The client does not enter sleep mode as expected.
We are using the Nordic Semiconductor nRF7002-DK. In this board, both PS-Poll and No-PS-Poll power-saving modes are working as expected. However, when running in TWT (Target Wake Time) power mode using the following command:-wifi twt setup 0 0 2 2 0 1 1 1 1000 60000, the client does not enter sleep mode as expected. Can you help us to enter the device into sleep mode.
Applications Versions:
  1. nRF connection Desktop v5.2.0
  2. Toolchain Manager v1.6.0
  3. Visual studio cade v2.9.2
  4. Windows 11 pro Platform
  • Hi Naveen,
    Naveen Pyda said:
    As you advised, we made the same changes in ncs/v2.9.2/nrf/samples/wifi/twt/src/main.c
    Naveen Pyda said:
    All files were replaced with the twt.zip files in the path ncs/v2.9.2/nrf/samples/wifi/twt/. After that, we flashed the build using the commands below:
    Please build and test the application I shared (twt.zip), not the sample in the SDK. The only change you need to make is to set the credentials in prj.conf.
    Naveen Pyda said:
    but we are not receiving any logs from the client side. I had previously shared screenshots and logs for this issue.
    Just to make sure I understand correctly, do you not get any logs at all? With the TWT application I attached, you should get logs like this:
    *** Booting nRF Connect SDK v2.9.2-4ab7b98fc76f ***
    *** Using Zephyr OS v3.7.99-aa34a5632971 ***
    [00:00:00.665,954] <inf> net_config: Initializing network
    [00:00:00.665,954] <inf> net_config: Waiting interface 1 (0x20001080) to be up...
    [00:00:00.666,107] <inf> net_config: IPv4 address: 192.168.1.99
    [00:00:00.666,168] <inf> net_config: Running dhcpv4 client...
    [00:00:00.666,412] <inf> twt: Starting nrf7002dk with CPU frequency: 64 MHz
    [00:00:00.668,273] <inf> wifi_supplicant: wpa_supplicant initialized
    [00:00:01.666,534] <inf> twt: Static IP address (overridable): 192.168.1.99/255.255.255.0 -> 192.168.1.1
    [00:00:03.595,886] <inf> wifi_mgmt_ext: Connection requested
    [00:00:03.595,916] <inf> twt: Connection requested
    [00:00:03.595,977] <inf> twt: ==================
    [00:00:03.596,008] <inf> twt: State: SCANNING
    [00:00:03.896,148] <inf> twt: ==================
    [00:00:03.896,179] <inf> twt: State: SCANNING
    [00:00:04.196,350] <inf> twt: ==================
    [00:00:04.196,350] <inf> twt: State: SCANNING
    [00:00:04.496,520] <inf> twt: ==================
    [00:00:04.496,520] <inf> twt: State: SCANNING
    [00:00:04.796,691] <inf> twt: ==================
    [00:00:04.796,722] <inf> twt: State: SCANNING
    [00:00:05.096,862] <inf> twt: ==================
    [00:00:05.096,893] <inf> twt: State: SCANNING
    [00:00:05.397,033] <inf> twt: ==================
    [00:00:05.397,064] <inf> twt: State: SCANNING
    [00:00:05.697,204] <inf> twt: ==================
    [00:00:05.697,235] <inf> twt: State: SCANNING
    [00:00:05.997,375] <inf> twt: ==================
    [00:00:05.997,406] <inf> twt: State: SCANNING
    [00:00:06.297,576] <inf> twt: ==================
    [00:00:06.297,607] <inf> twt: State: SCANNING
    [00:00:06.597,747] <inf> twt: ==================
    [00:00:06.597,778] <inf> twt: State: SCANNING
    [00:00:06.897,918] <inf> twt: ==================
    [00:00:06.897,949] <inf> twt: State: SCANNING
    [00:00:07.198,089] <inf> twt: ==================
    [00:00:07.198,120] <inf> twt: State: SCANNING
    [00:00:07.498,291] <inf> twt: ==================
    [00:00:07.498,321] <inf> twt: State: SCANNING
    [00:00:07.798,461] <inf> twt: ==================
    [00:00:07.798,492] <inf> twt: State: SCANNING
    [00:00:08.098,632] <inf> twt: ==================
    [00:00:08.098,663] <inf> twt: State: SCANNING
    [00:00:08.398,803] <inf> twt: ==================
