 3.911, I: 0.027, T: 24.79, SoC: 81.00, TTE: 60166, TTF: nan
    V: 3.911, I: 0.027, T: 24.69, SoC: 80.99, TTE: 60252, TTF: nan
    V: 3.911, I: 0.027, T: 24.69, SoC: 80.97, TTE: 60392, TTF: nan
    V: 3.911, I: 0.028, T: 24.79, SoC: 80.96, TTE: 60642, TTF: nan
    V: 3.916, I: 0.027, T: 24.69, SoC: 80.85, TTE: 64605, TTF: nan
    V: 3.896, I: 0.033, T: 24.79, SoC: 80.82, TTE: 63375, TTF: nan
    V: 3.906, I: 0.026, T: 24.79, SoC: 80.80, TTE: 63105, TTF: nan
    V: 3.906, I: 0.027, T: 24.69, SoC: 80.78, TTE: 62813, TTF: nan
    V: 3.896, I: 0.027, T: 24.69, SoC: 80.76, TTE: 62328, TTF: nan
    V: 3.896, I: 0.027, T: 24.69, SoC: 80.74, TTE: 61702, TTF: nan
    V: 3.896, I: 0.026, T: 24.79, SoC: 80.71, TTE: 60933, TTF: nan
    V: 3.896, I: 0.027, T: 24.79, SoC: 80.69, TTE: 60109, TTF: nan
    V: 3.906, I: 0.026, T: 24.79, SoC: 80.67, TTE: 59354, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.66, TTE: 58661, TTF: nan
    V: 3.896, I: 0.026, T: 24.69, SoC: 80.63, TTE: 57881, TTF: nan
    V: 3.906, I: 0.026, T: 24.79, SoC: 80.62, TTE: 57215, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.60, TTE: 56635, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 80.58, TTE: 56056, TTF: nan
    V: 3.906, I: 0.025, T: 24.79, SoC: 80.56, TTE: 55524, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 80.55, TTE: 54993, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.53, TTE: 54605, TTF: nan
    V: 3.896, I: 0.026, T: 24.69, SoC: 80.51, TTE: 54098, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.49, TTE: 53623, TTF: nan
    V: 3.896, I: 0.026, T: 24.79, SoC: 80.47, TTE: 53062, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.46, TTE: 52547, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.44, TTE: 52103, TTF: nan
    V: 3.906, I: 0.026, T: 24.79, SoC: 80.43, TTE: 51712, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.41, TTE: 51364, TTF: nan
    V: 3.906, I: 0.026, T: 24.79, SoC: 80.39, TTE: 51019, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.38, TTE: 50001, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.36, TTE: 48919, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 80.35, TTE: 48103, TTF: nan
    V: 3.896, I: 0.026, T: 24.69, SoC: 80.33, TTE: 47357, TTF: nan
    V: 3.896, I: 0.026, T: 24.79, SoC: 80.31, TTE: 46799, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.29, TTE: 46504, TTF: nan
    V: 3.906, I: 0.026, T: 24.79, SoC: 80.28, TTE: 46458, TTF: nan
    V: 3.906, I: 0.026, T: 24.79, SoC: 80.26, TTE: 46575, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.25, TTE: 46720, TTF: nan
    V: 3.906, I: 0.026, T: 24.79, SoC: 80.23, TTE: 46882, TTF: nan
    V: 3.906, I: 0.026, T: 24.79, SoC: 80.22, TTE: 47206, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.20, TTE: 47511, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.19, TTE: 47801, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.18, TTE: 48117, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.16, TTE: 48448, TTF: nan
    V: 3.906, I: 0.026, T: 24.79, SoC: 80.15, TTE: 48790, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.13, TTE: 49102, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.12, TTE: 49554, TTF: nan
    V: 3.906, I: 0.025, T: 24.79, SoC: 80.10, TTE: 49924, TTF: nan
    V: 3.891, I: 0.025, T: 24.79, SoC: 80.08, TTE: 50191, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.07, TTE: 50455, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 80.05, TTE: 50708, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 80.04, TTE: 50918, TTF: nan
    V: 3.906, I: 0.025, T: 24.79, SoC: 80.02, TTE: 51101, TTF: nan
    V: 3.906, I: 0.026, T: 24.79, SoC: 80.01, TTE: 51296, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 80.00, TTE: 51458, TTF: nan
    V: 3.906, I: 0.025, T: 24.79, SoC: 79.98, TTE: 51601, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.97, TTE: 51769, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.95, TTE: 52066, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 79.94, TTE: 52513, TTF: nan
    V: 3.906, I: 0.025, T: 24.79, SoC: 79.92, TTE: 52873, TTF: nan
    V: 3.906, I: 0.026, T: 24.69, SoC: 79.91, TTE: 53208, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.90, TTE: 53476, TTF: nan
    V: 3.906, I: 0.025, T: 24.79, SoC: 79.88, TTE: 53701, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.87, TTE: 53889, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.85, TTE: 54048, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.84, TTE: 54183, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.83, TTE: 54298, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.81, TTE: 54397, TTF: nan
    V: 3.906, I: 0.025, T: 24.79, SoC: 79.80, TTE: 54483, TTF: nan
    V: 3.906, I: 0.025, T: 24.79, SoC: 79.78, TTE: 54558, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.77, TTE: 54624, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.76, TTE: 54682, TTF: nan
    V: 3.906, I: 0.025, T: 24.79, SoC: 79.74, TTE: 54772, TTF: nan
    V: 3.906, I: 0.024, T: 24.69, SoC: 79.73, TTE: 55083, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.71, TTE: 55336, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.70, TTE: 55542, TTF: nan
    V: 3.906, I: 0.025, T: 24.79, SoC: 79.69, TTE: 55749, TTF: nan
    V: 3.906, I: 0.025, T: 24.79, SoC: 79.67, TTE: 55949, TTF: nan
    V: 3.906, I: 0.025, T: 24.79, SoC: 79.66, TTE: 56102, TTF: nan
    V: 3.906, I: 0.024, T: 24.69, SoC: 79.64, TTE: 56229, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.63, TTE: 56374, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.62, TTE: 56522, TTF: nan
