nRF5340DK no debuggers discovered
The nRF5340DK's are not programmable on my pc. I have no issues using nRF52DK and nRF52840DK. I have 3 different nRF5340DK's, they all have the same issue.
When I try nrfjprog --recover, I get the following error:
ERROR: No debuggers were discovered.
Log output:
[2024-Jun-06 16:33:46] [debug] --------------------------------------------------------------------------------
[2024-Jun-06 16:33:46] [debug] C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe --recover --log lognew.txt
[2024-Jun-06 16:33:46] [debug] nrfjprog version 10.24.2 external
[2024-Jun-06 16:33:46] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
[2024-Jun-06 16:33:46] [ info] Library loaded, loading member functions.
[2024-Jun-06 16:33:46] [ info] Member functions succesfully loaded.
[2024-Jun-06 16:33:46] [debug] [ Client] - open
[2024-Jun-06 16:33:46] [debug] [ Client] - start
[2024-Jun-06 16:33:46] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 017612d0-6d04-4423-9ed0-43ab154abb77.
[2024-Jun-06 16:33:46] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2024-Jun-06 16:33:46] [debug] [  JLink] - Logger sink registered in JLink logger
[2024-Jun-06 16:33:46] [debug] [  nRFXX] - open
[2024-Jun-06 16:33:46] [debug] [  nRFXX] - just_check_family
[2024-Jun-06 16:33:46] [debug] [SeggerBackend] - open_dll
[2024-Jun-06 16:33:46] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2024-Jun-06 16:33:46] [trace] [ Client] - Command open executed for 55 milliseconds with result 0
[2024-Jun-06 16:33:46] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink_V796a\JLink_x64.dll.
[2024-Jun-06 16:33:46] [debug] [ Client] - config
[2024-Jun-06 16:33:46] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2024-Jun-06 16:33:46] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2024-Jun-06 16:33:46] [debug] [SeggerBackend] - Set batch mode
[2024-Jun-06 16:33:46] [debug] [SeggerBackend] - dll_version
[2024-Jun-06 16:33:46] [ info] [SeggerBackend] - Segger dll version 7.96.a loaded.
[2024-Jun-06 16:33:46] [trace] [ Worker] - Command open executed for 5 milliseconds with result 0
[2024-Jun-06 16:33:46] [trace] [ Client] - Command config executed for 15 milliseconds with result 0
[2024-Jun-06 16:33:46] [debug] [  nRFXX] - config
[2024-Jun-06 16:33:46] [debug] [ Client] - enum_emu_snr
[2024-Jun-06 16:33:46] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
[2024-Jun-06 16:33:46] [debug] [SeggerBackend] - enum_emu_snr
[2024-Jun-06 16:33:46] [trace] [ Worker] - Command config executed for 14 milliseconds with result 0
[2024-Jun-06 16:33:46] [debug] [  nRFXX] - enum_emu_con_info
[2024-Jun-06 16:33:46] [debug] [SeggerBackend] - is_connected_to_emu
[2024-Jun-06 16:33:46] [debug] [SeggerBackend] - enum_emu_con_info
[2024-Jun-06 16:33:46] [trace] [ Worker] - Command enum_emu_con_info executed for 4 milliseconds with result 0
[2024-Jun-06 16:33:46] [debug] [  nRFXX] - close
[2024-Jun-06 16:33:46] [debug] [SeggerBackend] - close
[2024-Jun-06 16:33:46] [debug] [SeggerBackend] - disconnect_from_emu
[2024-Jun-06 16:33:46] [debug] [SeggerBackend] - Segger Backend closed.
[2024-Jun-06 16:33:46] [debug] [  nRFXX] - nRF family DLL closed
[2024-Jun-06 16:33:46] [trace] [ Worker] - Command close executed for 31 milliseconds with result 0
[2024-Jun-06 16:33:46] [trace] [ Client] - Command close executed for 49 milliseconds with result 0
[2024-Jun-06 16:33:46] [debug] [ Client] - terminate
[2024-Jun-06 16:33:46] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[2024-Jun-06 16:33:46] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2024-Jun-06 16:33:46] [trace] [ Worker] - Executed 5 commands for 54 milliseconds
[2024-Jun-06 16:33:46] [debug] [ Client] - Worker process exited with code: 0
[2024-Jun-06 16:33:46] [debug] [ Client] - Child process terminated with result 0
[2024-Jun-06 16:33:46] [trace] [ Client] - Executed 5 commands for 134 milliseconds
When I try to use the Programmer from the nRF Connect for Desktop, I get the following error:
[PID:3308] [jlink] [NRFJPROG][Client][001050015604] Encountered error -13: Command connect_to_emu_with_snr executed for 15 milliseconds with result -13
[PID:3308] [jlink] [NRFJPROG][Worker][001050015604] Cannot call connect_to_emu_without_snr when there is no emulator connected.
[PID:3308] Error executing operations for 1050015604: [jlink] NO_EMULATOR_CONNECTED, code: Nrfjlink
Reading readback protection status for Application core
Failed to reading readback protection status for application core core. Error: [object Object], message: Batch task protection-get failed, [jlink] NO_EMULATOR_CONNECTED
[PID:3308] Error: Failed with exit code 1. One or more batch tasks failed: - [jlink] NO_EMULATOR_CONNECTED, code: Nrfjlink. Message: Batch task protection-get failed, [jlink] NO_EMULATOR_CONNECTED.
This is the full log output from the Programmer:
2024-06-06T14_38_08.532Z-log.txt
I already reinstalled nRF Connect for Desktop, and Jlink, but it didn't help.
Versions used:
nRF Connect for Desktop : v5.0.0
Programmer: v4.3.0
Jlink: V7.96a
nRF5340DK: 2.0.0
