nPM1300 BUCK2 not regulating to 3.3 V in standalone mode
Hi Nordic team,
I'm debugging a custom board using the nPM1300 and I'm seeing unexpected behavior from BUCK2. I'd appreciate any guidance on whether I'm misunderstanding the VSET configuration or if there is another startup/configuration requirement that I'm missing.
Hardware Configuration
  • PMIC: nPM1300
  • Operating mode: Standalone (no PMIC configuration over I²C)
  • BUCK2 desired output: 3.3 V
  • VSET2 resistor: 300 kΩ to GND
  • According to the nPM1300 Product Specification v1.3, the VSET2 table shows:
    • 250–500 kΩ → 3.3 V
  • NTC pin connected to GND through a 0 Ω resistor
  • No intentional connection between BUCK2 output and VSYS
  • Resistance from VSET2 to GND measures approximately 300 kΩ on the board
Observed Behavior (Board Under Test)
With USB power connected:
Signal Measured Voltage
VBUS 5.1 V
VSYS 5.0 V
BUCK2 Output (VOUT2) 4.45 V
The expected BUCK2 output is 3.3 V, but instead it sits around 4.45 V.
Battery-only operation
When running from battery:
  • One board measures ~3.3 V at BUCK2 output
  • Another board measures ~3.5 V at BUCK2 output
The output appears to track the battery voltage rather than regulate to a fixed 3.3 V.
Questions
  1. Is 300 kΩ a valid VSET2 value for selecting 3.3 V on nPM1300 Product Specification v1.3?
  2. In standalone mode, should BUCK2 automatically enable and regulate to the VSET-selected voltage at startup?
  3. Could grounding the NTC pin through 0 Ω affect BUCK2 startup or operation?
  4. Is it expected that VSYS measures almost the same as VBUS (5.0 V vs 5.1 V) in this configuration?
  5. Are there any recommended measurements or status registers that would help determine whether BUCK2 is actually enabled?
Any suggestions for further debugging would be greatly appreciated.
Thank you.
  • Dear Szabolcs,
    Thank you for reviewing the schematic and for your feedback.
    Regarding the current consumption, I would like to clarify that the measured current on the boards under test is approximately 30 - 33 mA with VBUS connected, which appears to be well below the default 100 mA current limit. Please disregard the earlier estimate of 90–110 mA that I mentioned during the initial investigation with some external debug tools connected, as subsequent measurements indicate the current consumption is significantly lower.
    Regarding the rework, yes, the boards currently being tested have undergone rework to remove the compass device. However, the BUCK2 behavior remains consistent across the tested boards (6 Boards):
    • Battery only: BUCK2 / 3V3A ≈ 3.294 - 3.33 V
    • VBUS connected: BUCK2 / 3V3A ≈ 4.24 V
    I will share the scope measurements/waveforms of VBUS, VSYS, BUCK2 output, and SW2 during startup soon.
  • Dear Szabolcs,
    Could you review the complete register dump attached, along with some manual measurements and observations included at the end of the document. Please let me know if you notice anything unexpected or any configuration that warrants further investigation.