    V: 3.906, I: 0.024, T: 24.69, SoC: 79.60, TTE: 56635, TTF: nan
    V: 3.906, I: 0.024, T: 24.79, SoC: 79.59, TTE: 56692, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.58, TTE: 56787, TTF: nan
    V: 3.906, I: 0.025, T: 24.79, SoC: 79.56, TTE: 56855, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.55, TTE: 56950, TTF: nan
    V: 3.906, I: 0.025, T: 24.79, SoC: 79.54, TTE: 57058, TTF: nan
    V: 3.906, I: 0.024, T: 24.69, SoC: 79.52, TTE: 57138, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.51, TTE: 57243, TTF: nan
    V: 3.906, I: 0.025, T: 24.79, SoC: 79.50, TTE: 57358, TTF: nan
    V: 3.906, I: 0.021, T: 24.79, SoC: 79.48, TTE: 57336, TTF: nan
    V: 3.906, I: 0.025, T: 24.69, SoC: 79.47, TTE: 57387, TTF: nan
    V: 3.896, I: 0.027, T: 24.79, SoC: 79.45, TTE: 57388, TTF: nan
    V: 3.891, I: 0.028, T: 24.79, SoC: 79.43, TTE: 57295, TTF: nan
    V: 3.896, I: 0.027, T: 24.69, SoC: 79.42, TTE: 57151, TTF: nan
    V: 3.891, I: 0.027, T: 24.79, SoC: 79.40, TTE: 56910, TTF: nan
    V: 3.891, I: 0.028, T: 24.69, SoC: 79.38, TTE: 56627, TTF: nan
    V: 3.896, I: 0.027, T: 24.69, SoC: 79.37, TTE: 56370, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 79.35, TTE: 56035, TTF: nan
    V: 3.896, I: 0.027, T: 24.79, SoC: 79.34, TTE: 55712, TTF: nan
    V: 3.896, I: 0.027, T: 24.79, SoC: 79.32, TTE: 55398, TTF: nan
    V: 3.896, I: 0.027, T: 24.69, SoC: 79.30, TTE: 55092, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 79.29, TTE: 54733, TTF: nan
    V: 3.896, I: 0.028, T: 24.79, SoC: 79.27, TTE: 54455, TTF: nan
    V: 3.896, I: 0.028, T: 24.69, SoC: 79.26, TTE: 54192, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 79.24, TTE: 53861, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 79.22, TTE: 53518, TTF: nan
    V: 3.891, I: 0.028, T: 24.79, SoC: 79.21, TTE: 53186, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 79.19, TTE: 52798, TTF: nan
    V: 3.896, I: 0.028, T: 24.69, SoC: 79.18, TTE: 52466, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 79.16, TTE: 52089, TTF: nan
    V: 3.896, I: 0.027, T: 24.69, SoC: 79.14, TTE: 51739, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 79.13, TTE: 51386, TTF: nan
    V: 3.896, I: 0.027, T: 24.69, SoC: 79.11, TTE: 51048, TTF: nan
    V: 3.891, I: 0.028, T: 24.69, SoC: 79.09, TTE: 50707, TTF: nan
    V: 3.891, I: 0.028, T: 24.69, SoC: 79.08, TTE: 50460, TTF: nan
    V: 3.896, I: 0.028, T: 24.69, SoC: 79.06, TTE: 50205, TTF: nan
    V: 3.891, I: 0.028, T: 24.79, SoC: 79.05, TTE: 49974, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 79.03, TTE: 49776, TTF: nan
    V: 3.896, I: 0.027, T: 24.79, SoC: 79.02, TTE: 49645, TTF: nan
    V: 3.896, I: 0.027, T: 24.69, SoC: 79.00, TTE: 49611, TTF: nan
    V: 3.886, I: 0.027, T: 24.69, SoC: 78.98, TTE: 49527, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.97, TTE: 49437, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.95, TTE: 49385, TTF: nan
    V: 3.891, I: 0.028, T: 24.69, SoC: 78.93, TTE: 49337, TTF: nan
    V: 3.891, I: 0.028, T: 24.79, SoC: 78.92, TTE: 49286, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.90, TTE: 49206, TTF: nan
    V: 3.891, I: 0.026, T: 24.69, SoC: 78.88, TTE: 49136, TTF: nan
    V: 3.891, I: 0.027, T: 24.79, SoC: 78.87, TTE: 49031, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.85, TTE: 48898, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.83, TTE: 48817, TTF: nan
    V: 3.896, I: 0.027, T: 24.69, SoC: 78.82, TTE: 48821, TTF: nan
    V: 3.891, I: 0.027, T: 24.79, SoC: 78.80, TTE: 48816, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.79, TTE: 48838, TTF: nan
    V: 3.886, I: 0.027, T: 24.69, SoC: 78.77, TTE: 48750, TTF: nan
    V: 3.891, I: 0.028, T: 24.69, SoC: 78.75, TTE: 48729, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.74, TTE: 48673, TTF: nan
    V: 3.886, I: 0.026, T: 24.69, SoC: 78.72, TTE: 48572, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.70, TTE: 48468, TTF: nan
    V: 3.891, I: 0.027, T: 24.79, SoC: 78.69, TTE: 48376, TTF: nan
    V: 3.896, I: 0.027, T: 24.79, SoC: 78.67, TTE: 48352, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.65, TTE: 48283, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.64, TTE: 48228, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.62, TTE: 48207, TTF: nan
    V: 3.886, I: 0.027, T: 24.79, SoC: 78.60, TTE: 48111, TTF: nan
    V: 3.896, I: 0.027, T: 24.79, SoC: 78.59, TTE: 48051, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.57, TTE: 48067, TTF: nan
    V: 3.891, I: 0.027, T: 24.79, SoC: 78.56, TTE: 48096, TTF: nan
    V: 3.886, I: 0.027, T: 24.69, SoC: 78.54, TTE: 48087, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.52, TTE: 48072, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.51, TTE: 48059, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.49, TTE: 48073, TTF: nan
    V: 3.886, I: 0.027, T: 24.69, SoC: 78.48, TTE: 48076, TTF: nan
    V: 3.891, I: 0.027, T: 24.79, SoC: 78.46, TTE: 48088, TTF: nan
    V: 3.891, I: 0.027, T: 24.79, SoC: 78.44, TTE: 48114, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.43, TTE: 48152, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.41, TTE: 48152, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.40, TTE: 48168, TTF: nan
    V: 3.886, I: 0.027, T: 24.69, SoC: 78.38, TTE: 48151, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.36, TTE: 48203, TTF: nan
    V: 3.886, I: 0.027, T: 24.69, SoC: 78.35, TTE: 48189, TTF: nan
    V: 3.886, I: 0.027, T: 24.69, SoC: 78.33, TTE: 48154, TTF: nan
