nRF9151 Low Power Mode.
I am using the nRF9151 DK, using the Serial LTE Modem firmware from the nRF Connect quick start.
I am planning to use nRF9151 as a serial modem, and connect it to my Host MCU using UART.
I am using the Power Profile II to measure the current of VDD_nRF.
Questions:
  1. Is this the product code that I should be using for my final product?
  2. Power save mode:
    1. I set the modem LPM. The average current is about 500uA in LPM. Why is it still so high? What is nRF9151 drawing current for? Is it because nRF9151 UART is still enabled?
    2. I press button 1 on the DK, the average current went down to 3uA.
    3. I press button 1 again, it seems to wake the nRF9151 up, with average current about 500uA again, but I lost all network configurations.
    4. Questions:
      1. What does button 1 do exactly? Any documents that describe exactly what it does?
      2. What is the proper way to go into deep power save mode, assuming I am using this Serial LTE Modem firmware in my final product?
      3. Is there a even lower power mode that the button 1 method? i.e. average current < 1uA maybe?
  3. There are some instances, when I leave the DK alone for maybe 10 mins, then I tried to send a AT command, the DK is not responsive in the sense it did not send back "OK" or network messages. However, my AT command was executed (based on the current profile of the Power Profiler II). Is this a know issue? Below image shows this error. In the image, bottom right, a few AT commands are sent but there were not response received.
  • Hi Simon,
    "This .hex file was compiled for the nRF9151 DK. Here is some more information about the UART configuration for the Serial modem add-on.".
    The UART pin configuration shown in the link is different from the schematic of the DK. Can it still work?
    I did went through lesson 2. It did not mention anything related to AT# commands. I know where to find these commands on the Nordic website but some AT# commands is able to run (eg AT#XCLAC), some can't (eg AT#XSLEEP), and can only be recognized before enabling the radio (AT#XCLAC). Once radio is enabled with AT+FUNC=1, this AT#XCLAC command cannot be recognized anymore. I can't find any documentation on this.
    'Oh, good catch! The documentation is wrong here, it has most likely been copied from the nRF9161 or the nRF9160, which both have the "ENABLE" pin on pin 101. For the nRF9151, It is indeed pin 10 on the chip that has to be used.'
    Is there any way to access the enable pin? Can find any connection from the enable pin to any connectors. What does the red X in the DK schematic on the enable pin represent?
    Alex.
  • Hi Alex,
    You are correct again... The pins in the documentation are wrong! The right ones are the ones you see on the datasheet (UART1). However, only the documentation is wrong. The firmware is configured to use the right pins.
    Honestly, it is a bit strange that we didn't catch that earlier. Sorry for the wrong documentation.
    The AT commands with # are custom AT command that are interpreted by the application. They are implemented by the Serial Modem Add-on. You cannot use them in any other firmware.
    For the AT#XCALC, I was able to use it fine... Can you please share some logs? Here are my logs:
    Ready
    > AT+CFUN?
    +CFUN: 0
    OK
    > AT#XCLAC
    ATE0
    ATE1
    AT#XAPOLL
    AT#XBIND
    AT#XCLAC
    AT#XCLOSE
    AT#XCONNECT
    AT#XDATACTRL
    AT#XDFUAPPLY
    AT#XDFUINIT
    AT#XDFUWRITE
    AT#XFOTA
    AT#XGETADDRINFO
    AT#XGNSS
    AT#XGNSSDEL
    AT#XMODEMRESET
    AT#XMQTTCFG
    AT#XMQTTCON
    AT#XMQTTPUB
    AT#XMQTTSUB
    AT#XMQTTUNSUB
