I want to set the transmitting power of the advertising packet. How can I set the TX power?
I am using nRF Connect SDK 2.5.1 in Visual Studio Code.
Sri
Sri
Hello
I have shared the custom board files and the config files.
Sri
Hi
I looked over and they seems fine to me.
I got a few pointers from a collauge that is worth having a look at
1. The PPK2 may give some spikes when changing level
2. You should zoom in where the adv.evt is and look at the level where is stable
Regards
Runar
I have looked into the adv.evt in the PPK current consumption by zooming in and found three peaks. But all the peaks are above the value mentioned in the datasheet even excluding the peak at the start.
So is there anything I can do to reduce or do you think the PPK is giving the spikes in current consumption?
TIA
The stable current is only high. So I presume DC/DC mode is not activated. So am I missing anything in enabling the DCDC mode?
Sri
Hi
I had a chat with a coworker and showed him the plots. Since your config looks fine, the slope of the current draw may indicate that the matching network/antenna tuning need optimizing.
Regards
Runar