    V: 3.886, I: 0.027, T: 24.69, SoC: 78.31, TTE: 48169, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.30, TTE: 48192, TTF: nan
    V: 3.886, I: 0.027, T: 24.79, SoC: 78.28, TTE: 48180, TTF: nan
    V: 3.891, I: 0.026, T: 24.69, SoC: 78.26, TTE: 48116, TTF: nan
    V: 3.891, I: 0.027, T: 24.69, SoC: 78.25, TTE: 48090, TTF: nan
    2. TTF's readings look adequate and similar to the truth))
    [00:00:00.411,102] <inf> PMIC: PMIC device ok
    V: 3.945, I: 0.022, T: 24.69, SoC: 78.35, TTE: nan, TTF: nan
    V: 3.945, I: 0.021, T: 24.69, SoC: 78.35, TTE: nan, TTF: nan
    [00:00:46.324,920] <inf> PMIC: Vbus connected
    V: 3.891, I: 0.024, T: 24.69, SoC: 78.29, TTE: nan, TTF: nan
    V: 4.189, I: -0.126, T: 24.79, SoC: 78.29, TTE: nan, TTF: nan
    V: 4.194, I: -0.126, T: 24.69, SoC: 78.35, TTE: nan, TTF: nan
    V: 4.204, I: -0.126, T: 24.69, SoC: 78.41, TTE: nan, TTF: nan
    V: 4.204, I: -0.126, T: 24.69, SoC: 78.47, TTE: nan, TTF: nan
    V: 4.194, I: -0.126, T: 24.79, SoC: 78.53, TTE: nan, TTF: nan
    V: 4.204, I: -0.126, T: 24.69, SoC: 78.59, TTE: nan, TTF: nan
    V: 4.208, I: -0.126, T: 24.69, SoC: 78.64, TTE: nan, TTF: nan
    V: 4.208, I: -0.126, T: 24.69, SoC: 78.70, TTE: nan, TTF: nan
    V: 4.204, I: -0.126, T: 24.69, SoC: 78.76, TTE: nan, TTF: nan
    V: 4.208, I: -0.126, T: 24.79, SoC: 78.82, TTE: nan, TTF: nan
    V: 4.208, I: -0.126, T: 24.69, SoC: 78.88, TTE: nan, TTF: nan
    V: 4.204, I: -0.126, T: 24.69, SoC: 78.94, TTE: nan, TTF: nan
    V: 4.208, I: -0.126, T: 24.69, SoC: 79.00, TTE: nan, TTF: nan
    V: 4.208, I: -0.126, T: 24.69, SoC: 79.06, TTE: nan, TTF: nan
    V: 4.208, I: -0.126, T: 24.69, SoC: 79.12, TTE: nan, TTF: nan
    V: 4.208, I: -0.126, T: 24.69, SoC: 79.18, TTE: nan, TTF: nan
    V: 4.208, I: -0.126, T: 24.69, SoC: 79.24, TTE: nan, TTF: nan
    V: 4.208, I: -0.126, T: 24.69, SoC: 79.30, TTE: nan, TTF: nan
    V: 4.204, I: -0.126, T: 24.69, SoC: 79.36, TTE: nan, TTF: nan
    V: 4.208, I: -0.126, T: 24.69, SoC: 79.42, TTE: nan, TTF: nan
    V: 4.208, I: -0.126, T: 24.69, SoC: 79.48, TTE: nan, TTF: nan
    V: 4.208, I: -0.126, T: 24.69, SoC: 79.54, TTE: nan, TTF: nan
    V: 4.204, I: -0.126, T: 24.69, SoC: 79.60, TTE: nan, TTF: nan
    V: 4.208, I: -0.126, T: 24.69, SoC: 79.65, TTE: nan, TTF: nan
    V: 4.208, I: -0.126, T: 24.69, SoC: 79.71, TTE: nan, TTF: 3564
    V: 4.208, I: -0.126, T: 24.69, SoC: 79.77, TTE: nan, TTF: 3548
    V: 4.204, I: -0.126, T: 24.69, SoC: 79.83, TTE: nan, TTF: 3533
    V: 4.204, I: -0.126, T: 24.79, SoC: 79.89, TTE: nan, TTF: 3519
    V: 4.204, I: -0.126, T: 24.69, SoC: 79.95, TTE: nan, TTF: 3505
    V: 4.204, I: -0.126, T: 24.69, SoC: 80.01, TTE: nan, TTF: 3492
    V: 4.204, I: -0.126, T: 24.69, SoC: 80.07, TTE: nan, TTF: 3479
    V: 4.204, I: -0.126, T: 24.69, SoC: 80.13, TTE: nan, TTF: 3467
    V: 4.204, I: -0.126, T: 24.69, SoC: 80.18, TTE: nan, TTF: 3454
    V: 4.208, I: -0.126, T: 24.69, SoC: 80.24, TTE: nan, TTF: 3442
    V: 4.204, I: -0.126, T: 24.69, SoC: 80.30, TTE: nan, TTF: 3431
    V: 4.208, I: -0.126, T: 24.69, SoC: 80.36, TTE: nan, TTF: 3419
    V: 4.204, I: -0.126, T: 24.69, SoC: 80.42, TTE: nan, TTF: 3408
    V: 4.204, I: -0.126, T: 24.69, SoC: 80.48, TTE: nan, TTF: 3397
    V: 4.204, I: -0.126, T: 24.69, SoC: 80.53, TTE: nan, TTF: 3387
    V: 4.204, I: -0.126, T: 24.69, SoC: 80.59, TTE: nan, TTF: 3376
    V: 4.204, I: -0.126, T: 24.69, SoC: 80.65, TTE: nan, TTF: 3366
    V: 4.208, I: -0.126, T: 24.69, SoC: 80.71, TTE: nan, TTF: 3356
    V: 4.208, I: -0.126, T: 24.69, SoC: 80.76, TTE: nan, TTF: 3346
    V: 4.208, I: -0.126, T: 24.69, SoC: 80.82, TTE: nan, TTF: 3336
    V: 4.208, I: -0.126, T: 24.69, SoC: 80.88, TTE: nan, TTF: 3326
    V: 4.208, I: -0.126, T: 24.69, SoC: 80.94, TTE: nan, TTF: 3316
    V: 4.208, I: -0.126, T: 24.69, SoC: 80.99, TTE: nan, TTF: 3306
    V: 4.208, I: -0.126, T: 24.69, SoC: 81.05, TTE: nan, TTF: 3297
    V: 4.208, I: -0.126, T: 24.69, SoC: 81.11, TTE: nan, TTF: 3287
    V: 4.208, I: -0.126, T: 24.69, SoC: 81.17, TTE: nan, TTF: 3278
    V: 4.208, I: -0.126, T: 24.69, SoC: 81.22, TTE: nan, TTF: 3268
    V: 4.208, I: -0.126, T: 24.69, SoC: 81.28, TTE: nan, TTF: 3259
    V: 4.208, I: -0.126, T: 24.69, SoC: 81.34, TTE: nan, TTF: 3249
    V: 4.208, I: -0.126, T: 24.69, SoC: 81.39, TTE: nan, TTF: 3240
    V: 4.213, I: -0.126, T: 24.69, SoC: 81.45, TTE: nan, TTF: 3230
    V: 4.213, I: -0.126, T: 24.69, SoC: 81.51, TTE: nan, TTF: 3221
    V: 4.213, I: -0.126, T: 24.69, SoC: 81.56, TTE: nan, TTF: 3211
    V: 4.213, I: -0.126, T: 24.69, SoC: 81.62, TTE: nan, TTF: 3202
    V: 4.213, I: -0.126, T: 24.69, SoC: 81.68, TTE: nan, TTF: 3192
    V: 4.213, I: -0.126, T: 24.69, SoC: 81.74, TTE: nan, TTF: 3183
    V: 4.213, I: -0.126, T: 24.69, SoC: 81.79, TTE: nan, TTF: 3173
    V: 4.213, I: -0.126, T: 24.69, SoC: 81.85, TTE: nan, TTF: 3164
    V: 4.213, I: -0.126, T: 24.69, SoC: 81.91, TTE: nan, TTF: 3154
    V: 4.213, I: -0.126, T: 24.69, SoC: 81.96, TTE: nan, TTF: 3145
    V: 4.213, I: -0.126, T: 24.69, SoC: 82.02, TTE: nan, TTF: 3135
    V: 4.213, I: -0.126, T: 24.69, SoC: 82.08, TTE: nan, TTF: 3126
    V: 4.218, I: -0.126, T: 24.69, SoC: 82.13, TTE: nan, TTF: 3116
    V: 4.213, I: -0.126, T: 24.79, SoC: 82.19, TTE: nan, TTF: 3107
    V: 4.218, I: -0.126, T: 24.69, SoC: 82.25, TTE: nan, TTF: 3097
    V: 4.218, I: -0.126, T: 24.69, SoC: 82.30, TTE: nan, TTF: 3087
    V: 4.223, I: -0.126, T: 24.69, SoC: 82.36, TTE: nan, TTF: 3078
    V: 4.218, I: -0.126, T: 24.69, SoC: 82.42, TTE: nan, TTF: 3068