    AT#XNRFCLOUD
    AT#XNRFCLOUDPOS
    AT#XPING
    AT#XRECV
    AT#XRECVCFG
    AT#XRECVFROM
    AT#XRESET
    AT#XSEND
    AT#XSENDTO
    AT#XSHUTDOWN
    AT#XSLEEP
    AT#XSMS
    AT#XSMVER
    AT#XSOCKET
    AT#XSOCKETOPT
    AT#XSSOCKET
    AT#XSSOCKETOPT
    AT#XUUID
    OK
    > AT+CFUN=1
    OK
    > AT#XCLAC
    ATE0
    ATE1
    AT#XAPOLL
    AT#XBIND
    AT#XCLAC
    AT#XCLOSE
    AT#XCONNECT
    AT#XDATACTRL
    AT#XDFUAPPLY
    AT#XDFUINIT
    AT#XDFUWRITE
    AT#XFOTA
    AT#XGETADDRINFO
    AT#XGNSS
    AT#XGNSSDEL
    AT#XMODEMRESET
    AT#XMQTTCFG
    AT#XMQTTCON
    AT#XMQTTPUB
    AT#XMQTTSUB
    AT#XMQTTUNSUB
    AT#XNRFCLOUD
    AT#XNRFCLOUDPOS
    AT#XPING
    AT#XRECV
    AT#XRECVCFG
    AT#XRECVFROM
    AT#XRESET
    AT#XSEND
    AT#XSENDTO
    AT#XSHUTDOWN
    AT#XSLEEP
    AT#XSMS
    AT#XSMVER
    AT#XSOCKET
    AT#XSOCKETOPT
    AT#XSSOCKET
    AT#XSSOCKETOPT
    AT#XUUID
    OK
    > AT+CFUN=0
    OK
    > AT#XCLAC
    ATE0
    ATE1
    AT#XAPOLL
    AT#XBIND
    AT#XCLAC
    AT#XCLOSE
    AT#XCONNECT
    AT#XDATACTRL
    AT#XDFUAPPLY
    AT#XDFUINIT
    AT#XDFUWRITE
    AT#XFOTA
    AT#XGETADDRINFO
    AT#XGNSS
    AT#XGNSSDEL
    AT#XMODEMRESET
    AT#XMQTTCFG
    AT#XMQTTCON
    AT#XMQTTPUB
    AT#XMQTTSUB
    AT#XMQTTUNSUB
    AT#XNRFCLOUD
    AT#XNRFCLOUDPOS
    AT#XPING
    AT#XRECV
    AT#XRECVCFG
    AT#XRECVFROM
    AT#XRESET
    AT#XSEND
    AT#XSENDTO
    AT#XSHUTDOWN
    AT#XSLEEP
    AT#XSMS
    AT#XSMVER
    AT#XSOCKET
    AT#XSOCKETOPT
    AT#XSSOCKET
    AT#XSSOCKETOPT
    AT#XUUID
    OK
    There is no good way to have access to the ENABLE pin in the nRF9151DK, unfortunately.
    The red X in the schematic is just a warning from Altium. (As the ENABLE pin is set as an input pin, it detects that no output pin have been connected to it and make a warning.) It can be completely ignored in that scenario.
    Simon D-M
  • Hi SImon,
    Thanks again for your replies. How can I generate the box of the log like you did?
    Some follow up and additional clarifications.
    Some how after I tried to program the serial_modem_v0.3.0_nrf9151dk_ext_mcu.hex" firmware and then back to the nRF Connect AT command firmware, it works. Anyway I see some difference in the log.
    > AT#XCLAC
    AT#XACCEPT
    AT#XBIND
    AT#XCLAC
    AT#XCONNECT
    AT#XDATACTRL
    AT#XFOTA
    AT#XFTP
    AT#XGETADDRINFO
    AT#XGPIO
    AT#XGPIOCFG
    AT#XGPS
    AT#XGPSDEL
    AT#XHTTPCCON
    AT#XHTTPCREQ
    AT#XLISTEN
    AT#XMODEMRESET
    AT#XMQTTCFG
    AT#XMQTTCON
    AT#XMQTTPUB
    AT#XMQTTSUB
    AT#XMQTTUNSUB
    AT#XNRFCLOUD
    AT#XNRFCLOUDPOS
    AT#XPING
    AT#XPOLL
    AT#XRECV
    AT#XRECVFROM
    AT#XRESET
    AT#XSEND
    AT#XSENDTO
    AT#XSHUTDOWN
    AT#XSLEEP
    AT#XSLMVER
    AT#XSMS
    AT#XSOCKET
    AT#XSOCKETOPT
    AT#XSOCKETSELECT
    AT#XSSOCKET
    AT#XSSOCKETOPT
    AT#XTCPCLI
    AT#XTCPHANGUP
    AT#XTCPSEND
    AT#XTCPSVR
    AT#XTFTP
    AT#XUDPCLI
    AT#XUDPSEND
    AT#XUDPSVR
    AT#XUUID
    OK
    Did you generate this list from the DK? What is the application hex you used?
    'You are correct again... The pins in the documentation are wrong! The right ones are the ones you see on the datasheet (UART1). However, only the documentation is wrong. The firmware is configured to use the right pins.'
    Alex: By datasheet do you mean the DK schematic? There is no datasheet for the DK and I don't think the hardware guide show which pins are used.
    'You can also download the modem firmware on the nRF9151 product page, in the "Download" section.'
    Alex: This link points to "mfw_nrf91x1_2.0.4" which is modem firmware ver 2.0.4.