    [00:00:08.398,834] <inf> twt: State: AUTHENTICATING
    [00:00:08.631,469] <inf> twt: Connected
    [00:00:08.706,115] <inf> twt: ==================
    [00:00:08.706,146] <inf> twt: State: COMPLETED
    [00:00:08.706,176] <inf> twt: Interface Mode: STATION
    [00:00:08.706,207] <inf> twt: Link Mode: WIFI 6 (802.11ax/HE)
    [00:00:08.706,207] <inf> twt: SSID: <SSID>
    [00:00:08.706,237] <inf> twt: BSSID: FC:34:97:0B:F6:DC
    [00:00:08.706,268] <inf> twt: Band: 5GHz
    [00:00:08.706,268] <inf> twt: Channel: 44
    [00:00:08.706,298] <inf> twt: Security: WPA2-PSK
    [00:00:08.706,329] <inf> twt: MFP: Optional
    [00:00:08.706,329] <inf> twt: RSSI: -64
    [00:00:08.706,329] <inf> twt: TWT: Supported
    [00:00:10.706,420] <inf> twt: AP is TWT capable, establishing TWT
    [00:00:10.721,038] <inf> twt: TWT setup requested
    [00:00:10.807,250] <inf> twt: TWT response: TWT accept
    [00:00:10.807,250] <inf> twt: == TWT negotiated parameters ==
    [00:00:10.807,250] <inf> twt: TWT Dialog token: 1
    [00:00:10.807,281] <inf> twt: TWT flow ID: 0
    [00:00:10.807,312] <inf> twt: TWT negotiation type: TWT individual negotiation
    [00:00:10.807,312] <inf> twt: TWT responder: true
    [00:00:10.807,342] <inf> twt: TWT implicit: true
    [00:00:10.807,373] <inf> twt: TWT announce: false
    [00:00:10.807,403] <inf> twt: TWT trigger: false
    [00:00:10.807,403] <inf> twt: TWT wake interval: 65024 us
    [00:00:10.807,403] <inf> twt: TWT interval: 524000 us
    [00:00:10.807,434] <inf> twt: ========================
    [00:00:10.807,556] <inf> twt: TWT sleep state: sleeping
    [00:00:10.911,285] <inf> twt: TWT sleep state: awake
    [00:00:10.976,074] <inf> twt: TWT sleep state: sleeping
    [00:00:11.021,148] <inf> twt: TWT Setup success
    [00:00:11.435,577] <inf> twt: TWT sleep state: awake
    [00:00:11.500,457] <inf> twt: TWT sleep state: sleeping
    [00:00:11.959,838] <inf> twt: TWT sleep state: awake
    [00:00:12.024,871] <inf> twt: TWT sleep state: sleeping
    [00:00:12.484,161] <inf> twt: TWT sleep state: awake
    [00:00:12.549,255] <inf> twt: TWT sleep state: sleeping
    [00:00:13.008,453] <inf> twt: TWT sleep state: awake
    [00:00:13.028,564] <inf> net_dhcpv4: Received: 192.168.32.104
    [00:00:13.028,747] <inf> net_config: IPv4 address: 192.168.32.104
    [00:00:13.028,778] <inf> net_config: Lease time: 36000 seconds
    [00:00:13.028,808] <inf> net_config: Subnet: 255.255.255.0
    [00:00:13.028,839] <inf> net_config: Router: 192.168.32.1
    [00:00:13.028,961] <inf> twt: DHCP IP address: 192.168.32.104
    [00:00:13.077,911] <inf> twt: TWT sleep state: sleeping
    [00:00:13.532,714] <inf> twt: TWT sleep state: awake
    [00:00:13.598,052] <inf> twt: TWT sleep state: sleeping
    [00:00:14.057,037] <inf> twt: TWT sleep state: awake
    [00:00:14.122,467] <inf> twt: TWT sleep state: sleeping
    [00:00:14.581,329] <inf> twt: TWT sleep state: awake
    [00:00:14.646,881] <inf> twt: TWT sleep state: sleeping
    [00:00:15.106,353] <inf> twt: TWT sleep state: awake
    [00:00:15.171,264] <inf> twt: TWT sleep state: sleeping
    [00:00:15.629,882] <inf> twt: TWT sleep state: awake
    [00:00:15.695,648] <inf> twt: TWT sleep state: sleeping
    [00:00:16.154,174] <inf> twt: TWT sleep state: awake
    [00:00:16.220,001] <inf> twt: TWT sleep state: sleeping
    [00:00:16.678,436] <inf> twt: TWT sleep state: awake
    [00:00:16.744,628] <inf> twt: TWT sleep state: sleeping
    [00:00:17.202,697] <inf> twt: TWT sleep state: awake
    [00:00:17.268,737] <inf> twt: TWT sleep state: sleeping
    [00:00:17.726,959] <inf> twt: TWT sleep state: awake
    Naveen Pyda said:
    We have a little bit of confusion about this. Actually, we are connecting the Nordic device through the terminal in VS Code. You can see below attached screenshot.