    V: 4.218, I: -0.126, T: 24.69, SoC: 82.48, TTE: nan, TTF: 3058
    V: 4.218, I: -0.126, T: 24.69, SoC: 82.53, TTE: nan, TTF: 3049
    V: 4.223, I: -0.126, T: 24.69, SoC: 82.59, TTE: nan, TTF: 3039
    V: 4.218, I: -0.126, T: 24.69, SoC: 82.65, TTE: nan, TTF: 3030
    V: 4.218, I: -0.126, T: 24.69, SoC: 82.70, TTE: nan, TTF: 3021
    V: 4.218, I: -0.126, T: 24.69, SoC: 82.76, TTE: nan, TTF: 3011
    V: 4.218, I: -0.126, T: 24.69, SoC: 82.82, TTE: nan, TTF: 3002
    V: 4.218, I: -0.126, T: 24.69, SoC: 82.87, TTE: nan, TTF: 2993
    V: 4.223, I: -0.126, T: 24.69, SoC: 82.93, TTE: nan, TTF: 2984
    V: 4.223, I: -0.126, T: 24.69, SoC: 82.98, TTE: nan, TTF: 2974
    V: 4.223, I: -0.126, T: 24.69, SoC: 83.04, TTE: nan, TTF: 2965
    V: 4.218, I: -0.126, T: 24.69, SoC: 83.10, TTE: nan, TTF: 2956
    V: 4.218, I: -0.126, T: 24.69, SoC: 83.15, TTE: nan, TTF: 2948
    V: 4.218, I: -0.126, T: 24.69, SoC: 83.21, TTE: nan, TTF: 2939
    V: 4.223, I: -0.126, T: 24.69, SoC: 83.26, TTE: nan, TTF: 2930
    V: 4.223, I: -0.126, T: 24.69, SoC: 83.32, TTE: nan, TTF: 2922
    V: 4.223, I: -0.126, T: 24.69, SoC: 83.37, TTE: nan, TTF: 2913
    V: 4.223, I: -0.126, T: 24.69, SoC: 83.43, TTE: nan, TTF: 2905
    V: 4.223, I: -0.126, T: 24.69, SoC: 83.48, TTE: nan, TTF: 2896
    V: 4.223, I: -0.126, T: 24.69, SoC: 83.54, TTE: nan, TTF: 2888
    V: 4.223, I: -0.126, T: 24.69, SoC: 83.59, TTE: nan, TTF: 2880
    V: 4.218, I: -0.126, T: 24.69, SoC: 83.65, TTE: nan, TTF: 2872
    V: 4.223, I: -0.126, T: 24.69, SoC: 83.70, TTE: nan, TTF: 2864
    V: 4.223, I: -0.126, T: 24.69, SoC: 83.76, TTE: nan, TTF: 2856
    V: 4.223, I: -0.126, T: 24.69, SoC: 83.81, TTE: nan, TTF: 2848
    V: 4.223, I: -0.126, T: 24.69, SoC: 83.86, TTE: nan, TTF: 2840
    V: 4.223, I: -0.126, T: 24.69, SoC: 83.92, TTE: nan, TTF: 2832
    V: 4.218, I: -0.126, T: 24.69, SoC: 83.97, TTE: nan, TTF: 2825
    V: 4.223, I: -0.126, T: 24.69, SoC: 84.02, TTE: nan, TTF: 2818
    V: 4.228, I: -0.126, T: 24.69, SoC: 84.08, TTE: nan, TTF: 2810
    V: 4.218, I: -0.126, T: 24.69, SoC: 84.13, TTE: nan, TTF: 2803
    V: 4.228, I: -0.126, T: 24.69, SoC: 84.18, TTE: nan, TTF: 2795
    V: 4.228, I: -0.126, T: 24.69, SoC: 84.23, TTE: nan, TTF: 2788
    V: 4.228, I: -0.126, T: 24.69, SoC: 84.29, TTE: nan, TTF: 2780
    V: 4.228, I: -0.126, T: 24.69, SoC: 84.34, TTE: nan, TTF: 2773
    V: 4.228, I: -0.126, T: 24.69, SoC: 84.39, TTE: nan, TTF: 2765
    V: 4.228, I: -0.126, T: 24.69, SoC: 84.44, TTE: nan, TTF: 2758
    V: 4.228, I: -0.126, T: 24.69, SoC: 84.50, TTE: nan, TTF: 2751
    V: 4.228, I: -0.126, T: 24.69, SoC: 84.55, TTE: nan, TTF: 2743
    V: 4.228, I: -0.126, T: 24.69, SoC: 84.60, TTE: nan, TTF: 2736
    V: 4.228, I: -0.126, T: 24.69, SoC: 84.65, TTE: nan, TTF: 2729
    V: 4.228, I: -0.126, T: 24.69, SoC: 84.70, TTE: nan, TTF: 2721
    V: 4.228, I: -0.126, T: 24.69, SoC: 84.75, TTE: nan, TTF: 2714
    V: 4.228, I: -0.126, T: 24.69, SoC: 84.81, TTE: nan, TTF: 2707
    V: 4.228, I: -0.126, T: 24.69, SoC: 84.86, TTE: nan, TTF: 2700
    V: 4.228, I: -0.126, T: 24.69, SoC: 84.91, TTE: nan, TTF: 2692
    V: 4.228, I: -0.125, T: 24.69, SoC: 84.96, TTE: nan, TTF: 2685
    V: 4.228, I: -0.125, T: 24.69, SoC: 85.01, TTE: nan, TTF: 2678
    V: 4.228, I: -0.125, T: 24.69, SoC: 85.06, TTE: nan, TTF: 2671
    V: 4.228, I: -0.125, T: 24.69, SoC: 85.11, TTE: nan, TTF: 2664
    V: 4.223, I: -0.125, T: 24.69, SoC: 85.16, TTE: nan, TTF: 2657
    V: 4.228, I: -0.125, T: 24.69, SoC: 85.21, TTE: nan, TTF: 2650
    V: 4.223, I: -0.125, T: 24.69, SoC: 85.27, TTE: nan, TTF: 2643
    V: 4.228, I: -0.124, T: 24.69, SoC: 85.32, TTE: nan, TTF: 2636
    V: 4.228, I: -0.124, T: 24.69, SoC: 85.37, TTE: nan, TTF: 2628
    V: 4.228, I: -0.124, T: 24.79, SoC: 85.42, TTE: nan, TTF: 2621
    V: 4.228, I: -0.124, T: 24.69, SoC: 85.47, TTE: nan, TTF: 2614
    V: 4.228, I: -0.123, T: 24.69, SoC: 85.52, TTE: nan, TTF: 2607
    V: 4.228, I: -0.123, T: 24.69, SoC: 85.57, TTE: nan, TTF: 2600
    V: 4.228, I: -0.123, T: 24.69, SoC: 85.62, TTE: nan, TTF: 2593
    V: 4.228, I: -0.123, T: 24.69, SoC: 85.67, TTE: nan, TTF: 2586
    V: 4.228, I: -0.123, T: 24.69, SoC: 85.72, TTE: nan, TTF: 2579
    V: 4.228, I: -0.123, T: 24.69, SoC: 85.77, TTE: nan, TTF: 2571
    V: 4.228, I: -0.123, T: 24.69, SoC: 85.82, TTE: nan, TTF: 2564
    V: 4.228, I: -0.122, T: 24.69, SoC: 85.87, TTE: nan, TTF: 2557
    V: 4.228, I: -0.088, T: 24.69, SoC: 92.27, TTE: nan, TTF: 1510
    V: 4.223, I: -0.084, T: 24.69, SoC: 92.31, TTE: nan, TTF: 1504
    V: 4.228, I: -0.084, T: 24.69, SoC: 92.35, TTE: nan, TTF: 1498
    V: 4.228, I: -0.084, T: 24.69, SoC: 92.39, TTE: nan, TTF: 1492
    V: 4.228, I: -0.084, T: 24.69, SoC: 92.42, TTE: nan, TTF: 1486
    V: 4.228, I: -0.084, T: 24.69, SoC: 92.46, TTE: nan, TTF: 1480
    V: 4.228, I: -0.084, T: 24.69, SoC: 92.50, TTE: nan, TTF: 1474
    V: 4.228, I: -0.084, T: 24.69, SoC: 92.54, TTE: nan, TTF: 1468
    V: 4.228, I: -0.083, T: 24.69, SoC: 92.57, TTE: nan, TTF: 1462
    V: 4.228, I: -0.083, T: 24.69, SoC: 92.61, TTE: nan, TTF: 1457
    V: 4.228, I: -0.083, T: 24.69, SoC: 92.65, TTE: nan, TTF: 1451
    V: 4.228, I: -0.083, T: 24.69, SoC: 92.68, TTE: nan, TTF: 1445
    V: 4.228, I: -0.082, T: 24.69, SoC: 92.72, TTE: nan, TTF: 1439
    V: 4.228, I: -0.082, T: 24.69, SoC: 92.76, TTE: nan, TTF: 1433
    V: 4.228, I: -0.083, T: 24.69, SoC: 92.79, TTE: nan, TTF: 1428
    V: 4.228, I: -0.074, T: 24.69, SoC: 94.51, TTE: nan, TTF: 1140
    V: 4.228, I: -0.074, T: 24.69, SoC: 94.54, TTE: nan, TTF: 1134
    V: 4.228, I: -0.074, T: 24.69, SoC: 94.57, TTE: nan, TTF: 1128
