I am trying to code nRF52840- DK with MAX30003 ECG Board Using SPI. I have referred Arduino Uno Code for MAX30003 ECG.
I need some help for Driver Development if anybody worked on this please share any info.
Thanks and Regards,
Rohit
Thanks and Regards,
Rohit
I have to read SPI transmit and SPI Receive.
That makes no sense!
Transmit is what you send - so why do you need to read it??
Use the 'Insert Code' feature to get properly formatted source code in your post:
From MAX30003 spec:
The device is programmed and accessed by a 32 cycle SPI instruction framed by a CSB low interval. The content of the SPI operation consists of a one byte command word (comprised of a seven bit address and a Read/Write mode indicator, i.e., A[6:0] + R/W) followed by a three-byte data word.
Read mode operations will access the requested data on the 8th SCLK rising edge, and present the MSB of the requested data on the following SCLK falling edge, allowing the µC to sample the data MSB on the 9th SCLK rising edge. Configuration, Status, and FIFO data are all available via normal mode read back sequences. If more than 32 SCLK rising edges are provided in a normal read sequence then the excess edges will be ignored and the device will read back zeros.
uint8_t SPI_TX_Buff[4]; // 32 bit transfers
void MAX30003_Reg_Read(uint8_t Reg_address)
nrfx_err_t err_code = NRF_SUCSESS;
// nrf_gpio_pin_clear(NRFX_SPIM_SS_PIN); The driver should handle the SS pin automatically.
//Prepare the tx buffer
memset(SPI_TX_Buff[0], 0x00, sizeof(SPI_TX_Buff)); // Erases the buffer
memset(SPI_RX_Buff[0], 0x00, sizeof(SPI_TX_Buff)); // Erases the buffer
SPI_TX_Buff[0] = (Reg_address<<1 ) | RREG; // should be SPI_TXBuff[0], I assume RREG = 0x1;
//Create the transfer descriptor
nrfx_spim_xfer_desc_t xfer_desc4 = NRFX_SPIM_XFER_TRX(SPI_TX_Buff[0], sizeof(SPI_TX_Buff), SPI_RX_Buff[0], sizeof(SPI_TX_Buff));
//Initiate the transfer
err_code = nrfx_spim_xfer(&Your_SPIM_Instance, &xfer_desc4, 0);
// nrf_gpio_pin_set(NRFX_SPIM_SS_PIN); The driver should handle the SS pin automatically.
// When the SPIM event handler is called with the NRFX_SPIM_EVENT_DONE event, the SPI_RX_Buff[1] to 3 will contain the received data.You should also scope the SPI communication with a digital logical analyzer. I suggest a Saleae Logic 8 or similar devices.
#include "nrfx_spim.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "MAX30003.h"
#define NRFX_SPIM_SCK_PIN 3
#define NRFX_SPIM_MOSI_PIN 4
#define NRFX_SPIM_MISO_PIN 28
#define NRFX_SPIM_SS_PIN 29
#define NRFX_SPIM_DCX_PIN 30
#define SPI_INSTANCE 3 /**< SPI instance index. */
/* FOR MAX30003 ECG PART */
uint8_t SPI_RX_Buff[6]; /**< RX buffer. */
uint8_t SPI_TX_Buff[6];
static const uint8_t ECG_SIZE = sizeof(SPI_TX_Buff); /**< Transfer length. */
//volatile char SPI_RX_Buff[5] ;
volatile char *SPI_RX_Buff_Ptr;
uint8_t A=0xFF;
uint8_t A1=0x00;
int i=0;
unsigned long uintECGraw = 0;
signed long intECGraw=0;
uint8_t DataPacketHeader[20];
uint8_t data_len = 8;
signed long ecgdata;
unsigned long data;
char SPI_temp_32b;
char SPI_temp_Burst[100];
