nRF54L AUX-AP access port description and usage
Hi all,
In the PDF version of nRF54L PRELIMINARY DATASHEET v0.8, in chapter
9.1 Debug access port:
in table 65: Access port overview
is listed AUX access port of AHB-AP with AP ID 1.
Figure 160: Debug and trace overview
shows AUX-AP connected to VPR trough AMBIX0 block.
In table 66 in chapter 9.2 Access port protection:
Access port protection overview registers UICR.AUXAPROTECT, TAMPC.PROTECT.­AP[0].­DBGEN
are described as "These registers control the generation of the AHB-AP DBGEN signal,
which controls debug access to the VPR AHB-AP. This is used to provide debug capability for VPR."
But there is no other info where any VPR debugging resides in AUX-AP memory space.
Moreover I didn't find any readable address in AUX-AP.
FLPR/VPR RISC-V coprocessor DM (debug module) registers are exposed @ 0x4004C000 / 0x5004C000 of APP-AP (AP ID 0)  address space as described
in 8.26.1 Registers
What is AUX-AP for? Is possible to use it for RISC-V DM access?
  • The debug diagram in trace and debug chapter in PS is not very accurate,  the AHB-AP (AP0) can also access the VPR registers. The VPR debug registers are memory mapped on APB00, so they can be accessed through either AP0 and AP1. However, the AUX-AP can access only APB00 space on AMBIX0, a shown below:
    The main reason to have AP0 and AP1 (AUX-AP) to debug CM33 and VPR simultaneously using the corresponding APs. So the primary usage for AUX-AP is to use with RISC-V DM access as pointed in the question.
  • Thanks for the reply.
    Could you please go into details about accessing RISC-V DM over AUX-AP?
    I would expect DM registers at RISC-V debug spec conforming addresses of AUX-AP. But there is no access from SWD DAP.
    Datasheet, page 751 reads:
    UICR.AUXAPROTECT,
    TAMPC.PROTECT.AP[0].DBGEN
    and
    UICR and TAMPC are combined to enable or disable the access port protection. The access port is normally
    protected, and is opened when the following conditions are met:
    1. UICR.APPROTECT must be Unprotected.
    2. The corresponding TAMPC.PROTECT register must be written by firmware. See TAMPC signal protector
    for details on the procedure.
    Does it mean that AUX-AP access cannot be enabled by a debugger only without running some code on nRF54L?
  • That is correct. There are protection on both AP0 and AP1. So, in addition to writing non-volatile UICR.AUXPROTECT register, you also need to enable DBGEN signal using TAMPC.PROTECT.AP[0].DBGEN register during runtime (after a reset). The TAMPC registers can be written by the fw running on CM33.
    Both the AP0 and AP1 uses same protection mechanism, however uses different registers.
  • I have the blinky app with egpio sdp overlay loaded. The app calls nrf54l_handle_approtect() which enables NRF_TAMPC->PROTECT.AP[0].DBGEN.CTRL
    Both UICR.AUXAPPROTECT[0].PROTECT0 and PROTECT1 are 0xffffffff thus unprotected.
    I believe that AUX-AP DBGEN signal should be enabled in this device state. However I see no readable memory accessed trough AUX-AP on standard RISC-V DM locations (e.g. 0x44 for .DMSTATUS)
    Where is RISC-V DM mapped on AUX-AP?
    Yes, the signal at TAMPC.PROTECT.AP[0].DBGEN.CTRL register must be set as well (in addition to the UICR PROTECT0/1 state)
    You can find it here:
    https://docs.nordicsemi.com/bundle/ps_nrf54L15/page/vpr.html#ariaid-title14