    My question was related to which sample you built and flashed to your board, not how you connect to the serial port on the device.
    Naveen Pyda said:
    We flashed the build in both the shell and twt paths.
    Are you flashing both the TWT sample and shell sample to the nRF7002 DK? These are two separate samples, and you should only flash one at a time. If you flash one sample first and then the other, the last sample will overwrite the first sample you flashed.
    Naveen Pyda said:
    2.westflash
    Please use this to make sure you erase everything on the device:
    west flash --recover
    Marte
  • Hi Marte,
    First of all, thank you for explaining everything clearly.
    As per your advice, we erased and flashed the new build provided by you in privacy twt.zip. We also added the credentials in prj.conf, but the client is not connecting to the SSID.
    Could you please guide us on how to run the TWT setup command: wifi twt setup 0 0 2 2 0 1 1 1 2000 60000000?
     Please find the attached logs below:
    [00:00:00.271,972] <inf> net_config: Initializing network
    [00:00:00.272,003] <inf> net_config: Waiting interface 1 (0x20001080) to be up...
    [00:00:00.272,155] <inf> net_config: IPv4 address: 192.168.1.99
    [00:00:00.272,216] <inf> net_config: Running dhcpv4 client...
    [00:00:00.272,460] <inf> twt: Starting nrf7002dk with CPU frequency: 64 MHz
    [00:00:00.274,291] <inf> wifi_supplicant: wpa_supplicant initialized
    [00:00:00.277,221] <err> wifi_nrf: nrf_wifi_wpa_supp_set_key: rpu_ctx_zep is NULL
    [00:00:00.277,252] <err> wifi_nrf: nrf_wifi_wpa_supp_set_key: rpu_ctx_zep is NULL
    [00:00:00.277,282] <err> wifi_nrf: nrf_wifi_wpa_supp_set_key: rpu_ctx_zep is NULL
    [00:00:00.277,313] <err> wifi_nrf: nrf_wifi_wpa_supp_set_key: rpu_ctx_zep is NULL
    [00:00:00.277,343] <err> wifi_nrf: nrf_wifi_wpa_supp_set_key: rpu_ctx_zep is NULL
    [00:00:01.272,583] <inf> twt: Static IP address (overridable): 192.168.1.99/255.255.255.0 -> 192.168.1.1
    [00:00:03.191,375] <err> wifi_nrf: nrf_wifi_wpa_supp_scan2: RPU context not initialized
    [00:00:03.192,871] <err> wifi_nrf: nrf_wifi_wpa_supp_scan2: RPU context not initialized
    [00:00:03.193,145] <inf> wifi_mgmt_ext: Connection requested
    [00:00:03.193,176] <inf> twt: Connection requested
    [00:00:03.193,237] <inf> twt: ==================
    [00:00:03.193,267] <inf> twt: State: DISCONNECTED
    [00:00:03.493,408] <inf> twt: ==================
    [00:00:03.493,438] <inf> twt: State: DISCONNECTED
    [00:00:03.793,579] <inf> twt: ==================
    [00:00:03.793,579] <inf> twt: State: DISCONNECTED
    [00:00:04.093,750] <inf> twt: ==================
    [00:00:04.093,750] <inf> twt: State: DISCONNECTED
    [00:00:04.193,603] <err> wifi_nrf: nrf_wifi_wpa_supp_scan2: RPU context not initialized
    [00:00:04.393,920] <inf> twt: ==================
    [00:00:04.393,951] <inf> twt: State: DISCONNECTED
    [00:00:04.694,122] <inf> twt: ==================
    [00:00:04.694,152] <inf> twt: State: DISCONNECTED
    [00:00:04.994,293] <inf> twt: ==================
    [00:00:04.994,293] <inf> twt: State: DISCONNECTED
    [00:00:05.194,305] <err> wifi_nrf: nrf_wifi_wpa_supp_scan2: RPU context not initialized
    [00:00:05.294,464] <inf> twt: ==================
    [00:00:05.294,494] <inf> twt: State: DISCONNECTED
    [00:00:05.594,635] <inf> twt: ==================
    [00:00:05.594,635] <inf> twt: State: DISCONNECTED
    [00:00:05.894,836] <inf> twt: ==================
    [00:00:05.894,866] <inf> twt: State: DISCONNECTED
    [00:00:06.195,068] <err> wifi_nrf: nrf_wifi_wpa_supp_scan2: RPU context not initialized
    [00:00:06.195,343] <inf> twt: ==================
    [00:00:06.195,343] <inf> twt: State: DISCONNECTED
    [00:00:06.495,513] <inf> twt: ==================
    [00:00:06.495,513] <inf> twt: State: DISCONNECTED
    [00:00:06.795,684] <inf> twt: ==================
    [00:00:06.795,684] <inf> twt: State: DISCONNECTED
    [00:00:07.095,886] <inf> twt: ==================
    [00:00:07.095,916] <inf> twt: State: DISCONNECTED
    Thanks & Regards,
    Naveen P
  • Hi Naveen
    Did you set the credentials by changing these configs to the SSID and password for your network?
