I want to set the transmitting power of the advertising packet. How can I set the TX power?
I am using nRF Connect SDK 2.5.1 in Visual Studio Code.
Sri
Sri
I have completed the steps told in the document. But still getting multiple current peaks for each advertisement. The power setting in proj.conf is CONFIG_BT_CTLR_TX_PWR_0=y
The expected current consumption is 10.3 mA in normal mode and 4.9mA in DC/DC mode. So anything I am missing? I followed all the steps in the document you shared to create a custom board.
Thank you for sharing the documentation. I have followed it and now in idle it is consuming 1.3 - 1.5uA (Avg). I turned off the serial and other unused peripherals.
The transmission power is still not matching the values given in the datasheet. It is varying. How do i get the 5mA specified in the datasheet?
TIA
Sri
Hi
I would suspect that the DCDC is not enabled. Can you share your custom board files(for vscode) and your config files?
Regards
Runar
PFA the contents of the custom board file and the config file of the project.
File Name: Kconfig
Contents:
# nRF52833 board configuration
config BOARD_ENABLE_DCDC
bool "DCDC Mode"
select SOC_DCDC_NRF52X
default y
depends on BOARD_BEACON_NRF52833
File Name: Kconfig.board
Contents:
# Copyright (c) 2024 Nordic Semiconductor ASA
config BOARD_BEACON_NRF52833
bool "BEACON"
depends on SOC_NRF52833_QIAA
File Name: Kconfig.defconfig
Contents:
if BOARD_BEACON_NRF52833
config BOARD
default "beacon_nrf52833"
config BT_CTLR
default BT
endif
File Name: beacon_nrf52833.dts
Contents:
// Copyright (c) 2024 Nordic Semiconductor ASA
// SPDX-License-Identifier: Apache-2.0
/dts-v1/;
#include <nordic/nrf52833_qiaa.dtsi>
#include "beacon_nrf52833-pinctrl.dtsi"
model = "BEACON";
compatible = "ust,beacon-nrf52833";
chosen {
zephyr,sram = &sram0;
zephyr,flash = &flash0;
zephyr,code-partition = &slot0_partition;
zephyr,console = &uart0 ;
zephyr,shell-uart = &uart0 ;
zephyr,uart-mcumgr = &uart0;
leds {
compatible = "gpio-leds";
LED0: led_0 {
label = "RED LED";
gpios = <&gpio0 13 GPIO_ACTIVE_LOW>;
LED1: led_1 {
label = "GREEN LED";
gpios = <&gpio0 15 GPIO_ACTIVE_LOW>;
LED2: led_2 {
label = "BLUE LED";
gpios = <&gpio0 17 GPIO_ACTIVE_LOW>;
LED3: led_3 {
label = "IR LED";
gpios = <&gpio0 22 GPIO_ACTIVE_LOW>;
buttons {
compatible = "gpio-keys";
btn0: user_btn {
label = "USER BUTTON";
gpios = <&gpio1 4 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
aliases {
led0 = &LED0;
led1 = &LED1;
led2 = &LED2;
sw0 = &btn0;
watchdog0 = &wdt0;
&flash0 {
partitions {
#address-cells = <1>;
#size-cells = <1>;
boot_partition: partition@0 {
label = "mcuboot";
reg = <0x0 0xc000>;
slot0_partition: partition@c000 {
label = "image-0";
reg = <0xc000 0x32000>;
slot1_partition: partition@3e000 {
label = "image-1";
reg = <0x3e000 0x32000>;
scratch_partition: partition@70000 {
label = "image-scratch";
reg = <0x70000 0xa000>;
storage_partition: partition@7a000 {
label = "storage";
reg = <0x7a000 0x6000>;
&uart0 {
status = "okay";
current-speed = <115200>;
pinctrl-0 = <&uart0_default>;
pinctrl-1 = <&uart0_sleep>;
&gpio0 {
status = "okay";
&gpio1 {
status = "okay";
&gpiote {
status = "okay";
&nfct {
status = "disabled";
&acl {
File Name: beacon_nrf52833.yaml
Contents:
identifier: beacon_nrf52833
type: mcu
arch: arm
ram: 128
flash: 512
toolchain:
- zephyr
- gnuarmemb
- xtools
File Name: beacon_nrf52833_defconfig
Contents:
CONFIG_SOC_SERIES_NRF52X=y
CONFIG_SOC_NRF52833_QIAA=y
CONFIG_BOARD_BEACON_NRF52833=y
# Enable MPU
CONFIG_ARM_MPU=y
# Enable hardware stack protection
CONFIG_HW_STACK_PROTECTION=y
# Enable GPIO
CONFIG_GPIO=n
# Enable UART
CONFIG_SERIAL=n
# Enable Console
CONFIG_CONSOLE=n
CONFIG_UART_CONSOLE=n
# Enable Pin Control subsystem
CONFIG_PINCTRL=y
File Name: beacon_nrf52833-pinctrl.dtsi
Contents:
* Copyright (c) 2022 Nordic Semiconductor
&pinctrl {
uart0_default: uart0_default{
group1 {
psels = <NRF_PSEL(UART_TX,0,6)>;
group2 {
psels = <NRF_PSEL(UART_RX,0,8)>;
bias-pull-up;
uart0_sleep: uart0_sleep {
group1 {
psels = <NRF_PSEL(UART_TX, 0, 6)>,
<NRF_PSEL(UART_RX, 0, 8)>;
low-power-enable;
i2c0_default: i2c0_default {
group1 {
psels = <NRF_PSEL(TWIM_SDA, 0, 26)>,
<NRF_PSEL(TWIM_SCL, 0, 12)>;
i2c0_sleep: i2c0_sleep {
group1 {
low-power-enable;
File Name: board.cmake
Contents:
board_runner_args(jlink "--device=nrf52833_xxaa" "--speed=4000")
board_runner_args(pyocd "--target=nrf52833" "--frequency=4000000")
include(${ZEPHYR_BASE}/boards/common/nrfjprog.board.cmake)
include(${ZEPHYR_BASE}/boards/common/jlink.board.cmake)
include(${ZEPHYR_BASE}/boards/common/pyocd.board.cmake)File Name: prj.conf Contents: # Logger module CONFIG_LOG=n # GPIO Library CONFIG_GPIO=n # Include BLE stack in project CONFIG_BT=y # Set device Name CONFIG_BT_DEVICE_NAME="UBC0001" # Increase stack size for the main thread and System Workqueue CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 CONFIG_MAIN_STACK_SIZE=2048 # Set the default Tx Power of BLE # CONFIG_BT_CTLR_TX_PWR_MINUS_20=y # CONFIG_BT_CTLR_TX_PWR_MINUS_16=y # CONFIG_BT_CTLR_TX_PWR_MINUS_12=y # CONFIG_BT_CTLR_TX_PWR_MINUS_8=y # CONFIG_BT_CTLR_TX_PWR_MINUS_4=y CONFIG_BT_CTLR_TX_PWR_0=y # CONFIG_BT_CTLR_TX_PWR_PLUS_4=y # CONFIG_BT_CTLR_TX_PWR_PLUS_8=y ---------------------------------------------------------------------------------------------------------------------------------
