Installing nRF52840 dongle on W10 PC. Please see the attached screenshot to help me out installing it for nRF Connect.
Thanks.
Thanks.
Great, just update this thread if you run into any more issues. Hopefully everything works like it should now.
FYI: Just now nRF Connect Desktop has lost my dongle. I pulled it of USB and then plugged it back, then I was notified that it needs to be reprogrammed yet again and so I did. It is working again... What The ...Dongle!
Weird. Have you noticed some improved stability with the new version of nRF Connect for Desktop apart from this one issue? You do not receive the libusb error anymore, correct? Has this happened multiple times? Has your intern had any issues?
I didn't see my intern yet nor did hear anything.I'm trying to accept nRF Connect the way it is otherwise my list of complaints would be huge and I'm guessing I'm not the only one. I'd strongly recommend implementing a client-server architecture and thus one would be able to communicate with it via some port and do whatever necessary on the client side leaving nRF Connect(the server) alone.
In case it will help you to replicate the issue. After my PC hibernates I need to relaunch nRF Connect. As soon as I relaunch it I'm having issues with the dongle. Sorry, didn't make a screenshot yet. To fix it, I need to pull the dongle out and push it back in the USB. Then it is working again.
Sorry for the delayed response. I just tested the dongle with the ble app on nrf connect v2.5.0. I programmed the correct FW on the dongle when the popup appeared, noticed that the scanning functionality worked like it should & closed the dongle port. I then put the computer to sleep, turned it back on, opened nRF Connect for Desktop once again, opened the BLE app, connected to the dongle & the scanning worked like it should. Could you please upload a screenshot of the issue(s) you are having?