    CONFIG_WIFI_CREDENTIALS_STATIC_SSID="MySSID"
    CONFIG_WIFI_CREDENTIALS_STATIC_PASSWORD="MyPassword"
    What kind of security does the network use? In prj.conf, in the sample I shared, I set CONFIG_WIFI_CREDENTIALS_STATIC_TYPE_PSK, which is used if a network uses a password and PSK security, which is the most standard. If your network uses something else, you need to change this config to match your network's configuration. Here you can see the different config options for this:
    • CONFIG_WIFI_CREDENTIALS_STATIC_TYPE_OPEN - Wi-Fi network uses no password.
    • CONFIG_WIFI_CREDENTIALS_STATIC_TYPE_PSK - Wi-Fi network uses a password and PSK security (default).
    • CONFIG_WIFI_CREDENTIALS_STATIC_TYPE_PSK_SHA256 - Wi-Fi network uses a password and PSK-256 security.
    • CONFIG_WIFI_CREDENTIALS_STATIC_TYPE_SAE - Wi-Fi network uses a password and SAE security.
    You do not need to run this command in the sample I shared, as the sample sets up TWT in the code itself:
    static int setup_twt(void)
    	struct net_if *iface = net_if_get_first_wifi();
    	struct wifi_twt_params params = { 0 };
    	int ret;
    	twt_flow_id = 1;
    	params.operation = WIFI_TWT_SETUP;
    	params.negotiation_type = WIFI_TWT_INDIVIDUAL;
    	params.setup_cmd = WIFI_TWT_SETUP_CMD_REQUEST;
    	params.dialog_token = 1;
    	params.flow_id = twt_flow_id;
    	params.setup.responder = 0;
    	params.setup.trigger = IS_ENABLED(CONFIG_TWT_TRIGGER_ENABLE);
    	params.setup.implicit = 1;
    	params.setup.announce = IS_ENABLED(CONFIG_TWT_ANNOUNCED_MODE);
    	params.setup.twt_wake_interval = CONFIG_TWT_WAKE_INTERVAL;
    	params.setup.twt_interval = CONFIG_TWT_INTERVAL;
    	ret = net_mgmt(NET_REQUEST_WIFI_TWT, iface, &params, sizeof(params));
    	if (ret) {
    		LOG_INF("TWT setup failed: %d", ret);
    		return ret;
    	LOG_INF("TWT setup requested");
    	return 0;
    When the device connects to the network, it will send a request to enable TWT on its own.
    Marte
  • Hi Marte,
    Fullscreen
    1
    2
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    Now the client is connected to the SSID and working as expected, but we want to run ping traffic on this client.
     Please find the attached logs below for your reference:
    [00:00:00.486,999] <inf> net_config: Initializing network
    [00:00:00.486,999] <inf> net_config: Waiting interface 1 (0x20001080) to be up...
    [00:00:00.487,182] <inf> net_config: IPv4 address: 192.168.1.99
    [00:00:00.487,213] <inf> net_config: Running dhcpv4 client...