    'If you want to update the modem core, you can follow this guide.'
    Alex: This link points to the update guide as well as a link to download firmware for the DK (nRF9151 DK Downloads) with an older ver 2.0.2. I assume I should ignore the firmware in this link correct?
    And the PTCRB cert indicates "mfw_nrf91x1_2.0.2". ver 2.04 is not certified by PTCRB yet. Shoudn't I be using ver 2.0.2? Is ver 2.0.4 currently under approval process?
    Also, the AT Command file "nrf91x1_cellular_at_commands_v1.4" indicates only update to modem firmware ver 2.0.3. Are the AT commands still applicable for ver 2.0.4?
    Also, I want to revisit the Application MCU firmware of the nRF9151DF again. In nRF Connect for Desktop, I ran quick start, under "select an application to run", I choose "AT commands". What exactly is the MCU firmware used? I read somewhere there AT command mode is not Serial Modem Mode? AT command mode is sending AT command directly to the Modem Firmware (AT command pass thru mode), and AT# commands are not supported? While Serial Modem mode, the AT commands are sent to the MCU firmware, which can interpret AT# commands. Is this correct? This is quick confusing. Is there anywhere that describe the different behavior and maybe dataflow or block diagram between PC/external MCU, nRF9151 MCU firmware, and nRF9151 modem?
    So again, I just to talk to nRF9151 as a whole, using AT commands. Which mode should I use for my final product without the need to modify the nRF9151 firmware, be it the MCU app firmware or the modem firmware. Should it be the AT command "pass thru" firmware or the Serial Modem firmware?
    By the way, I programmed "serial_modem_v0.3.0_nrf9151dk_ext_mcu.hex" into the DK using 'erase and write', I encountered error. I retried again and it was successful. See below log:
    2026-01-31T03:44:48.427Z INFO Recovering Application core
    2026-01-31T03:44:48.428Z INFO Recovering Application core 0%
    2026-01-31T03:44:48.499Z INFO Recovering Application core 50%
    2026-01-31T03:44:49.736Z INFO Recovering Application core 100%
    2026-01-31T03:44:49.736Z INFO Recovering Application core completed
    2026-01-31T03:44:49.736Z INFO Loading core information for Application core
    2026-01-31T03:44:49.738Z INFO Update files regions according to Application core
    2026-01-31T03:44:49.738Z INFO Parse memory regions for file
    2026-01-31T03:44:49.740Z INFO Loading core information for Application core 0%
    2026-01-31T03:44:49.740Z INFO Loading core information for Application core 100%
    2026-01-31T03:44:49.741Z INFO Loading core information for Application core completed
    2026-01-31T03:44:49.742Z INFO Update files regions according to Application core
    2026-01-31T03:44:49.742Z INFO Parse memory regions for file
    2026-01-31T03:44:50.263Z INFO Writing HEX to Application core
    2026-01-31T03:44:50.264Z INFO Writing HEX to Application core 0%
    2026-01-31T03:44:50.364Z INFO Writing HEX to Application core 33%
    2026-01-31T03:44:50.485Z INFO Writing HEX to Application core 33%
    2026-01-31T03:44:50.797Z INFO Writing HEX to Application core 67%
    2026-01-31T03:44:52.886Z ERROR Failed "writing hex to application core". Error: code: 1, description: Generic, message: Batch task program failed, Device error: NVMC Failed to write to NVMC.CONFIGNS: failed: Failed to read from memory address 0x50003100: Failed to write DebugPort register 0x08: Unknown error in the J-Link DLL (error code =-1797082992)
    2026-01-31T03:45:36.199Z INFO Recovering Application core
    2026-01-31T03:45:36.200Z INFO Recovering Application core 0%
    2026-01-31T03:45:36.264Z INFO Recovering Application core 50%
    2026-01-31T03:45:37.487Z INFO Recovering Application core 100%
    2026-01-31T03:45:37.488Z INFO Recovering Application core completed
    2026-01-31T03:45:37.488Z INFO Loading core information for Application core
    2026-01-31T03:45:37.488Z INFO Loading core information for Application core 0%
    2026-01-31T03:45:37.489Z INFO Update files regions according to Application core
    2026-01-31T03:45:37.489Z INFO Parse memory regions for file
    2026-01-31T03:45:37.491Z INFO Loading core information for Application core 100%
    2026-01-31T03:45:37.491Z INFO Loading core information for Application core completed
    2026-01-31T03:45:37.492Z INFO Update files regions according to Application core
    2026-01-31T03:45:37.492Z INFO Parse memory regions for file
    2026-01-31T03:45:37.900Z INFO Writing HEX to Application core
    2026-01-31T03:45:37.900Z INFO Writing HEX to Application core 0%
    2026-01-31T03:45:37.965Z INFO Writing HEX to Application core 33%
    2026-01-31T03:45:38.033Z INFO Writing HEX to Application core 33%
    2026-01-31T03:45:38.322Z INFO Writing HEX to Application core 67%
