Creating development env for nzrzf5340 error/warning : ️❗︎ nrfjprog couldn't be executed. Please ensure that SEGGER J-Link Software and Documentation Pack and nRF Command Line Tools are both installed.
If you see i'm trying to install toolchain and nrf sdk v2.6.1 via vscode, the installations seems to be successful but at the end of toolchain as well as sdk installation the below
[22:34:51] =========== Toolchain validation report for nRF Connect SDK Toolchain v2.6.1 ===========
Package Using the nRF Connect SDK v2.6.1 at c:\ncs\v2.6.1
️Exclamation️ nrfjprog couldn't be executed. Please ensure that SEGGER J-Link Software and Documentation Pack and nRF Command Line Tools are both installed.
[23:38:08] =========== Toolchain validation report for nRF Connect SDK Toolchain v2.6.1 ===========
FYI: I did install the nRF command line tools prior to the above step
    Could you try installing SEGGER J-Link from here:
     https://www.segger.com/downloads/jlink
    And make sure that the underlined checkbox here is selected ?
    We are currently in discussion with Segger on how to include this "legacy usb drivers" in all future versions of nrf-command-line-tools.
    Håkon
  • I kept having the same error on a Windows 10 machine, even after following the above instructions.
    What fixed it for me was going into "Apps and Features" on Windows and un-installing any older versions of J-Link and the nRF command line tools that existed on my machine (I had some older versions there), and un-installing the most recent versions, then re-installing the most recent versions (again following the above instructions).
    Tommy Schell
  • Thanks! Any idea we should we do with a Mac? there is no option to choose for legacy usb drivers but I am facing a same problem.
    [15:31:55] =========== Toolchain validation report for nRF Connect SDK Toolchain v2.6.1 ===========
     Using the nRF Connect SDK v2.6.1 at /opt/nordic/ncs/v2.6.1
    ️️ nrfjprog couldn't be executed. Please ensure that SEGGER J-Link Software and Documentation Pack and nRF Command Line Tools are both installed.
  • As I was searching for literally hours on this bug, I want to give advice on this point. We should not use `nrfjprog` anymore (see: nRF Command Line Tools - nordicsemi.com).
    `nrfutil` (the currently advised tool: nRF Util - nordicsemi.com) is using some strange paths to search for the JLink-DLLs, which was prompted in the log file to me:
    [2025-04-15T06:15:47.729Z] [18068] WARN - [ProbeLib] [2025-04-15 06:15:47.729760Z] Unable to set up J-Link DLL to get version information: J-Link DLL not found, searched in ["C:\\Users\\PhilippLuchscheiderr\\SEGGER\\JLink_V810e", "C:\\Program Files\\SEGGER\\JLink", "C:\\Program Files (x86)\\SEGGER\\JLink"]
    After I found this piece of information, I just copied the relevant DLLs (JLinkARM.dll and JLink_x64.dll) into one of these paths (currently from the v8.18).
    Any other try I made failed. Adding to PATH (like ChatGPT advised) or setting a settings variable in VSCode.
    @nordic: why is there no proper documentation???