    [00:00:00.487,457] <inf> twt: Starting nrf7002dk with CPU frequency: 64 MHz
    [00:00:00.489,349] <inf> wifi_supplicant: wpa_supplicant initialized
    [00:00:01.487,579] <inf> twt: Static IP address (overridable): 192.168.1.99/255.255.255.0 -> 192.168.1.1
    [00:00:03.419,860] <inf> wifi_mgmt_ext: Connection requested
    [00:00:03.419,891] <inf> twt: Connection requested
    [00:00:03.419,952] <inf> twt: ==================
    [00:00:03.419,982] <inf> twt: State: SCANNING
    [00:00:03.720,123] <inf> twt: ==================
    [00:00:03.720,153] <inf> twt: State: SCANNING
    [00:00:04.020,324] <inf> twt: ==================
    [00:00:04.020,355] <inf> twt: State: SCANNING
    [00:00:04.320,495] <inf> twt: ==================
    [00:00:04.320,495] <inf> twt: State: SCANNING
    [00:00:04.620,666] <inf> twt: ==================
    [00:00:07.322,296] <inf> twt: State: AUTHENTICATING
    [00:00:07.622,436] <inf> twt: ==================
    [00:00:07.622,467] <inf> twt: State: AUTHENTICATING
    [00:00:07.940,948] <inf> twt: ==================
    [00:00:07.940,979] <inf> twt: State: ASSOCIATED
    [00:00:07.941,009] <inf> twt: Interface Mode: STATION
    [00:00:07.941,009] <inf> twt: Link Mode: WIFI 6 (802.11ax/HE)
    [00:00:07.941,040] <inf> twt: SSID: TWT
    [00:00:07.941,070] <inf> twt: BSSID: 00:33:58:AB:81:82
    [00:00:07.941,101] <inf> twt: Band: 5GHz
    [00:00:07.941,101] <inf> twt: Channel: 64
    [00:00:07.941,131] <inf> twt: Security: WPA2-PSK
    [00:00:07.941,131] <inf> twt: MFP: Optional
    [00:00:07.941,162] <inf> twt: RSSI: -56
    [00:00:07.941,162] <inf> twt: TWT: Supported
    [00:00:07.994,842] <inf> twt: Connected
    [00:00:08.248,474] <inf> twt: ==================
    [00:00:08.248,504] <inf> twt: State: COMPLETED
    [00:00:08.248,535] <inf> twt: Interface Mode: STATION
    [00:00:08.248,565] <inf> twt: Link Mode: WIFI 6 (802.11ax/HE)
    [00:00:08.248,596] <inf> twt: SSID: TWT
    [00:00:08.248,626] <inf> twt: BSSID: 00:33:58:AB:81:82
    [00:00:08.248,626] <inf> twt: Band: 5GHz
    [00:00:08.248,657] <inf> twt: Channel: 64
    [00:00:08.248,657] <inf> twt: Security: WPA2-PSK
    [00:00:08.248,687] <inf> twt: MFP: Optional
    [00:00:08.248,687] <inf> twt: RSSI: -55
    [00:00:08.248,718] <inf> twt: TWT: Supported
    [00:00:09.273,620] <inf> net_dhcpv4: Received: 172.40.9.251
    [00:00:09.273,803] <inf> net_config: IPv4 address: 172.40.9.251
    [00:00:09.273,803] <inf> net_config: Lease time: 600 seconds
    [00:00:09.273,864] <inf> net_config: Subnet: 255.255.240.0
    [00:00:09.273,895] <inf> net_config: Router: 172.40.0.1
    [00:00:09.273,986] <inf> twt: DHCP IP address: 172.40.9.251
    [00:00:10.248,779] <inf> twt: AP is TWT capable, establishing TWT
    [00:00:10.256,622] <inf> twt: TWT setup requested
    [00:00:10.282,958] <inf> twt: TWT response: TWT accept
    [00:00:10.282,958] <inf> twt: == TWT negotiated parameters ==
    [00:00:10.282,989] <inf> twt: TWT Dialog token: 1
    [00:00:10.282,989] <inf> twt: TWT flow ID: 1
    [00:00:10.283,020] <inf> twt: TWT negotiation type: TWT individual negotiation
    [00:00:10.283,020] <inf> twt: TWT responder: true
    [00:00:10.283,050] <inf> twt: TWT implicit: true
    [00:00:10.283,081] <inf> twt: TWT announce: false
    [00:00:10.283,111] <inf> twt: TWT trigger: false
    [00:00:10.283,111] <inf> twt: TWT wake interval: 65024 us
    [00:00:10.283,111] <inf> twt: TWT interval: 524000 us
    [00:00:10.283,111] <inf> twt: ========================
    [00:00:10.283,264] <inf> twt: TWT sleep state: sleeping
    [00:00:10.412,811] <inf> twt: TWT sleep state: awake
    [00:00:10.477,783] <inf> twt: TWT sleep state: sleeping
    [00:00:10.556,701] <inf> twt: TWT Setup success
    [00:00:10.937,164] <inf> twt: TWT sleep state: awake
    [00:00:11.002,258] <inf> twt: TWT sleep state: sleeping
    [00:00:11.461,486] <inf> twt: TWT sleep state: awake
    [00:00:11.526,672] <inf> twt: TWT sleep state: sleeping
    [00:00:11.985,809] <inf> twt: TWT sleep state: awake
    [00:00:12.051,086] <inf> twt: TWT sleep state: sleeping
    Thanks & Regards,
    Naveen P
  • Hi Marte,
    And we want to run iperf or zperf.
