I'm wondering if someone can review this schematic document for an AoA application using the NRF5340. I'm generally concerned about the power and crystal schema, and that important signals are brought to test points.
Thanks!
Thanks!
I see you have quite a few pins dedicated to AOA here, but only one antenna switch. Can you confirm on how many antennas you're planning on having on your board? I assume this will be the locator device of an AoA application, correct?
As for the schematic review itself, here are my notes:
Simon
The note is incorrect, the HF crystal is indeed 32MHz. Datasheet attached, PN is ECS-320-8-37B-CTN-TR.ECX-1637B.pdf
I see, the crystal looks okay.
