Custom board not seen by IOS device but it is seen by NRF-Connect Desktop
Hi There,
I've been developing a product using the NRF52DK.  I had some custom PCB's made after I had my circuit designed, and I programmed them with the NRF52DK.  Now my boards and the NRF52832 on the DK are running the exact same firmware.
With the NRF52DK, I can connect to my service on NRF Connect for IOS and Desktop (with an NRF51 dongle).
With my boards, I can't see them with IOS (using NRF Connect or LightBlue) but I can see them using NRF Connect Desktop.
When I scan with NRF Connect Desktop, my boards' RSSI indicates a fairly strong signal (~ -55dBm) and I can connect and view/control all the characteristics fine.
I'm going to continue poking around to try to understand what's different but I'm quite stumped as to why IOS will only see the NRF52832 on the DK, but NRF Connect Desktop will see either the DK or the custom board.  I've tried an iPhone and an iPad and got the same result.
Any suggestions would be greatly appreciated!
Roger
  • I was going to use SOL_SNS just to determine whether or not the solenoid is present before enabling the Boost.  The plan is to use a pull-up in the NRF and then read it.  If the low resistance of the solenoid is present, I'll detect a low input voltage of D2's Vf.  If the solenoid isn't present then I'll see a hi-level and won't enable the Boost.  You're probably right that it would be worthwhile to put some protection on the nRF side....If nothing else, a little RC between the nRF and the anode of D2 would hopefully catch anything that got through D2...That circuit is only measuring DC voltage prior to enabling the boost, so I could put a pretty big C there and 100 ohms between nRF and the C to hopefully snub anything out.
    I'm hoping that I won't have too many issues with back-emf due to not switching the solenoid...If I was driving it with a low-side switch then I'd be more concerned, but I was thinking that things would be relatively graceful with this design, and that Q1 would never see much VDS due to it floating up with the boost output.
  • Yes that is the correct way to hookup C25. It actually doesn't matter if there are extra ground connections on the outside, but telling people to do it like this ensures that the phase reference for C25 is the same on all designs.
    Your traces between series parts should be as fat as possible.  Otherwise you are creating parasitic inductances with each interconnect.  In this case same width as the pad will be fine. Then pinch in the ground flood to the limit of your boardhouses capabilities, generally about 5-6mils is ok.  It still won't be 50ohms, but it will get it a little closer. You will still have matching work to do, but it will likely work reasonably well with whatever ref design values you are copying.
  • I don't have more comments on the design.
    I still think you should choose a different buck converter with integrated charge management.  You still don't have a LiPo charging solution on the board.
    TI has plenty of integrated buck/charge controller combos for 1,2, or even 3 cell solutions.
    http://www.ti.com/power-management/battery-management/charger-ic/products.html#p1152=1;1&p1153max=0;1
    Next time send me a PM or just email.  The new Nordic site isn't working well and I rarely get notifications on questions.  I think a lot of stuff is getting lost.
  • Just out of interest, I was starting to play with a new project idea and I configured one of my initial boards for that and used my DK as a Central.  The DK can see my custom board, but still no luck with a phone.  I assume that my antenna design is just crappy enough to not work with a phone's chip antenna but I'm right on the edge where a PCB antenna can see it.
    I just received rev2 of my board today, and the stencil is on its way.  Here's hoping that this one behaves better.  Thanks again for the input on this!
  • There are plenty of config problems that can cause that to happen. That's really not my area of expertise. I'm sure there is a lot of info on it in the devzone.
    Did you get my reply on your ground pours and thermals? I don't see it now in the list.
    Actually right now I don't see most of the my last comments on your recent spin.  I only see 2 comments and I sent you at least 4 or 5.   I have been having a lot of issues with the new devzone site and I think the system may have lost them.