    V: 4.228, I: -0.073, T: 24.69, SoC: 94.61, TTE: nan, TTF: 1122
    V: 4.228, I: -0.075, T: 24.69, SoC: 94.64, TTE: nan, TTF: 1116
    V: 4.223, I: -0.074, T: 24.79, SoC: 94.67, TTE: nan, TTF: 1110
    V: 4.228, I: -0.075, T: 24.69, SoC: 94.71, TTE: nan, TTF: 1104
    V: 4.223, I: -0.073, T: 24.69, SoC: 94.74, TTE: nan, TTF: 1098
    V: 4.228, I: -0.073, T: 24.69, SoC: 94.77, TTE: nan, TTF: 1092
    V: 4.228, I: -0.074, T: 24.69, SoC: 94.81, TTE: nan, TTF: 1086
    V: 4.228, I: -0.073, T: 24.69, SoC: 94.84, TTE: nan, TTF: 1080
    V: 4.228, I: -0.073, T: 24.69, SoC: 94.87, TTE: nan, TTF: 1074
    V: 4.228, I: -0.073, T: 24.69, SoC: 94.90, TTE: nan, TTF: 1068
    V: 4.228, I: -0.073, T: 24.69, SoC: 94.94, TTE: nan, TTF: 1063
    V: 4.228, I: -0.073, T: 24.69, SoC: 94.97, TTE: nan, TTF: 1057
    V: 4.228, I: -0.073, T: 24.69, SoC: 95.00, TTE: nan, TTF: 1051
    V: 4.228, I: -0.073, T: 24.69, SoC: 95.04, TTE: nan, TTF: 1045
    V: 4.228, I: -0.073, T: 24.69, SoC: 95.07, TTE: nan, TTF: 1039
    V: 4.228, I: -0.073, T: 24.69, SoC: 95.10, TTE: nan, TTF: 1033
    V: 4.228, I: -0.073, T: 24.69, SoC: 95.13, TTE: nan, TTF: 1027
    V: 4.228, I: -0.073, T: 24.69, SoC: 95.17, TTE: nan, TTF: 1021
    V: 4.228, I: -0.073, T: 24.69, SoC: 95.20, TTE: nan, TTF: 1015
    V: 4.228, I: -0.073, T: 24.69, SoC: 95.23, TTE: nan, TTF: 1009
    V: 4.228, I: -0.073, T: 24.69, SoC: 95.26, TTE: nan, TTF: 1003
    V: 4.228, I: -0.072, T: 24.69, SoC: 95.30, TTE: nan, TTF: 997
    V: 4.228, I: -0.072, T: 24.69, SoC: 95.33, TTE: nan, TTF: 991
    V: 4.228, I: -0.072, T: 24.69, SoC: 95.36, TTE: nan, TTF: 985
    V: 4.228, I: -0.072, T: 24.69, SoC: 95.39, TTE: nan, TTF: 980
    V: 4.228, I: -0.072, T: 24.69, SoC: 95.42, TTE: nan, TTF: 974
    V: 4.228, I: -0.072, T: 24.69, SoC: 95.45, TTE: nan, TTF: 968
    V: 4.228, I: -0.072, T: 24.69, SoC: 95.49, TTE: nan, TTF: 962
    V: 4.228, I: -0.072, T: 24.69, SoC: 95.52, TTE: nan, TTF: 956
    V: 4.228, I: -0.072, T: 24.69, SoC: 95.55, TTE: nan, TTF: 950
    V: 4.228, I: -0.071, T: 24.69, SoC: 95.58, TTE: nan, TTF: 944
    V: 4.228, I: -0.072, T: 24.69, SoC: 95.61, TTE: nan, TTF: 938
    V: 4.228, I: -0.072, T: 24.69, SoC: 95.64, TTE: nan, TTF: 933
    V: 4.228, I: -0.072, T: 24.69, SoC: 95.67, TTE: nan, TTF: 927
    V: 4.228, I: -0.071, T: 24.69, SoC: 95.71, TTE: nan, TTF: 921
    V: 4.228, I: -0.071, T: 24.69, SoC: 95.74, TTE: nan, TTF: 915
    V: 4.228, I: -0.071, T: 24.69, SoC: 95.77, TTE: nan, TTF: 909
    V: 4.228, I: -0.070, T: 24.69, SoC: 95.80, TTE: nan, TTF: 903
    V: 4.228, I: -0.070, T: 24.69, SoC: 95.83, TTE: nan, TTF: 897
    V: 4.228, I: -0.071, T: 24.69, SoC: 95.86, TTE: nan, TTF: 892
    V: 4.228, I: -0.070, T: 24.69, SoC: 95.89, TTE: nan, TTF: 886
    V: 4.228, I: -0.070, T: 24.69, SoC: 95.92, TTE: nan, TTF: 880
    V: 4.228, I: -0.070, T: 24.69, SoC: 95.95, TTE: nan, TTF: 874
    V: 4.228, I: -0.070, T: 24.69, SoC: 95.98, TTE: nan, TTF: 869
    V: 4.228, I: -0.071, T: 24.69, SoC: 96.01, TTE: nan, TTF: 863
    V: 4.228, I: -0.070, T: 24.69, SoC: 96.04, TTE: nan, TTF: 857
    V: 4.228, I: -0.070, T: 24.69, SoC: 96.07, TTE: nan, TTF: 851
    V: 4.228, I: -0.070, T: 24.69, SoC: 96.10, TTE: nan, TTF: 845
    V: 4.223, I: -0.070, T: 24.69, SoC: 96.13, TTE: nan, TTF: 840
    V: 4.223, I: -0.070, T: 24.69, SoC: 96.16, TTE: nan, TTF: 834
    V: 4.228, I: -0.070, T: 24.69, SoC: 96.19, TTE: nan, TTF: 828
    V: 4.228, I: -0.070, T: 24.69, SoC: 96.22, TTE: nan, TTF: 822
    V: 4.228, I: -0.069, T: 24.69, SoC: 96.25, TTE: nan, TTF: 817
    V: 4.228, I: -0.069, T: 24.69, SoC: 96.28, TTE: nan, TTF: 811
    V: 4.228, I: -0.070, T: 24.69, SoC: 96.31, TTE: nan, TTF: 805
    V: 4.228, I: -0.070, T: 24.69, SoC: 96.34, TTE: nan, TTF: 799
    V: 4.228, I: -0.068, T: 24.69, SoC: 96.37, TTE: nan, TTF: 793
    V: 4.228, I: -0.068, T: 24.69, SoC: 96.40, TTE: nan, TTF: 788
    V: 4.228, I: -0.068, T: 24.69, SoC: 96.43, TTE: nan, TTF: 782
    V: 4.228, I: -0.068, T: 24.69, SoC: 96.46, TTE: nan, TTF: 776
    V: 4.228, I: -0.068, T: 24.69, SoC: 96.49, TTE: nan, TTF: 771
    V: 4.228, I: -0.068, T: 24.69, SoC: 96.52, TTE: nan, TTF: 765
    V: 4.228, I: -0.068, T: 24.69, SoC: 96.55, TTE: nan, TTF: 760
    V: 4.228, I: -0.068, T: 24.69, SoC: 96.58, TTE: nan, TTF: 754
    V: 4.228, I: -0.068, T: 24.69, SoC: 96.60, TTE: nan, TTF: 748
    V: 4.228, I: -0.068, T: 24.69, SoC: 96.63, TTE: nan, TTF: 742
    V: 4.228, I: -0.068, T: 24.69, SoC: 96.66, TTE: nan, TTF: 737
    V: 4.228, I: -0.068, T: 24.69, SoC: 96.69, TTE: nan, TTF: 731
    V: 4.228, I: -0.067, T: 24.69, SoC: 96.72, TTE: nan, TTF: 725
    V: 4.228, I: -0.067, T: 24.69, SoC: 96.75, TTE: nan, TTF: 720
    V: 4.228, I: -0.068, T: 24.69, SoC: 96.78, TTE: nan, TTF: 714
    V: 4.228, I: -0.067, T: 24.69, SoC: 96.81, TTE: nan, TTF: 708
    V: 4.223, I: -0.067, T: 24.69, SoC: 96.83, TTE: nan, TTF: 703
    V: 4.228, I: -0.067, T: 24.69, SoC: 96.86, TTE: nan, TTF: 697
    V: 4.228, I: -0.067, T: 24.69, SoC: 96.89, TTE: nan, TTF: 691
    V: 4.228, I: -0.067, T: 24.79, SoC: 96.92, TTE: nan, TTF: 686
    V: 4.228, I: -0.067, T: 24.69, SoC: 96.95, TTE: nan, TTF: 680
    V: 4.228, I: -0.067, T: 24.69, SoC: 96.97, TTE: nan, TTF: 674
    V: 4.228, I: -0.067, T: 24.69, SoC: 97.00, TTE: nan, TTF: 669
    V: 4.228, I: -0.067, T: 24.69, SoC: 97.03, TTE: nan, TTF: 663
    V: 4.223, I: -0.067, T: 24.69, SoC: 97.06, TTE: nan, TTF: 657
    V: 4.228, I: -0.067, T: 24.69, SoC: 97.09, TTE: nan, TTF: 652
    V: 4.228, I: -0.067, T: 24.69, SoC: 97.12, TTE: nan, TTF: 646
