Dear all,
Working with nRF52832 (currently without SoftDevice), and there some issues regarding the project current consumption that we need to understand:
1) In the PS (v1.1) documentation, in section 7.2.1 "CPU performance", there is a current definition
of IDDFLASHDCDC/MHz that can be as low as 58uA/MHz.
The current consumption in our project was dropped from 5.5mA to 3.5mA, but still, it's far from the expected current of 0.928mA (=58nA * 16), what else should be done/configured to achieve this goal?
2) In our low power SAADC module, we set tACQ (Acquisition time) to 40usec and tCONV (Conversion time) to 2usec, once again, in the PS (v1.1) documentation, the IADC,CONV current definition is 700uA, we want to know that it refers to the time frame of 42usec and the current will be in idle mode otherwise, and if this isn't the case is there a way to configure it to that time frame only?
3) In the low power SAADC module, we use an easyDMA, and the current consumption is about 1.5mA, is there a way to reduce that?
In other words, to make sure that the easyDMA is in idle state during the time between samples?
Thanks in advance,
Amir.