    ## Register dump
    NPM13XX_REGISTER_DUMP_BEGIN
    MAIN page 0x00 (0x00..0x27)
      0000: 00 00 ff ff 00 00 2c 2c 00 00 06 06 00 00 00 00
      0010: 00 00 00 00 03 03 3d 3d 00 00 00 00 00 00 00 00
      0020: 00 00 00 00 00 00 02 02
    VBUS/LDSW_EXTRA page 0x02 (0x00..0x0c)
      0200: 00 01 05 00 00 00 00 21 00 00 00 00 00
    CHARGER page 0x03 (0x00..0x50)
      0300: 00 00 00 00 01 01 02 02 08 00 cf 01 07 04 00 00
      0310: bb 01 a4 02 54 01 3b 01 5a 00 5d 00 00 00 00 00
      0320: 00 00 00 00 00 00 00 00 00 00 00 00 44 00 00 00
      0330: 00 10 00 00 09 0e 00 00 0d 0c 08 07 00 00 0e 04
      0340: 03 02 00 03 00 01 26 00 00 00 00 00 0c 07 00 00
      0350: 00
    BUCK page 0x04 (0x00..0x35)
      0400: 00 00 00 00 00 00 00 00 17 02 08 08 41 00 00 01
      0410: 17 17 03 03 00 00 00 00 00 00 00 00 00 00 c2 00
      0420: c2 00 00 00 00 00 1d 1d 03 1e 00 5f 01 06 1f 1e
      0430: 5d 02 00 00 44 00
    ADC page 0x05 (0x00..0x24)
      0500: 00 00 00 00 00 00 00 00 00 00 00 03 00 00 00 01
      0510: 0f ca 00 6d c1 01 00 de 00 a6 90 00 00 00 00 00
      0520: 1a 17 1a 3c 01
    GPIO page 0x06 (0x00..0x1e)
      0600: 00 09 00 05 00 00 00 00 00 00 00 00 00 00 00 01
      0610: 00 01 01 01 00 00 00 00 00 00 00 00 00 00 00
    TIMER page 0x07 (0x00..0x0a)
      0700: 00 00 00 00 00 00 02 00 00 00 00
    LDSW page 0x08 (0x00..0x0d)
      0800: 00 00 00 00 12 0a 0a 00 01 01 00 01 17 08
    POF page 0x09 (0x00..0x00)
      0900: 00
    LEDDRV page 0x0a (0x00..0x08)
      0a00: 02 02 02 00 00 00 00 00 00
    SHIP page 0x0b (0x00..0x07)
      0b00: 00 00 00 00 03 01 01 00
    ERRLOG page 0x0e (0x00..0x05)
      0e00: 00 00 00 00 00 00
    NPM13XX_REGISTER_DUMP_END
    ## Parsing Register Dump
    NPM13XX_ANALYSIS_BEGIN
    PMIC: part=nPM1300 revision=0x02.2 rstcause=0x00 ship_exit=no boot_monitor=no watchdog=no longpress=no unknown=0x00
    VBUS: present status=0x21 detect=0x00 (no source detected) current_limit=no ovp=no uv=no suspended=no busout=yes
    VBUS config: ilim0=0x01 (100 mA) startup=0x05 (500 mA) suspend=0x00
    Charger: status=0x09 (constant-current) iset=0x08.0 (32.000 mA) vterm_idx=0x07 (4150 mV) vterm_r_idx=0x04 (4000 mV)
    Charger aux: ilim_status=0x00 ntc_status=0x00 die_status=0x00 disable=0x02 recharge_disabled=no ntc_disabled=yes config=0x00 vbatlow_charge=0x00 (disabled)
    Charger error reason: none
    Charger error sensor: none
    ERRLOG charger: reason=0x00 sensor=0x00
    BUCK2: on=yes status=0x44 sw_control=no selected_idx=0x17 (3300 mV) vout_norm=0x08 (1800 mV) vout_stat=0x17 (3300 mV) retention=0x08 (1800 mV)
    BUCK control: ctrl0=0x00 en_ctrl=0x41 vret_ctrl=0x00 pwm_ctrl=0x00 sw_ctrl=0x01
    BUCK2 range note: nPM13xx BUCK/LDO selectors cover 1000..3300 mV; no register setting can command 4100 mV.
    POF: config=0x00 state=disabled polarity_high=no threshold_idx=0x00 (2800 mV)
    GPIO: status=0x00 gpio0=no gpio1=no gpio2=no gpio3=no gpio4=no
    LEDDRV: mode0=0x02 (host) mode1=0x02 (host) mode2=0x02 (host)
    LDSW: status=0x12 ldo1_on=yes ldo2_on=no config=0x00 ldo1_mode=LDO ldo2_mode=LDO ldo1_vout_idx=0x17 (3300 mV) ldo2_vout_idx=0x08 (1800 mV)
    ADC: vbat_raw=809 -> 3950 mV vsys_raw=770 -> 4793 mV vbus_raw=664 -> 4863 mV ntc_raw=0 die_raw=437 ibat_raw=1 ibat_stat=0x0f config=0x00 auto=0x00 (disabled) ibat_en=0x01 (enabled)
    NPM13XX_ANALYSIS_END
    ## Manual Observations
    ### VBUS ON + VBAT ON
    BUCK2 = 4.1v - NOT_AS_PER_EXPECTATION
    BUCK1 disable / enable via shell is reflecting on pcb correctly. NOTE: voltage is very slowly reducing when disabled.
