Memfault OTA for multiple nRF boards (NCS 3.1.1)
Im currently in the process of integrating Memfault OTA on the nRF9151 DK. My project has multiple boards: nRF9151 DK connects with nRF52840 DK via UART for communication. For OTA, I figured that I can use memfault OTA to update the nRF9151 DK because it supports out of the box. However, I'm not sure how to approach for nRF52840 DK. I know that since 2 boards connect using UART, I can put it into DFU mode and just do a serial recovery. From Memfault doc:
Or the doc recommends to bundle the update into 1 OTA:
Since the nRF9151 DK has external flash, it has enough storage for this approach as well. But memfault guide http://mflt.io/nrf-fota-setup said to just call memfault_fota_start to start the OTA process. That works great for the nRF9151 DK, but what about the nRF52840 board I have connected? The document doesn't mention this very clear on how I could do the "get" and "push" for downstream board, or how I can do the "bundle" approach.
Even if I don't consider the nRF52840 DK, I still need to update both the app and the modem fw on the nRF9151 DK. Which function/API should I override? Or is there already an implementation? The only function I can override is the memfault_fota_download_callback, but this is called after everything is done. I just want to check if the payload is supposed to be for the nRF52840 DK board and save it in a different partition instead?
I'd appreciate the help. Thanks so much.
  • Thank you. I took a look at those. I was able to move past the warning.
    But when init, I encountered a SECURE FAULT because I'm sharing 1 serial line.
    I tried to use 2 UART lines this time.
    UART2 from nRF91 -> UART1 on nRF52 for normal communication.
    UART1 from nRF91 -> UART0 on nRF52 for SMP, respectively.
    When the check for OTA is available, and the dfu_target_smp tried to send an echo command to the nRF52, it failed. With hardware control lines connected, it just stuck waiting for the flow control lines to be asserted. I disabled it to check, and I was right, the echo command time out and failed.
    I verified that the nRF52 is actually in serial recovery because I have the LED1 enabled when it's in serial recovery.
    To verify that this is a uart issue, I also try to swap the UART1 and UART0 connection, so now UART2 -> UART0 on the nRF52 DK, and indeed the commands that normally works for UART1 now receives no response on UART0.
    Here is the overlay (I put these in both the boards and in mcuboot sysbuild):
        /* Tell Zephyr the retention region is used for boot-mode */
        chosen {
            /delete-property/ zephyr,shell-uart;
            /delete-property/ zephyr,bt-mon-uart;
            /delete-property/ zephyr,bt-c2h-uart;
            zephyr,boot-mode = &retention0;
            zephyr,uart-mcumgr = &uart0;
        /* Retention region for boot mode */
        sram@2003FC00 {
    		compatible = "zephyr,memory-region", "mmio-sram";
    		reg = <0x2003FC00 DT_SIZE_K(1)>;
    		zephyr,memory-region = "RetainedMem";
    		status = "okay";
    		retainedmem {
    			compatible = "zephyr,retained-ram";
    			status = "okay";
    			#address-cells = <1>;
    			#size-cells = <1>;
    			retention0: boot_mode@0 {
    				compatible = "zephyr,retention";
    				status = "okay";
    				reg = <0x0 0x100>;
    				prefix = [08 04];
    				checksum = <1>;
    &gpio0 {
            status = "okay";
    &gpio1 {
            status = "okay";
    &gpiote0 {
            status = "okay";
    &nrf_radio_fem_spi {
        status = "disabled";
    &pinctrl {
        uart0_default_custom: uart0_default_custom {
            group1 {
                psels = <NRF_PSEL(UART_TX, 1, 2)>,
                    <NRF_PSEL(UART_RTS, 1, 1)>;
            group2 {
                psels = <NRF_PSEL(UART_RX, 1, 4)>,
                    <NRF_PSEL(UART_CTS, 1, 3)>;
                bias-pull-up;
        uart0_sleep_custom: uart0_sleep_custom {
            group1 {
                    <NRF_PSEL(UART_RTS, 1, 1)>,
                low-power-enable;
        uart1_default_custom: uart1_default_custom {
            group1 {
                psels = <NRF_PSEL(UART_TX, 0, 29)>,
                    <NRF_PSEL(UART_RTS, 0, 28)>;
            group2 {
                psels = <NRF_PSEL(UART_RX, 0, 31)>,
                    <NRF_PSEL(UART_CTS, 0, 30)>;
                bias-pull-up;
        uart1_sleep_custom: uart1_sleep_custom {
            group1 {
                    <NRF_PSEL(UART_RTS, 0, 28)>,
                low-power-enable;
    &uart0 {
        status = "okay";
        current-speed = <115200>;
        pinctrl-0 = <&uart0_default_custom>;
        pinctrl-1 = <&uart0_sleep_custom>;
    &uart1 {
        status = "okay";
        hw-flow-control;
        pinctrl-0 = <&uart1_default_custom>;
        pinctrl-1 = <&uart1_sleep_custom>;
    /* Reduce SRAM0 usage to account for non-init area */
    &sram0 {
        reg = <0x20000000 DT_SIZE_K(255)>;
    I don't really know what I should do to make it work. I also attempted to cut solder bridge 50, 51, 52, 53 that connects UART0 to VCOM0, and it also doesn't work...
