I cannot locate any QPI sample code in the example. Was it possible for anyone to share me the sample code?
Thanks a bunch.
Thanks a bunch.
Hi haakonsh
Thanks. I have tried NRF_QSPI_CINSTR_LEN_3B but I notice the output of the last byte is 0x00 rather than 0x02. Please advice is this a bug?
Ahh, sorry I missed that.
I believe the reason that you get 0x02, 0x00 is that you declared the buffer as uint16_t whereas the QSPI operates on bytes.
ie:
NRF_QSPI_CINSTR_LEN_5B should yield 0x02, 0x00, 0x02, 0x00.
Thanks @haakonsh,
I would like to learn to understand and how to configure prot_if parameters.
readoc structure
1) NRF_QSPI_READOC_READ4IO = 0xEB which is Quad I/O Read which is same as S25F064L Quad I/O Read 0xEB?
2) NRF_QSPI_WRITEOC_PP4IO = 0x38 for MX25R6435F chip its 4PP? Was it the same as S25F064L 4QPP which is 0x34?
If I want to change those value, where can I change it? I just don't understand the code in nrf52840_bitfields.h, and how can I change if the PP4IO instruction if its different?
/* Bits 5..3 : Configure number of data lines and opcode used for writing. */ #define QSPI_IFCONFIG0_WRITEOC_Pos (3UL) /*!< Position of WRITEOC field. */ #define QSPI_IFCONFIG0_WRITEOC_Msk (0x7UL << QSPI_IFCONFIG0_WRITEOC_Pos) /*!< Bit mask of WRITEOC field. */ #define QSPI_IFCONFIG0_WRITEOC_PP (0UL) /*!< Single data line SPI. PP (opcode 0x02). */ #define QSPI_IFCONFIG0_WRITEOC_PP2O (1UL) /*!< Dual data line SPI. PP2O (opcode 0xA2). */ #define QSPI_IFCONFIG0_WRITEOC_PP4O (2UL) /*!< Quad data line SPI. PP4O (opcode 0x32). */ #define QSPI_IFCONFIG0_WRITEOC_PP4IO (3UL) /*!< Quad data line SPI. PP4IO (opcode 0x38). */
3) The S25F064L chip come in SPI as default setting, is the on board PCA10056 DK MX25R6435F already preconfigured with QSPI setting? If yes, How can I the command in SPI using QSPI resource?
4) is the default QSPI sample setting same for operation below?
I'm sorry for the delayed response. Haakon is currently out of office on business travel. Have you been able to solve this, or do you still need help?
Yes. I need help. The question will be as per the last question I asked, which is how to customize the QSPI sample code to enable QSPI in cypress Model:S25FL064LABNFI010
