nRF52832 custom board only working in debug.
I'm working on a custom board with nrf52832 and I'm running into an issue where the firmware will only run on the custom board in debug. But it works fine in  nrf52DK. For my build configuration I'm using nrf52dk/nrf52832 board. below is my prj.conf
# Copyright (c) 2018 Nordic Semiconductor
CONFIG_NCS_BOOT_BANNER=n
CONFIG_BOOT_BANNER=n
CONFIG_BOOT_DELAY=0
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="IK_MB_LBS"
CONFIG_BT_MAX_CONN=2
# Enable the LBS service
# CONFIG_BT_LBS=y
# CONFIG_BT_LBS_POLL_BUTTON=y
# CONFIG_DK_LIBRARY=y
CONFIG_BOARD_ENABLE_DCDC=n
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
# CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
# CONFIG_GPIO=y
CONFIG_ADC=y
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
CONFIG_FLASH=y
CONFIG_NVS=y
CONFIG_REBOOT=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x4000
CONFIG_SETTINGS_NVS_SECTOR_COUNT=2
CONFIG_I2C=n
CONFIG_SPI=n
CONFIG_WATCHDOG=n
CONFIG_THREAD_STACK_INFO=n
CONFIG_THREAD_CUSTOM_DATA=n
CONFIG_FPU=n
CONFIG_LOG=n
CONFIG_PRINTK=n
CONFIG_NFCT_PINS_AS_GPIOS=y
my overlay file
// To get started, press Ctrl+Space to bring up the completion menu and view the available nodes.
// You can also use the buttons in the sidebar to perform actions on nodes.
// Actions currently available include:
// * Enabling / disabling the node
// * Adding the bus to a bus
// * Removing the node
// * Connecting ADC channels
// For more help, browse the DeviceTree documentation at https://docs.zephyrproject.org/latest/guides/dts/index.html
// You can also visit the nRF DeviceTree extension documentation at https://docs.nordicsemi.com/bundle/nrf-connect-vscode/page/guides/ncs_configure_app.html#devicetree-support-in-the-extension
	gpio_output {
		compatible = "gpio-leds";
		solenoiden: solenoid_en {
			gpios = <&gpio0 25 GPIO_ACTIVE_LOW>;
			label = "solenoid Enable";
		ec200ureset:ec200u_reset{
			gpios = <&gpio0 27 GPIO_ACTIVE_LOW>;
			label = "EC200U reset pin";
		extwatchdog:ext_watchdof{
			gpios = <&gpio0 10 GPIO_ACTIVE_LOW>;
			label = "External watchdog pin";
	buttons{
		button0: button_0 {
			status="disabled";
		button1: button_1 {
			status="disabled";
		button2: button_2 {
			status="disabled";
		button3: button_3 {
			status="disabled";
	leds {
		led0: led_0 {
			status="disabled";
		led1: led_1 {
			status="disabled";
		led2: led_2 {
			status="disabled";
		led3: led_3 {
			status="disabled";
	gpio_input{
		compatible = "gpio-keys";
		doorsense: door_sense_in{
			gpios = <&gpio0 28 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "Door sense pin";
		latchsense: latch_sense_in{
			gpios = <&gpio0 14 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "Latch sense pin";
		ignitionin:ignition_in{
			gpios =<&gpio0 15 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "Ignition in pin";
    zephyr,user {
        io-channels = <&adc 5>,<&adc 6>,<&adc 7>;
&spi2 {
    status="disabled";
/delete-node/ &{/pin-controller/uart0_default/group1/};
/delete-node/ &{/pin-controller/uart0_sleep/group1/};
&uart0_default {
    group1 {
        psels = <NRF_PSEL(UART_TX, 0, 13)>, <NRF_PSEL(UART_RX, 0, 12)>;
&adc {
	#address-cells = <1>;
	#size-cells = <0>;
	status = "okay";
	channel@5 {
		reg = <5>;
		zephyr,gain = "ADC_GAIN_1_4";
		zephyr,reference = "ADC_REF_VDD_1_4";
		zephyr,acquisition-time = <ADC_ACQ_TIME_DEFAULT>;
		zephyr,input-positive = <NRF_SAADC_AIN5>;
		zephyr,resolution = <10>;
	channel@6 {
		reg = <6>;
	channel@7 {
		reg = <7>;
&spi1{
	status="disabled";
&i2c0 {
	status="disabled";
&pwm0 {
	status="disabled";
My schematic
  • Hi Akshay,
    Do any of the Bluetooth samples work? Are you able to see the custom device advertising? If you see the board advertising, it would confirm that the 32MHz crystal is running adequately.
    Have you tested multiple custom boards? Could there be any soldering issue with the 32MHz crystal?
    Would you be able to share the partnumber and/or the datasheet for the 32MHz crystal? I would like to verify that the crystal is within spec. and that the load capacitors for the crystal have been properly selected.
    I checked the schematic against our reference design and I everything looks fine.
    You could try to enable the DC/DC but I am not sure whether that would help.
    CONFIG_BOARD_ENABLE_DCDC=y
  • Hi helsing,
    Yes, I have thoroughly tested the firmware on multiple custom boards, all of which are of the same hardware revision (v3.0.1). Unfortunately, the results are consistently the same — the firmware developed using the nRF Connect SDK (NCS) does not function as expected on these boards.
    Interestingly, the firmware developed using the older NRF5 SDK works perfectly fine on the v3.0.1 boards without any issues. This confirms that there is no inherent hardware problem with this specific revision when using the NRF5 SDK.
    Recently, we developed a new version of the hardware, designated as v4.0.0. This revision incorporates several major changes compared to v3.0.1, but notably, the MCU section remains unchanged. To our surprise, the firmware developed using NCS, which previously failed on v3.0.1, now functions flawlessly on the v4.0.0 boards without any issues.
    This behavior raises questions about what specific factors in the v3.0.1 hardware revision might be causing incompatibilities with the NCS firmware, despite the MCU section being identical in both hardware versions.
  • Hi helsing,
    these are the part numbers;
    GRT1555C1E120JA02D - 12PF capacitor
    FA-128 32.0000MF10Z-AJ3 - 32Mhz crystal.
    We tried flashing the peripheral lbs with and without CONFIG_BOARD_ENABLE_DCDC=y. But it didn't work.
  • Hi Akshay,
    Try replacing the 12pF load capacitors, C3 and C9, with 8pF capacitors.
    Explanation
    If the 32MHz crystal is not working properly, the SoC would only be able to start if configured to use the internally synthesized clock.
    The value of the load capacitors, Ccap, is calculated using
    Ccap = 2*CL – C_pcb – C_pin.
    From the datasheet for Y1 we find that the load capacitance, CL, is 6pF for the HFXO. This gives
    Ccap = 2 * 6pF - 4pF =  8pF,
    where C_pcb + C_pin ≈ 4pF for the HFXO pins.
    You may use that C_pcb + C_pin ≈ 5pF for LFXO pins when calculating the load capacitane for X1, along with the load capacitane, CL, found in the datasheet.
    See General PCB design guidelines for nRF52 series for a note on calculating the load capacitors.
  • Hi helsing,
    Is the old nrf5 sdk using the internal clock?! because all these boards are working when we flash  a firmware developed using nrf5 sdk v17.1.0.