    I even change between ASYNC using DMA and Interrupt and none of it work. UART1 is working fine though. But not UART0 no matter what I did.
    CONFIG_UART_0_ASYNC=n
    CONFIG_UART_0_INTERRUPT_DRIVEN=y
    I ran out of option and don't really know what to do.
  •   An update:
    The actual culprit is the UART1 port on the nRF9151. I found this thread with a related issue but for an nRF9160 DK and I was able to resolve the issue.
    To be transparent, after my hopeless attempt at enable UART1 and UART3 to work on the nRF9151, I gave up and just assigned `zephyr,uart-mcumgr` to uart0, swapped the console to uart3, and it worked.
    For me, uart1 makes sense because it was owned by secure domain. But uart3 just didn't work and I didn't know why, even with and without hardware control lines, it doesn't output anything although I enabled it with pins in the overlay.
    Here is my current working overlay for anyone who has the same issue as mine in the future:
    	chosen {
            zephyr,console = &uart3;
            zephyr,shell-uart = &uart3;
    &gpio0 {
    		status = "okay";
    &gpiote {
    		status = "okay";
    &pinctrl {
    	uart2_default_custom: uart2_default_custom {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 0, 19)>,
    				<NRF_PSEL(UART_RTS, 0, 18)>;
    		group2 {
    			psels = <NRF_PSEL(UART_RX, 0, 17)>,
    				<NRF_PSEL(UART_CTS, 0, 16)>;
    			bias-pull-up;
    	uart2_sleep_custom: uart2_sleep_custom {
    		group1 {
    				<NRF_PSEL(UART_RTS, 0, 18)>,
    			low-power-enable;
    	uart3_default_custom: uart3_default_custom {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 0, 3)>,
    				<NRF_PSEL(UART_RX, 0, 31)>;
    	uart3_sleep_custom: uart3_sleep_custom {
    		group1 {
    &i2c3 {
    &i2c2 {
    &spi3 {
    &pwm0 {
    &pwm1 {
    &pwm2 {
    &pwm3 {
    &uart2 {
    	status = "okay";
    	hw-flow-control;
    	pinctrl-0 = <&uart2_default_custom>;
    	pinctrl-1 = <&uart2_sleep_custom>;
    &uart3 {
    	status = "okay";
    	pinctrl-0 = <&uart3_default_custom>;
    	pinctrl-1 = <&uart3_sleep_custom>;
    &uart0 {
    	status = "okay";
    	hw-flow-control;
    Of course this makes the log unavailable. Using RTT log with an onboard debugger somehow took control of the uart0 port (although I disabled vcom0 in the board configurator), so I had to use an external JLink probe.
    Anyway, I was able to get SMP to write update to my other device now.
