How to assign UART to different pins
If I understand correctly, you can pretty much assign any pin to any peripheral. I've been using a modded central uart project on a dev board but on this other board I'm using, I don't have access to the same pins. I think the pins are assigned in the dtsi file as follows:
&pinctrl {
uart0_default: uart0_default {
group1 {
psels = <NRF_PSEL(UART_TX, 0, 6)>,
<NRF_PSEL(UART_RTS, 0, 5)>;
group2 {
psels = <NRF_PSEL(UART_RX, 0, 8)>,
<NRF_PSEL(UART_CTS, 0, 7)>;
bias-pull-up;
Looks right as I am connected to P0.06 and P0.08 for the UART.
On the one hand you'd think, yeah, just mod this, but this is in
the ncs/zephyr directory so I'm assuming you don't want to mod this.
Again as far as I understand (but might not be right) you need to have some sort of other overlay file?
Is that right? If so (well, even if not), how exactly do you do this
and what exactly what I put in whatever place I need it? What if I needed to us, say P0.09
and P0.10?
Thanks.
    FYI, I just looked through some of the warnings, such as this one:
    This snippet:
    	get_mac_addr(read_mac_addr);
    	if ((SCAN_FOR_NAME == scan_type) || (true == check_blank_addr(read_mac_addr)))
    		err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_NAME, DEVICE_NAME);
    		filter_type = SCAN_FOR_NAME;
    		new_pairing = true;
    	else if (SCAN_FOR_ADDR == scan_type)
    		addr.type = BT_ADDR_LE_RANDOM;
    		for (i=0; i<BT_ADDR_LE_STR_LEN; i++)
    			addr.a.val[i] = read_mac_addr[i];
    		err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_ADDR, &addr);
    		filter_type = SCAN_FOR_ADDR;
    BT_ADDR_LE_STR_LEN = 30, and the add.a.val[i] ony have 6 elements, so you risk corrupting your RAM when writing outside the initial 6 elements in the array. You should definitiely look into this. Use "i < BT_ADDR_SIZE" instead of "BT_ADDR_LE_STR_LEN".
    Please see the attached projec.t I modified the app.overlay, added the sleep configuration for the UART, and also added the "&uicr", which is needed to be able to use the NFC pins as normal GPIOs.
    I also added a small function (test_overlay_function()) in main.c, just to check that everything is working.
    Note that if you are testing on a DK, the NFC pins (P0.09 and P0.10) is not routed out to the pin header without moving some 0R resistors. That should be fine if you have a custom board.
    5086.ccust_uart.zip
    Edvin
  • Many thanks, will read through more thoroughly it and give it a go.
    In the meantime, after a quick scan, one question: what is the situation with the input pin on P0 29 please? There doesn't seem to be anything for the issue where it was claiming:
    message": "identifier \"__device_dts_ord_DT_N_ALIAS_sel_sw_pin_P_gpios_IDX_0_PH_ORD\" is undefined",
    Thanks again.
  • Oh, sorry. I just went with what I saw in the app.overlay.
    The idea is that you copy the parts that you want to change from the board files, paste it in your app.overlay, and change it in the app.overlay.
    I added it in the app.overlay of this project (as well as some minor, non important changes in my test_overlay_function() in main.c):
    ccust_uart2.zip
    Edvin
    Sorry to be slow, but I can't see how this new part of the overlay file, ie this:
     buttons
     compatible = "gpio-keys";
     button0: button_0
     gpios = <&gpio0 29 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
     label = "Push button switch 0";
     zephyr,code = <INPUT_KEY_0>;
    Is then used to enable me to read the pin.
    Previously, when I took the original dts file and used sw0 I could just do this:
    #define SWITCH_NODE DT_ALIAS(sw0)
    static const struct gpio_dt_spec user_switch = GPIO_DT_SPEC_GET(SWITCH_NODE, gpios)
    gpio_pin_configure_dt(&user_switch, GPIO_INPUT);
    pin_value = gpio_pin_get_dt(&user_switch);
    And pin value would change when the switch was pressed or not.
    So how does the new bit of code map to being able to read the pin? You've introduced this new [to me]
    zephyr,code = <INPUT_KEY_0>;zephyr,code = <INPUT_KEY_0>;
    And called it button0
    I've tried this:
    #define SWITCH_NODE DT_ALIAS(button0)
    And this
    #define SWITCH_NODE DT_ALIAS(button_0)
    But I get the same old error telling me
        "resource": "/home/robertw/ncs/v2.8.0/zephyr/include/zephyr/devicetree.h",
        "owner": "cpptools",
        "severity": 8,
        "message": "'DT_N_ALIAS_button0_P_gpios_IDX_0_VAL_pin' undeclared here (not in a function); did you mean 'DT_N_S_buttons_S_button_0_P_gpios_IDX_0_VAL_pin'?",
        "source": "gcc",
        "startLineNumber": 240,
        "startColumn": 32,
        "endLineNumber": 240,
        "endColumn": 32
  • I just verified that it worked with the blinking pattern of your 3 LEDs. They blinked faster when P0.29 was connected to GND when I reset the device. So what I did was to redefine button0, as you can see in the app.overlay. If you look in your main.c, you can see that you fetch the switch:
    static const struct gpio_dt_spec user_switch = GPIO_DT_SPEC_GET(SWITCH_NODE, gpios);
    using sw0. sw0 is fetched from the aliases list in nrf52840dk_nrf52840.dts:
    You can see the ones that are "greyed out" in this list, those are the ones that are redefined in app.overlay. This also means that you technically still have led3 (although it is not being used in your application. The same goes for sw1-3 that are defined but not used.
    The reason sw0 is not grey is that it is still mapped to button0, but button0 is redefined, so if you scroll up in that same file, you will see that the definition of button0 is greyed out.
    Edvin