    2026-01-31T03:45:40.333Z INFO Writing HEX to Application core 83%
    2026-01-31T03:45:40.333Z INFO Writing HEX to Application core 100%
    2026-01-31T03:45:40.338Z INFO Writing HEX to Application core completed
    2026-01-31T03:45:41.006Z INFO Reading readback protection status for Application core
    2026-01-31T03:45:41.007Z INFO Reading readback protection status for Application core 0%
    2026-01-31T03:45:41.072Z INFO Reading readback protection status for Application core 50%
    2026-01-31T03:45:41.073Z INFO Reading readback protection status for Application core 50%
    2026-01-31T03:45:41.074Z INFO Reading readback protection status for Application core 100%
    2026-01-31T03:45:41.074Z INFO Application core protection status 'NRFDL_PROTECTION_STATUS_NONE'
    2026-01-31T03:45:41.075Z INFO Reading readback protection status for Application core completed
    I reset the DK, there were no initial messages which I were there when I use the AT command settings from the nRF Connect, and sending "AT", there is no response.
    I use the nRF Connect to download the AT commands firmware and it works again. So it seems like the UART pin definition on the schematic is not the same as the "serial_modem_v0.3.0_nrf9151dk_ext_mcu.hex" firmware?
    Also, I assume that firmware for EXT MCU can also be used on the DK using the Debug IC (i.e connecting the DK to PC using the USB cable and sending commands through the PC serial terminal)?
  • average current is about 500uA
    This is usually caused by the UART receiver. To reduce it down to 3-6µA you need to suspend the UART and wake it up, when you need it again. That wake up is the frequently done/implemented by some GPIO. There are also some implementations, which using the RX for that, but it depends on your requirements.
    I will just program whatever production-certified modem firmware and application firmware without any recompilation,
    The term "certified" may mean a lot of different things. Let me recommend, that you first clarify, what it should mean. Otherwise you will risk a very big disappointment in the end ;-).
  • Hi Alex,
    To do the quote box, just select the part that you what to quote and click on "Quote". To do the code text box, click on "Insert" at the bottom of the text box and "</> Code".
    I'm not sure, I might have compiled it by myself. But it is based on the latest Serial Modem add-on. So should be the same as serial_modem_v0.3.0_nrf9151dk_ppp_cmux.hex.
    Yes, sorry for the confusion.
    You can choose which modem firmware version you want to download. (from mfw2.0.0 to mfw2.0.4).
    If you use the firmware in here, yes, you should use the mfw 2.0.2. Yes, if you need the PTCRB for now, you have to go with the mfw 2.0.2. I cannot communicate about what certification the mfw 2.0.4 will have. But even if you use everything pre-certified from our side. You will, most likely, still need to redo the PTCRB certification as said here :
    "When a module is integrated into an end product, the module’s RF performance may change, which impacts the end device’s performance. Therefore, even devices that already use a PTCRB-certified module still need their own PTCRB certification."
    It is written in the changelog of each modem firmware, which AT command version the modem firmware is aligned with. (link).
    The firmware in the Quick start Application is the Serial LTE Modem, not the AT client.
    (What I'm going to tell you is not 100% accurate, but it is a good way to visualize what is happening.) Basically, you can imagine that all the UART message (AT commands received) are first going through the Application core and if nothing has been done with it, it is transmitted to the Modem core. And the difference between the AT client sample and the Serial modem application is that in the AT client sample, there is almost no logic inside the application core. But for the Serial Modem application, there is some logic inside to support some custom AT commands.
    Here is the block diagram for the nRF9151 if you want to see how it really is inside the chip.
    Honestly, you should really consider modifying, even a tiny bit, the firmware you'll be using. Either way, I would recommend using the Serial modem application, as it has more capabilities and has power management integrated and both of them are "pass-thru".
    I don't think so, you have to use the UART specified in the external MCU overlay file (also documented here).
    As a side note, I would really recommend you to try asking question to our AI chatbot (blue circle, bottom right) as it would have been able to answer a lot of you questions. It has been trained specifically on our documentation, so it works quite well for these type of questions.
    Simon D-M