    But at the end of the update, I encountered an error
    <err> mcumgr_grp_img_client: Missing mandatory parametrs
    from this line, I tried to add more debug prints, as shown below:
    LOG_ERR("hash len %d, img mgmt data sha len %d version len %d slot found %d",
    hash.len, IMG_MGMT_DATA_SHA_LEN, version.len,
    zcbor_map_decode_bulk_key_found(list_res_decode,
    ARRAY_SIZE(list_res_decode),
    "slot"));
    <dbg> mcumgr_grp_img_client: hash len 0 != img mgmt data sha len 32, version len 5 slot found 1
    Is this concerning that the hash len = 0? I rebooted the device and seems like it works fine. So I'm unsure if I'm missing any steps in generating the image or if there's anything that I need to look into.
    I have this config enabled, not sure if it has anything to do with this:
    CONFIG_BOOT_SERIAL_IMG_GRP_HASH=y
    Any idea would be appreciated. Thank you for your patience with me.
  • Hello, just the final update. I tried to follow this thread to get hash working, but some reason the read back hash always has len = 0, although I use mcuboot imgtool.py to check for the hash info (and it is there with len = 32 - SHA256).
    I decided to switch nRF52 to running SMP server with dual slots because I felt like having it as single slot is quite risky for remote deployment.
    I was able to get the OTA bundle working with Memfault! Thank you so much  for your recommendation and resources. Much appreciated!
  • Hi  -
    I'm glad to hear it- that was my suggestion, to use `imgtool` to check the binary file. Dual slots is a good idea for resiliency (you will need the fallback logic, i.e. the `boot_write_img_confirmed()` API should be called only when the running image is confirmed to be OK, i.e. some time after system fully boots).
    Example `imgtool` output for reference, but not so useful now that you are up and running! Excellent work, it is not the simplest thing to implement! Let us know if you have any other questions.
    Noah
    ❯ imgtool dumpinfo app.signed.bin
    Printing content of signed image: app.signed.bin
    #### Image header (offset: 0x0) ############################
    magic:              0x96f3b83d
    load_addr:          0x0
    hdr_size:           0x200
    protected_tlv_size: 0x0
    img_size:           0x8ded4
    flags:              0x0
    version:            2.0.1+0
    #### Payload (offset: 0x200) ###############################
    |              FW image (size: 0x8ded4 Bytes)              |
    #### TLV area (offset: 0x8e0d4) ############################
    magic:     0x6907
    area size: 0x98
            type: SHA256 (0x10)
            len:  0x20
            data: 0x0e 0x82 0xb3 0x0c 0xb9 0xa8 0x2b 0xc8
                  0x85 0x39 0x98 0x9a 0xdd 0x75 0x9c 0x20
                  0x3e 0x9d 0xe6 0xb2 0x6b 0x3d 0xd8 0xb6
                  0x1f 0x8b 0xc3 0xf4 0x37 0x73 0x80 0xfc
            type: KEYHASH (0x1)
            len:  0x20
            data: 0xe3 0x04 0x66 0xf6 0xb8 0x47 0x0c 0x1f
                  0x29 0x07 0x0b 0x17 0xf1 0xe2 0xd3 0xe9
                  0x4d 0x44 0x5e 0x3f 0x60 0x80 0x87 0xfd
                  0xc7 0x11 0xe4 0x38 0x2b 0xb5 0x38 0xb6
            type: ECDSASIG (0x22)
            len:  0x48
            data: 0x30 0x46 0x02 0x21 0x00 0xe3 0x23 0x9a
                  0xed 0xd5 0x0b 0xcf 0xfb 0x39 0x52 0xe1
                  0x61 0x2a 0x9a 0x6e 0xd8 0xf4 0x6e 0xe1
                  0x0d 0x96 0xa7 0xe8 0x87 0xbe 0x42 0xf9
                  0x5e 0x6b 0x58 0xb2 0x84 0x02 0x21 0x00
                  0xce 0xd1 0xf5 0x2a 0xf6 0xf7 0x78 0xb1
                  0x87 0x4f 0x3d 0xb2 0x38 0x61 0xcf 0xc0
                  0xd0 0x8e 0x7a 0x8b 0x37 0x1c 0xd6 0x0f
                  0x43 0x07 0x4f 0xf2 0x9b 0xc6 0xa5 0xdb
    #### End of Image ##########################################
    dumpinfo has run successfully
