We are currently in the process of FCC certification for a product that uses nRF52832. Our testing house said the the test has failed because of not qualifying the minimum bandwidth requirement.
Configuration is all 12 combinations of the following 3 x channels, 2 x modulations, and 2 x bit rates were tested to find the worst case. More substantial testing was to follow using this worst case but we did not pass.
The worst case was determined to be Nrf (¿proprietary?) modulation at 1 Mbit, using a modulated carrier.
1) Do I need Nrf modulation to inter-operate with mobile devices?
2) If I don't have to enable Nrf to operate with iOS, Android devices (for example), how do I disable it?
Configuration Params (all 12 combinations of modes and "channels"):
  • modulated tx carrier
  • static const uint8_t txpower = RADIO_TXPOWER_TXPOWER_Pos4dBm; // max power according to my interpretation
  • static const uint8_t channels[] = {2, 40, 80};
  • static const uint8_t modes[] = {
    • RADIO_MODE_MODE_Ble_1Mbit,
    • RADIO_MODE_MODE_Ble_2Mbit,
    • RADIO_MODE_MODE_Nrf_1Mbit,
    • RADIO_MODE_MODE_Nrf_2Mbit
  • Data payload is random bytes
Note that "channels" is a misnomer... these are frequency offsets to 2400 NOT channel numbers. this is a bug in the SDK.
6dB BW plots.pdf
  • Hi
    1) You only need to test the bit rates that you will actually use in the end product, so if you are planning to use BLE only then you can remove the Nrf bit rates from the test.
    2) What example are you using to test the part?
    It is common to use the DTM examples for BLE testing, in which case the Nrf bit rates are unavailable.
    Have you had the hardware layout reviewed by us earlier?
    Assuming the layout is done correctly you should be able to pass the test on all bit rates.
    Best regards
    Torbjørn
    1. We've stopped testing with Nrf and are now testing with Ble 1Mbit and 2Mbit. Whichever of those two is the worst will be used for Phase II testing at three frequencies.
    2. I'm using an example that I believe came from this forum (didn't re-find it just now). If I find the original posting I'll re-reply here. Since the tester is happy with ignoring the Nrf modes and just using the Ble modes we're progressing.
    3. Our HW was reviewed, it was submitted by our HW designer. This is now a SW (well... radio configuration) issue.
    I believe that what I need to do is take my nRF52 SDK 14.2.0 examples/ble_peripheral/ble_app_template.c "like" code and force it to NOT allow Nrf modulation... so that our application is using the same RF stuff that our testing is using. Can I block either Nrf mode in my app, or do I have to pick one of the two bit rates for Ble. In my 802.11 days bit rates were dynamically negotiated within each session which implies both Ble bit rates are enabled. Maybe BLE is different?
  • This is the code we based our test on. A button on our product cycles us through the modes and channels.
    https://devzone.nordicsemi.com/f/nordic-q-a/14473/radio-test-example-channel-selection-issue-fcc-certification
    It's clear how to force Nrf vs Ble and 1Mbit vs 2Mbit in that test code, however it is not obvious to me how to do that in the ble_app_template.c example.
  • First, the radio test code does work well for FCC.  Also, as ovrebekk pointed out you only test with the modulations you actually use.
    Second, you should post a jpeg of the failing spectrum analyzer sweep. It will tell a lot about what is going wrong for you.
  • When I run nRF52 SDK 14.2.0 examples/ble_peripheral/ble_app_template.c what modulations am I using?
1 2
