NRF54L15 setting pin 2.07 as UART TX does not work
I am on a custom NRF54L15 module where I want to change the default UART TX pin from P1.04 to P2.07. Unfortunately, there is no output. Using P1.14 somehow works?
I also have MCU Boot enabled when I connect my wires to pin P1.04 I see the MCU Boot logs, but not the one from my main app - as expected because they should be printed to P2.07 but thats not working as said ...
My overlay:
    zephyr,user {
        //epd_test_gpios = <&gpio0 17 GPIO_ACTIVE_LOW>; // NOT WORKING
        led_builtin_gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>;
        io-channels = <&adc 0>, <&adc 1>;
        epd_busy_gpios = <&gpio0 20 GPIO_ACTIVE_LOW>;
        epd_res_gpios = <&gpio0 22 GPIO_ACTIVE_LOW>;
        epd_dc_gpios = <&gpio0 24 GPIO_ACTIVE_LOW>;
        epd_cs_gpios = <&gpio1 00 GPIO_ACTIVE_LOW>;
        // epd_spi_clk_gpios = <&gpio1 6 GPIO_ACTIVE_LOW>;
        // epd_spi_mosi_gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; // SDI
    aliases {
        /delete-property/ sw3;
        /delete-property/ led3;
        /delete-property/ sw2;
        /delete-property/ sw1;
        /delete-property/ sw0;
/delete-node/ &button3;
/delete-node/ &{/buttons/};
/delete-node/ &led3;
&led1 {
    gpios = <&gpio1 6 0>;
&led2 {
    gpios = <&gpio1 5 0>;
&cpuapp_rram {
    reg = <0x0 DT_SIZE_K(1524)>;
&cpuapp_sram {//! Without this the only 188Kb of RAM is available
    reg = <0x20000000 DT_SIZE_K(256)>;
    ranges = <0x0 0x20000000 DT_SIZE_K(256)>;
&adc {
    #address-cells = <1>;
    #size-cells = <0>;
    channel@0 {
        reg = <0>;
        zephyr,gain = "ADC_GAIN_1_6";
        zephyr,reference = "ADC_REF_VDD_1";
        zephyr,acquisition-time = <0>;
        zephyr,input-positive = <NRF_SAADC_AIN2>; /* P1.06 */
        zephyr,resolution = <10>;
&spi00_default {
    group1 {
        psels = <NRF_PSEL(SPIM_SCK, 2, 6)>, <NRF_PSEL(SPIM_MOSI, 0, 10)>;           // (SPIM_MOSI, 1, 6)    // (SPIM_MOSI, 1, 11)
&spi00_sleep {
    group1 {
        psels = <NRF_PSEL(SPIM_SCK, 1, 11)>,
&pinctrl {
    uart20_default: uart20_default {
        group1 {
            psels = <NRF_PSEL(UART_TX, 2, 7)>,
                    <NRF_PSEL(UART_RTS, 2, 8)>;
        group2 {
            psels = <NRF_PSEL(UART_RX, 2, 9)>,
                    <NRF_PSEL(UART_CTS, 2, 10)>;
            bias-pull-up;
    uart20_sleep: uart20_sleep {
        group1 {
            psels =
                <NRF_PSEL(UART_RTS, 2, 8)>,
            low-power-enable;
&uart20 {
    status = "okay";
    current-speed = <115200>;
    pinctrl-0 = <&uart20_default>;
    pinctrl-1 = <&uart20_sleep>;
/delete-node/ &boot_partition;
/delete-node/ &slot0_partition;
/delete-node/ &slot1_partition;
    partitions {
        #size-cells = <1>;
        boot_partition: partition@0 {
            label = "mcuboot";
            reg = <0x00000 0x0C000>;
        pad_partition: partition@c000 {
            label = "mcuboot_pad";
            reg = <0x0C000 0x200>;
        slot0_partition: partition@c200 {
            label = "mcuboot_primary";
            reg = <0x0C200 0x40000>;
        slot1_partition: partition@4c200 {
            label = "mcuboot_secondary";
            reg = <0x4C200 0x40000>;
        nvs_partition: partition@8c200 {
            label = "nvs_storage";
            reg = <0x8C200 0x6BE00>;
Thanks