    V: 4.228, I: -0.067, T: 24.69, SoC: 97.14, TTE: nan, TTF: 640
    V: 4.228, I: -0.066, T: 24.69, SoC: 97.17, TTE: nan, TTF: 635
    V: 4.228, I: -0.066, T: 24.69, SoC: 97.20, TTE: nan, TTF: 629
    V: 4.228, I: -0.067, T: 24.69, SoC: 97.23, TTE: nan, TTF: 623
    V: 4.228, I: -0.066, T: 24.69, SoC: 97.25, TTE: nan, TTF: 618
    V: 4.228, I: -0.067, T: 24.69, SoC: 97.28, TTE: nan, TTF: 612
    V: 4.228, I: -0.066, T: 24.69, SoC: 97.31, TTE: nan, TTF: 606
    V: 4.228, I: -0.067, T: 24.69, SoC: 97.34, TTE: nan, TTF: 601
    V: 4.228, I: -0.067, T: 24.69, SoC: 97.37, TTE: nan, TTF: 595
    V: 4.228, I: -0.066, T: 24.79, SoC: 97.39, TTE: nan, TTF: 589
    V: 4.228, I: -0.066, T: 24.69, SoC: 97.42, TTE: nan, TTF: 583
    V: 4.228, I: -0.066, T: 24.69, SoC: 97.44, TTE: nan, TTF: 580
    V: 4.228, I: -0.066, T: 24.69, SoC: 97.46, TTE: nan, TTF: 577
    V: 4.228, I: -0.066, T: 24.69, SoC: 97.47, TTE: nan, TTF: 574
    V: 4.228, I: -0.066, T: 24.69, SoC: 97.49, TTE: nan, TTF: 571
    V: 4.228, I: -0.065, T: 24.69, SoC: 97.51, TTE: nan, TTF: 568
    V: 4.228, I: -0.066, T: 24.69, SoC: 97.52, TTE: nan, TTF: 565
    V: 4.228, I: -0.066, T: 24.69, SoC: 97.54, TTE: nan, TTF: 562
    V: 4.228, I: -0.066, T: 24.69, SoC: 97.56, TTE: nan, TTF: 558
    V: 4.228, I: -0.066, T: 24.79, SoC: 97.58, TTE: nan, TTF: 555
    V: 4.228, I: -0.065, T: 24.69, SoC: 97.59, TTE: nan, TTF: 552
    V: 4.228, I: -0.065, T: 24.69, SoC: 97.61, TTE: nan, TTF: 549
    V: 4.228, I: -0.065, T: 24.69, SoC: 97.63, TTE: nan, TTF: 546
    V: 4.228, I: -0.065, T: 24.69, SoC: 97.64, TTE: nan, TTF: 543
    V: 4.228, I: -0.065, T: 24.69, SoC: 97.66, TTE: nan, TTF: 540
    V: 4.228, I: -0.065, T: 24.69, SoC: 97.68, TTE: nan, TTF: 536
    V: 4.228, I: -0.065, T: 24.69, SoC: 97.69, TTE: nan, TTF: 533
    V: 4.228, I: -0.065, T: 24.69, SoC: 97.71, TTE: nan, TTF: 530
    V: 4.228, I: -0.065, T: 24.69, SoC: 97.73, TTE: nan, TTF: 527
    V: 4.228, I: -0.065, T: 24.69, SoC: 97.74, TTE: nan, TTF: 524
    V: 4.223, I: -0.064, T: 24.69, SoC: 97.76, TTE: nan, TTF: 521
    V: 4.228, I: -0.064, T: 24.69, SoC: 97.78, TTE: nan, TTF: 517
    V: 4.228, I: -0.064, T: 24.69, SoC: 97.79, TTE: nan, TTF: 514
    V: 4.228, I: -0.064, T: 24.69, SoC: 97.81, TTE: nan, TTF: 511
    V: 4.228, I: -0.064, T: 24.69, SoC: 97.83, TTE: nan, TTF: 508
    V: 4.228, I: -0.064, T: 24.69, SoC: 97.84, TTE: nan, TTF: 505
    V: 4.228, I: -0.064, T: 24.69, SoC: 97.86, TTE: nan, TTF: 501
    V: 4.228, I: -0.064, T: 24.69, SoC: 97.88, TTE: nan, TTF: 498
    V: 4.228, I: -0.064, T: 24.79, SoC: 97.89, TTE: nan, TTF: 495
    V: 4.228, I: -0.064, T: 24.69, SoC: 97.91, TTE: nan, TTF: 492
    V: 4.228, I: -0.064, T: 24.69, SoC: 97.93, TTE: nan, TTF: 488
    V: 4.228, I: -0.064, T: 24.69, SoC: 97.94, TTE: nan, TTF: 485
    V: 4.228, I: -0.064, T: 24.69, SoC: 97.96, TTE: nan, TTF: 482
    V: 4.228, I: -0.064, T: 24.69, SoC: 97.98, TTE: nan, TTF: 479
    V: 4.228, I: -0.064, T: 24.69, SoC: 97.99, TTE: nan, TTF: 475
    V: 4.228, I: -0.064, T: 24.79, SoC: 98.01, TTE: nan, TTF: 472
    V: 4.228, I: -0.064, T: 24.69, SoC: 98.03, TTE: nan, TTF: 469
    V: 4.228, I: -0.064, T: 24.69, SoC: 98.04, TTE: nan, TTF: 465
    V: 4.228, I: -0.063, T: 24.69, SoC: 98.06, TTE: nan, TTF: 462
    V: 4.228, I: -0.064, T: 24.79, SoC: 98.08, TTE: nan, TTF: 459
    V: 4.228, I: -0.063, T: 24.69, SoC: 98.09, TTE: nan, TTF: 455
    V: 4.228, I: -0.063, T: 24.69, SoC: 98.11, TTE: nan, TTF: 452
    V: 4.228, I: -0.063, T: 24.69, SoC: 98.13, TTE: nan, TTF: 449
    V: 4.228, I: -0.063, T: 24.69, SoC: 98.14, TTE: nan, TTF: 445
    V: 4.228, I: -0.063, T: 24.69, SoC: 98.16, TTE: nan, TTF: 442
    V: 4.228, I: -0.063, T: 24.69, SoC: 98.17, TTE: nan, TTF: 439
    V: 4.228, I: -0.062, T: 24.69, SoC: 98.19, TTE: nan, TTF: 435
    V: 4.228, I: -0.062, T: 24.69, SoC: 98.21, TTE: nan, TTF: 432
    V: 4.228, I: -0.063, T: 24.69, SoC: 98.22, TTE: nan, TTF: 429
    V: 4.228, I: -0.062, T: 24.69, SoC: 98.24, TTE: nan, TTF: 425
    V: 4.228, I: -0.062, T: 24.69, SoC: 98.26, TTE: nan, TTF: 422
    V: 4.228, I: -0.062, T: 24.69, SoC: 98.27, TTE: nan, TTF: 419
    V: 4.223, I: -0.062, T: 24.69, SoC: 98.29, TTE: nan, TTF: 415
    V: 4.228, I: -0.061, T: 24.69, SoC: 98.30, TTE: nan, TTF: 412
    V: 4.228, I: -0.061, T: 24.69, SoC: 98.32, TTE: nan, TTF: 409
    V: 4.228, I: -0.062, T: 24.69, SoC: 98.34, TTE: nan, TTF: 405
    V: 4.228, I: -0.061, T: 24.69, SoC: 98.35, TTE: nan, TTF: 402
    V: 4.228, I: -0.061, T: 24.69, SoC: 98.37, TTE: nan, TTF: 398
    V: 4.228, I: -0.060, T: 24.69, SoC: 98.38, TTE: nan, TTF: 395
    V: 4.228, I: -0.060, T: 24.69, SoC: 98.40, TTE: nan, TTF: 392
    V: 4.228, I: -0.060, T: 24.79, SoC: 98.41, TTE: nan, TTF: 388
    V: 4.228, I: -0.060, T: 24.69, SoC: 98.43, TTE: nan, TTF: 385
    V: 4.228, I: -0.060, T: 24.69, SoC: 98.45, TTE: nan, TTF: 382
    V: 4.228, I: -0.060, T: 24.69, SoC: 98.46, TTE: nan, TTF: 378
    V: 4.228, I: -0.060, T: 24.69, SoC: 98.48, TTE: nan, TTF: 375
    V: 4.228, I: -0.060, T: 24.69, SoC: 98.49, TTE: nan, TTF: 372
    V: 4.228, I: -0.060, T: 24.69, SoC: 98.51, TTE: nan, TTF: 368
    V: 4.228, I: -0.060, T: 24.69, SoC: 98.52, TTE: nan, TTF: 365
    V: 4.228, I: -0.059, T: 24.69, SoC: 98.54, TTE: nan, TTF: 361
    V: 4.228, I: -0.060, T: 24.69, SoC: 98.56, TTE: nan, TTF: 358
    V: 4.228, I: -0.060, T: 24.69, SoC: 98.57, TTE: nan, TTF: 355
    V: 4.228, I: -0.059, T: 24.69, SoC: 98.59, TTE: nan, TTF: 351
    V: 4.228, I: -0.059, T: 24.69, SoC: 98.60, TTE: nan, TTF: 348
    V: 4.228, I: -0.059, T: 24.69, SoC: 98.62, TTE: nan, TTF: 344