    LDO2 disable / enable via shell is reflecting on pcb correctly. NOTE: voltage is very slowly reducing when disabled.
    LDO1 disabled = 2.8v and enable = 3.285v - NOT_AS_PER_EXPECTATION
    ### VBUS ON + VBAT OFF
    ### VBUS OFF + VBAT ON
    BUCK2 = 3.3v
    While continuing the investigation, we wanted to cross-check a few points from the datasheet to ensure we are not overlooking any configuration-related causes:
    1. In our design, VBUSOUT is connected directly to the nRF5340 VBUS pin as recommended. Is there any possibility that the VBUSOUT path or VBUS detection circuitry could influence BUCK2 behavior when USB is connected?
    2. We are not intentionally using USB Selective Suspend (VBUSSUSPEND). The datasheet states that VBUS can be disconnected from VSYS while VBUSOUT remains active in this mode. Could this functionality affect BUCK operation in any way, or can it be ruled out for the observed behavior?
    3. Can charge-related settings such as ICHG (charge current limit) or VTERMSET (termination voltage) be ruled out as possible contributors to the observed BUCK2 behavior, or are there any known interactions between the charger and BUCK regulators that should be considered during debugging?
    Thank you for your guidance.
    The register dump shows every value as they should be, so I think there is a hardware problem somewhere.
    Can you remove the Buck inductor from a board, and measure the voltage on the SW and the VBUCKOUT pins? This will tell us where the voltage is coming from. (Also looking forward to the scope measurements.)
    Regarding your questions:
    • No, I don't think it should. This is independent of the Buck.
    • It can effect the VSYS voltage, which is the supply for the Buck. But otherwise, the Buck should operate normally.
    • The charger and the buck systems should be independent from each other. As you have seen, the problem persists without battery too.
  • Dear Szabolcs,
    Thank you for the clarifications and debugging suggestions.
    Please find attached the oscilloscope measurements, along with a tabulated summary of the observations under both battery-only and VBUS-connected conditions.
    I would appreciate your review of the captured waveforms and measurements. Please let me know if there are any additional checks you would recommend.
    Scope Measurements.zip
  • Hi Szabolcs,
    We have made significant progress in the investigation and would like to share the findings for your review and confirmation.
    Issue 1 – BUCK2 output rising to ~4.2 V when VBUS is connected
    Observed behavior
    • Battery only: BUCK2 output regulated normally around 3.3 V.
    • With VBUS connected: BUCK2 output increased to approximately 4.2–4.4 V and no longer appeared to regulate correctly.
    Root cause identified
    We discovered an unintended 0 Ω (to be DNP) connection (R10 at the external LDO enable pin) between VSYS and GPIO1 of the nPM1300. After correcting this connection, BUCK2 operation returned to normal and the output now regulates correctly at the expected voltage.
    Issue 2 – LDO1 / 3V3B rail measuring ~2.2 V when disabled
    Observed behavior
    • LDO1 was disabled through software.
    • The 3V3B rail continued to measure approximately 2.2 V.
    The 3V3B rail powers only the IMU and compass. To investigate further, a temporary 1 kΩ resistor was connected between 3V3B and GND while LDO1 remained disabled. The rail voltage collapsed from approximately 2.2 V to approximately 0.25 V.
    Based on this observation, our current understanding is that LDO1 is disabling correctly and is not actively sourcing the rail. The residual voltage appears to be caused by back-powering through the IMU and/or compass interface signals from the nRF5340 domain rather than from the PMIC itself.
    Could you please review these findings and let us know if the conclusions appear reasonable from your perspective?
    Thank you again for your support throughout the debugging process.