static const nrfx_spim_t spi = NRFX_SPIM_INSTANCE(SPI_INSTANCE); /**< SPI instance. */
static volatile bool spi_xfer_done; /**< Flag used to indicate that SPI instance completed the transfer. */
#define TEST_STRING "rohit"
static uint8_t m_tx_buf[] = TEST_STRING; /**< TX buffer. */
static uint8_t m_rx_buf[sizeof(TEST_STRING) + 1]; /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf); /**< Transfer length. */
void timerIsr() //Its configuration is over
nrf_gpio_pin_toggle(NRF_FCLK_PIN); // NRF_GPIO_PIN_MAP(1, 00) toggle Digital6 attached to FCLK of MAX30003
void MAX30003_Reg_Write (unsigned char WRITE_ADDRESS, unsigned long data)
uint8_t dataToSend = (WRITE_ADDRESS<<1) | WREG;
uint8_t temp_1 = (data>>16); //number of register to wr
uint8_t temp_2 = (data>>8);
nrf_delay_ms(200);
nrfx_spim_xfer_desc_t xfer_desc = NRFX_SPIM_XFER_TRX(dataToSend, sizeof(dataToSend), SPI_RX_Buff, sizeof(dataToSend));
nrfx_spim_xfer_desc_t xfer_desc1= NRFX_SPIM_XFER_TRX(temp_1, sizeof(temp_1), SPI_RX_Buff, sizeof(temp_1));
nrfx_spim_xfer_desc_t xfer_desc2= NRFX_SPIM_XFER_TRX(temp_2, sizeof(temp_2), SPI_RX_Buff, sizeof(temp_2));
nrfx_spim_xfer_desc_t xfer_desc3= NRFX_SPIM_XFER_TRX(data, sizeof(data), SPI_RX_Buff, sizeof(data));
nrf_delay_ms(200);
void max30003_sw_reset(void)
MAX30003_Reg_Write(SW_RST,0x000000);
nrf_delay_ms(100);
SPI_TX_Buff[1] = (Reg_address<<1 ) | RREG;
nrfx_spim_xfer_desc_t xfer_desc4 = NRFX_SPIM_XFER_TRX(SPI_TX_Buff[1], sizeof(SPI_TX_Buff[1]), SPI_RX_Buff, sizeof(SPI_TX_Buff[1]));
for ( i = 0; i < 3; i++)
SPI_temp_32b[i]= NRFX_SPIM_XFER_TRX(A, sizeof(A), SPI_RX_Buff, sizeof(A));
void spim_event_handler(nrfx_spim_evt_t const * p_event,
void * p_context)
spi_xfer_done = true;
NRF_LOG_INFO("Transfer completed.");
if (m_rx_buf[0] != 0)
NRF_LOG_INFO(" Received:");
NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
nrfx_spim_xfer_desc_t xfer_desc = NRFX_SPIM_XFER_TRX(m_tx_buf, m_length, m_rx_buf, m_length);
nrfx_spim_config_t spi_config = NRFX_SPIM_DEFAULT_CONFIG;
spi_config.frequency = NRF_SPIM_FREQ_1M;
spi_config.ss_pin = NRFX_SPIM_SS_PIN;
spi_config.miso_pin = NRFX_SPIM_MISO_PIN;
spi_config.mosi_pin = NRFX_SPIM_MOSI_PIN;
spi_config.sck_pin = NRFX_SPIM_SCK_PIN;
spi_config.dcx_pin = NRFX_SPIM_DCX_PIN;
spi_config.use_hw_ss = true;
spi_config.ss_active_high = false;
APP_ERROR_CHECK(nrfx_spim_init(&spi, &spi_config, spim_event_handler, NULL));
NRF_LOG_INFO("NRFX SPIM example started.");
MAX30003_Reg_Read( 0x21);
MAX30003_Reg_Read( 0x25);
while (1)
// Reset rx buffer and transfer done flag
memset(m_rx_buf, 0, m_length);
spi_xfer_done = false;
APP_ERROR_CHECK(nrfx_spim_xfer_dcx(&spi, &xfer_desc, 0, 15));
while (!spi_xfer_done)
__WFE();
NRF_LOG_FLUSH();
bsp_board_led_invert(BSP_BOARD_LED_0);
nrf_delay_ms(200);
Hi Haakonsh,
Thanks for the reply and suggestions.
regards,
rohit
So what do you expect that code to do?
What does it actually do?
In other words, you need to examine the signals on the physical connections between the SPI Master (NRF52840-DK) and the SPI Slave (MAX30003 ECG Board) using a logic analyser, oscilloscope, or similar.
Have you done that?
What did you see?
