nrf Connect SDK Issues with west.yml workspaces in VS Code
I am trying to add s2opc to my project. But everytime i try to open the complete Workspace in VSCode, the nrf Connect extension, just does nothing.
How to reproduce. Take the blinky example, make it a git repo, create a west.yml file looking like this:
manifest:
  remotes:
    - name: ncs
      url-base: https://github.com/nrfconnect
  projects:
    - name: nrf
      remote: ncs
      repo-path: sdk-nrf
      revision: v2.7.0
      import: true
    - name: s2opc
      groups:
        - s2opc
      path: deps/modules/lib/s2opc
      revision: master
      url: [email protected]:systerel/S2OPC.git
  self:
    path: app
Now do a west init -m <git clone url>
West update, west zephyr export, pip install all the required requirements etc...
If i now open the app folder or the overarching folder containing the nrf sdk and zephyr, the VSCode extension just spins indefinetly. Sometimes it works, by just opening the app folder, but then it still fails to compile, something that is easily reproducable on the command line.
  • If the SSH connection works but west still fails, then can you retry with more verbose logging?
    To make it faster, remove all projects from the manifest except for s2opc and add -vvvvv after west for good measure.
    For reference, here are the commands I used with a local manifest file.
    west -vvvvv init -l
    west -vvvvv update
  • Currently this has escalated quite a bit.
    I did the following:
    Completely removed VSCode from ubuntu 22.04 WSL, deleted the .vscode-server folder and anything i could find vscode related. And reinstalled vscode did not help.
    deleted the wsl image completely, reinstalled. Removed vscode from windows, deleted the nrf sdk from windows, reinstalled vscode on windows, installed the toolchain and sdk using vscode.
    Open VSCode in wsl install the nrf extension pack.
    The problem is now the extension never finishes loading. I am unable to debug it even, can not even generate support information.
    i reinstalled the prerequisites for ubuntu again. Installed the toolchain, installed the nrf dep package the udev rules.
    Nothing changed.
    The extension is loading, but i can't install the toolchain anymore.
    Right now something in my vscode or nrf installation seems to be broken. Its irrelevant which folder i open or what project is beeing used, i am unable to install the nrf toolchain using vscode. Open for debugging tipps in that regard.
  • I understand that you have an escalated situation, but this follow-up topic is completely different from the original topic of the west.yml, and I have no quick answer to give, so I must ask you to open a new DevZone case for it.  We try to keep each DevZone case focused on one topic only.
  • I think it was probably related, as using that west.yml file was working successfully under windows, where my setup is not working. But i can create a new ticket in regards to the linux issue specifically.
  • My apology. I thought you have issue getting VS Code working with anything at all on Ubuntu 22.04 LTS. I see now that I have misread and also misunderstood whichever information I correctly read.
    While it is still a different topic, I do have a quick answer: The nRF Connect for VS Code extension, as of now, doesn't officially support WSL, so I recommend you to not use the extension for the WSL environment.
    If you need a Linux environment on a Windows machine, and want to use the VS Code extension, please consider a virtual machine.