    V: 4.228, I: -0.059, T: 24.69, SoC: 98.63, TTE: nan, TTF: 341
    V: 4.228, I: -0.059, T: 24.69, SoC: 98.65, TTE: nan, TTF: 337
    V: 4.228, I: -0.058, T: 24.69, SoC: 98.66, TTE: nan, TTF: 334
    V: 4.228, I: -0.059, T: 24.69, SoC: 98.68, TTE: nan, TTF: 331
    V: 4.228, I: -0.058, T: 24.69, SoC: 98.69, TTE: nan, TTF: 327
    V: 4.228, I: -0.058, T: 24.69, SoC: 98.71, TTE: nan, TTF: 324
    V: 4.228, I: -0.058, T: 24.69, SoC: 98.72, TTE: nan, TTF: 320
    V: 4.228, I: -0.058, T: 24.69, SoC: 98.74, TTE: nan, TTF: 317
    V: 4.228, I: -0.058, T: 24.69, SoC: 98.76, TTE: nan, TTF: 313
    V: 4.228, I: -0.058, T: 24.69, SoC: 98.77, TTE: nan, TTF: 310
    V: 4.228, I: -0.058, T: 24.69, SoC: 98.79, TTE: nan, TTF: 306
    V: 4.228, I: -0.057, T: 24.69, SoC: 98.80, TTE: nan, TTF: 303
    V: 4.228, I: -0.057, T: 24.69, SoC: 98.82, TTE: nan, TTF: 299
    V: 4.228, I: -0.057, T: 24.69, SoC: 98.83, TTE: nan, TTF: 296
    V: 4.228, I: -0.057, T: 24.69, SoC: 98.85, TTE: nan, TTF: 293
    V: 4.228, I: -0.057, T: 24.69, SoC: 98.86, TTE: nan, TTF: 289
    V: 4.228, I: -0.057, T: 24.69, SoC: 98.88, TTE: nan, TTF: 286
    V: 4.228, I: -0.056, T: 24.69, SoC: 98.89, TTE: nan, TTF: 282
    V: 4.228, I: -0.057, T: 24.69, SoC: 98.91, TTE: nan, TTF: 279
    V: 4.228, I: -0.057, T: 24.69, SoC: 98.92, TTE: nan, TTF: 275
    V: 4.228, I: -0.056, T: 24.69, SoC: 98.94, TTE: nan, TTF: 272
    V: 4.228, I: -0.056, T: 24.69, SoC: 98.95, TTE: nan, TTF: 268
    V: 4.228, I: -0.057, T: 24.69, SoC: 98.97, TTE: nan, TTF: 265
    V: 4.228, I: -0.057, T: 24.69, SoC: 98.98, TTE: nan, TTF: 261
    V: 4.228, I: -0.057, T: 24.69, SoC: 99.00, TTE: nan, TTF: 258
    V: 4.228, I: -0.056, T: 24.69, SoC: 99.01, TTE: nan, TTF: 254
    V: 4.228, I: -0.056, T: 24.69, SoC: 99.03, TTE: nan, TTF: 249
    V: 4.228, I: -0.056, T: 24.69, SoC: 99.05, TTE: nan, TTF: 244
    V: 4.223, I: -0.056, T: 24.69, SoC: 99.07, TTE: nan, TTF: 239
    V: 4.228, I: -0.056, T: 24.69, SoC: 99.09, TTE: nan, TTF: 234
    V: 4.228, I: -0.056, T: 24.69, SoC: 99.11, TTE: nan, TTF: 229
    V: 4.228, I: -0.056, T: 24.69, SoC: 99.13, TTE: nan, TTF: 224
    V: 4.228, I: -0.056, T: 24.69, SoC: 99.16, TTE: nan, TTF: 218
    V: 4.228, I: -0.056, T: 24.69, SoC: 99.18, TTE: nan, TTF: 213
    V: 4.228, I: -0.055, T: 24.69, SoC: 99.20, TTE: nan, TTF: 208
    V: 4.228, I: -0.055, T: 24.69, SoC: 99.22, TTE: nan, TTF: 203
    V: 4.228, I: -0.055, T: 24.69, SoC: 99.24, TTE: nan, TTF: 198
    V: 4.228, I: -0.055, T: 24.69, SoC: 99.26, TTE: nan, TTF: 193
    V: 4.228, I: -0.055, T: 24.69, SoC: 99.28, TTE: nan, TTF: 188
    V: 4.228, I: -0.055, T: 24.69, SoC: 99.30, TTE: nan, TTF: 183
    V: 4.228, I: -0.055, T: 24.69, SoC: 99.32, TTE: nan, TTF: 178
    V: 4.228, I: -0.055, T: 24.69, SoC: 99.34, TTE: nan, TTF: 172
    V: 4.228, I: -0.055, T: 24.69, SoC: 99.36, TTE: nan, TTF: 167
    V: 4.228, I: -0.055, T: 24.69, SoC: 99.38, TTE: nan, TTF: 162
    V: 4.223, I: -0.055, T: 24.69, SoC: 99.40, TTE: nan, TTF: 157
    V: 4.228, I: -0.054, T: 24.69, SoC: 99.42, TTE: nan, TTF: 152
    V: 4.228, I: -0.054, T: 24.69, SoC: 99.44, TTE: nan, TTF: 147
    V: 4.228, I: -0.054, T: 24.69, SoC: 99.46, TTE: nan, TTF: 142
    V: 4.228, I: -0.054, T: 24.79, SoC: 99.48, TTE: nan, TTF: 136
    V: 4.228, I: -0.054, T: 24.69, SoC: 99.50, TTE: nan, TTF: 131
    V: 4.228, I: -0.054, T: 24.69, SoC: 99.52, TTE: nan, TTF: 126
    V: 4.228, I: -0.054, T: 24.69, SoC: 99.54, TTE: nan, TTF: 121
    V: 4.228, I: -0.054, T: 24.69, SoC: 99.56, TTE: nan, TTF: 116
    V: 4.228, I: -0.053, T: 24.69, SoC: 99.58, TTE: nan, TTF: 111
    V: 4.228, I: -0.054, T: 24.69, SoC: 99.60, TTE: nan, TTF: 106
    V: 4.228, I: -0.053, T: 24.69, SoC: 99.62, TTE: nan, TTF: 100
    V: 4.228, I: -0.053, T: 24.69, SoC: 99.64, TTE: nan, TTF: 95
    V: 4.228, I: -0.053, T: 24.69, SoC: 99.66, TTE: nan, TTF: 90
    V: 4.228, I: -0.053, T: 24.69, SoC: 99.68, TTE: nan, TTF: 85
    V: 4.228, I: -0.053, T: 24.69, SoC: 99.70, TTE: nan, TTF: 80
    V: 4.228, I: -0.053, T: 24.69, SoC: 99.72, TTE: nan, TTF: 75
    V: 4.228, I: -0.052, T: 24.69, SoC: 99.74, TTE: nan, TTF: 70
    V: 4.228, I: -0.053, T: 24.69, SoC: 99.76, TTE: nan, TTF: 65
    V: 4.228, I: -0.052, T: 24.69, SoC: 99.78, TTE: nan, TTF: 59
    V: 4.228, I: -0.052, T: 24.69, SoC: 99.80, TTE: nan, TTF: 54
    V: 4.228, I: -0.052, T: 24.69, SoC: 99.82, TTE: nan, TTF: 49
    V: 4.228, I: -0.052, T: 24.69, SoC: 99.84, TTE: nan, TTF: 44
    V: 4.228, I: -0.052, T: 24.69, SoC: 99.86, TTE: nan, TTF: 39
    V: 4.223, I: -0.052, T: 24.69, SoC: 99.87, TTE: nan, TTF: 34
    V: 4.228, I: -0.052, T: 24.69, SoC: 99.89, TTE: nan, TTF: 29
    V: 4.228, I: -0.051, T: 24.69, SoC: 99.91, TTE: nan, TTF: 24
    V: 4.228, I: -0.052, T: 24.69, SoC: 99.93, TTE: nan, TTF: 19
    V: 4.228, I: -0.051, T: 24.69, SoC: 99.95, TTE: nan, TTF: 13
    V: 4.228, I: -0.051, T: 24.69, SoC: 99.97, TTE: nan, TTF: 8
    V: 4.228, I: -0.051, T: 24.69, SoC: 99.99, TTE: nan, TTF: 3
    V: 4.228, I: -0.051, T: 24.69, SoC: 100.00, TTE: nan, TTF: 1
    V: 4.228, I: -0.050, T: 24.69, SoC: 100.00, TTE: nan, TTF: 1
    V: 4.223, I: -0.051, T: 24.69, SoC: 100.00, TTE: nan, TTF: 1
    V: 4.223, I: -0.050, T: 24.69, SoC: 100.00, TTE: nan, TTF: 1
    V: 4.228, I: -0.050, T: 24.79, SoC: 100.00, TTE: nan, TTF: 1
    V: 4.228, I: -0.049, T: 24.69, SoC: 100.00, TTE: nan, TTF: 1
    V: 4.228, I: -0.049, T: 24.79, SoC: 100.00, TTE: nan, TTF: 1
    V: 4.223, I: -0.048, T: 24.69, SoC: 100.00, TTE: nan, TTF: 1
    V: 4.228, I: -0.048, T: 24.69, SoC: 100.00, TTE: nan, TTF: 1
