Logging via SWO
I am trying to configure SWO logging in a sample project based on zephyr/samples/hello_world (source and config at the end).
I run this application on two targets: nRF54L15-DK and nRF52-DK.
On nRF54L15-DK: I cannot see any logs when using SEGGER J-Link SWO Viewer but I can see the logs via cortex-debug extension for vscode.
On nRF52-DK: I can see logs when using SEGGER J-Link SWO Viewer but I cannot see any logs via cortex-debug extension for vscode.
Do you know why it works that way?
Another question is about the SWO frequency. In case of nRF54L15-DK and vscode I need to configure the SWO receiver to half of the frequency configured in the application. In case of nRF52-DK and SEGGER J-Link SWO Viewer I can choose whatever frequency I want.
How to properly set the SWO frequency for nRF54L15?
Application code:
#include <zephyr/kernel.h>
	while (1) {
		printk("Hello World! %s\n", CONFIG_BOARD_TARGET);
		k_msleep(1000);
	return 0;
prj.conf file:
CONFIG_LOG=y
CONFIG_LOG_MODE_MINIMAL=n
CONFIG_LOG_MODE_IMMEDIATE=y
CONFIG_LOG_BACKEND_SWO=y
CONFIG_LOG_BACKEND_SWO_FREQ_HZ=2000000
launch.json file for vscode:
    "version": "0.2.0",
    "configurations": [
            "name": "hello nrf54",
            "cwd": "${workspaceFolder}",
            "executable": "${workspaceFolder}/build/merged.hex",
            "symbolFiles": [
                "${workspaceFolder}/build/hello_world/zephyr/zephyr.elf",
            "request": "launch",
            "type": "cortex-debug",
            "runToEntryPoint": "main",
            "servertype": "jlink",
            "device": "NRF54L15_M33",
            "interface": "swd",
            "showDevDebugOutput": "raw",
            "swoConfig": {
                "enabled": true,
                "source": "probe",
                "swoFrequency": 1000000,
                "cpuFrequency": 128000000,
                "decoders": [
                        "port": 0,
                        "type": "console",
                        "label": "hello",
                        "encoding":"ascii"
            "ipAddress": "192.168.100.20:19020",
            "name": "hello nrf52",
            "symbolFiles": [
            "device": "NRF52832_xxAA",
            "interface": "swd",
            "swoConfig": {
                "enabled": true,
                "source": "probe",
                "cpuFrequency": 64000000,
                "decoders": [
                        "port": 0,
                        "type": "console",
                        "label": "hello",
                        "encoding":"ascii"
Cheers,
Damian
  • Hi Marte,
    The debugger I use is SEGGER J-Link Base.
    The reason behind using SWO is that in our project we would like to have two builds: release and test. Release one uses SWO log backend but the application does not enable SWO. It can be enabled and set up by the attached debugger when needed.
    Test build which is used for measuring power consumption. Here the enables SWO by itself. No debugger is attached, only one wire to the SWO pin to gather the logs.
    I have an update regarding the logs in SEGGER J-Link SWO Viewer, I can get the logs, I just had to power cycle the target device. So after the reboot the logs are received. Setting `CONFIG_LOG_BACKEND_SWO=y` was enough. My apologies, it was my mistake.
    Nevertheless, the logs look corrupted. When running the simple application (from the code snippet above) every couple of lines of logs the ending of the line is incorrect.
    *** Booting nRF Connect SDK v3.2.1-d8887f6f32df ***
    *** Using Zephyr OS v4.2.99-ec78104f1569 ***
    Hello World! hcm200/nrf54l10/app
    Hello World! hcm200/nrf54l10/cpuapp
    Hello World! hcm200/nrf54l10/p
    Hello World! hcm200/nrf54l10/cuapp
    Hello World! hcm200/nrf54l10/uapp
    Hello World! hcm200/nrf54l10/puapp
    The correct ending should be `cpuapp`.
    I have attached a logic analyzer to SWO pin to see what really is happening on the wire. It occurs, there is unexpected data sent via SWO. Here are the waveforms:
    hello_world_sleep.sal
    I modified the application so that it does not use `k_msleep` function but a spin wait instead, like this:
    static void spin_wait_ms(int64_t duration_ms)
        const int64_t start_ms = k_uptime_get();
        while ((k_uptime_get() - start_ms) < duration_ms) {}
    After that the logs look correctly. The waveforms:
    hello_world_spin.sal
    It has been run on a custom board with nRF54L10 SoC on it.
    I have the following questions:
    1. Do you know why the logs are corrupted when using a sleep function in the code?
    2. Is there a way to use SWO log backend in Zephyr/NCS but not enabling SWO? Only the debugger would enable it when attached. It would save some power when the debugger is not attached.
    Best Regards,
    Damian
  • Hi Damian,
    1. It is likely caused by the HF clock being turned off when k_msleep() is called. The logging module uses deferred logging, so when LOG_INF() is called, the message is not sent immediately. Instead, it is queued and sent later by the logging thread. After the logging thread finishes writing all the bytes into the ITM FIFO (with ITM_SendChar()), the CPU goes to sleep. But the TPIU is still slowly serializing those bytes out over the SWO wire, and when the CPU sleeps, HFCLK is gated, cutting power to the TPIU mid-transmission, causing the message to be truncated.
    With a spin wait, the CPU stays awake, and HFCLK stays on, so the TPIU always finishes transmitting before sleep.
    I recommend using deferred logging, but you can log immediately instead of queuing logs by enabling CONFIG_LOG_MODE_IMMEDIATE.
    2. No, this is not possible. CONFIG_LOG_BACKEND_SWO must be enabled at build time to include the backend code. This includes log_backend_swo_init(), which enables ITM and TPIU on boot.
    Marte
  • Hi Marte,
    1. I use the config CONFIG_LOG_MODE_IMMEDIATE=y. The thing is that the logs are not truncated, they are sent among other random bytes (not printable), it can be seen in the `hello_world_sleep.sal` attached to my previous comment.
    2. I get it, thanks.
    Best Regards,
    Damian
    Since you are debugging I don't expect current consumption is much important, does enabling CONFIG_SOC_NRF_FORCE_CONSTLAT=y help? Then you should be able to use k_msleep() instead of spin_wait_ms().
    Kenneth