    V: 4.228, I: -0.047, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.046, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.046, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.045, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.045, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.044, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.043, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.043, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.042, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.041, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.041, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.040, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.041, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.039, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.039, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.038, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.038, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.037, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.038, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.037, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.036, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.036, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.035, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.034, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.033, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.033, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.034, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.033, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.032, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.031, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.032, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.030, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.030, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.030, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.029, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.029, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.029, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.028, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.027, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.028, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.027, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.027, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.028, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.027, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.026, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.026, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.026, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.025, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.025, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.024, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.218, I: -0.024, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.023, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.023, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.024, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.023, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.022, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.022, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.021, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.021, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.020, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.020, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.020, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.019, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.019, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.018, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.018, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.018, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.017, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.017, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.016, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.016, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.223, I: -0.015, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.016, T: 24.79, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.228, I: -0.015, T: 24.69, SoC: 100.00, TTE: nan, TTF: 0
    V: 4.199, I: 0.000, T: 24.69, SoC: 100.00, TTE: nan, TTF: nan
    V: 4.194, I: 0.000, T: 24.69, SoC: 100.00, TTE: nan, TTF: nan
    But pay attention to the moment when the charge percentage becomes 100% (current is 50 mA ).
    The charging process does not stop because I(BAT) > I(TERM). In my case, the charging current is set to 120mA, so I(TERM) defaults to about 12mA (10% of I(CHG)).  And the actual charging is only turned off after an additional 80 minutes when I(TERM) drops to 15 mA.
    How can I make it so that charging turns off immediately when SoC = 100%?
    I know I can set I(TERM) = 20% of I(CHG), but in that case I still have to wait a fair amount of time for I(BAT) to drop from 50mA to 25mA.
    I'm hoping for your help.
    Thank you.
    How long are these logs for (time)?
    So the Fuel Gauge library says that it "processes battery measurements made by Power Management ICs (PMICs) and provides a state-of-charge (SOC) prediction, along with other metric"
    So it only reads out and does not control the charging.
    The PMIC itself controls the charging, and it has a charge cutoff by its termination voltage.
    Configure this to decide when charging should stop.
