Connection Interval
Hi everyone,
I'm new to working with Bluetooth/
My problem is that the connection interval time sent by the central device does not converge with the time I see using an oscilloscope or a configured timer for 1 ms.
The principle of operation of my program is that the peripheral device sleeps for a certain time and wakes up at a specified interval. The central device at this time is trying to connect to it. Using the timer, I count the time from when the device woke up to the time of the BLE_GAP_EVT_CONNECTED event and to the time of the BLE_GAP_EVT_CONN_PARAM_UPDATE event. The time difference between these events is about 600 ms. I can not understand why such a difference in time. Maybe I did not correctly understand the meaning of the parameters MIN_CONN_INTERVAL and MAX_CONN_INTERVAL? If so, then how can you reduce the time for a full connection, so that the BLE_GAP_EVT_CONN_PARAM_UPDATE event occurs as soon as possible.
To check what the actual value is transmitted by the central device, you can make a breakpoint during the execution of the program at the time of the BLE_GAP_EVT_CONN_PARAM_UPDATE event, which I actually did.
According to the received data, the central device set the value of the maximum and minimum interval of 7.5 ms.In the peripheral device, I have the following parameters:
MIN_CONN_INTERVAL    MSEC_TO_UNITS (7.5, UNIT_1_25_MS)
MAX_CONN_INTERVAL   MSEC_TO_UNITS (30, UNIT_1_25_MS)
SLAVE_LATENCY            1
CONN_SUP_TIMEOUT   MSEC_TO_UNITS (250, UNIT_10_MS)
I also read that the connection interval can vary from 7.5 ms to 4 s, maybe this value is the connection interval for my central device?
Chip: BT840F (analog nRF52840);
SDK: nRF5_SDK_15.2.0;
Softdevice: s132_nrf52_6.1.0_softdevice;
Phone: Xiaomi Redmi 5+.
Thanks in advance for your help.
  • Hi
    Having some trouble recreating this. Are these logs when connecting to your phone or to the other nRF chip you have? Also, why are you waiting to transfer data until you get the last conn_params_update event? That shouldn't be necessary.
    I also have a question about your code snippet. Where does the time_conn [0-3] come from?
    Simon
  • Hi
    About the logs. If I understand you correctly, on the side of the smartphone I am not getting at the moment. Only in the manner described above, I get a report.
    "Also, why are you waiting to transfer data until you get the last conn_params_update event? That shouldn't be necessary."
    The last event I do not expect. As soon as I get to the BLE_GAP_EVT_CONN_PARAM_UPDATE event, I immediately start the data transfer. Due to the fact that for the first time the time interval parameters are set to 7.5 ms, the data does not come to the phone. Only with the following parameters data is received.
    About time_conn [0-3]. I set up a timer at 1 ms intervals and start it when the peripheral device wakes up.
  • Can you try to start sending data immediately after ble_evt_connected? You will likely get NRF_ERROR_INVALID_STATE in the beginning, but just keep trying until you get NRF_SUCCESS. This means that notifications aren't enabled, or that ATT_MTU exchange is running. It should not be necessary to wait until conns_params_update to send data.
     What following parameters are you referring to?
    Yes, the time_conn are timers, but where in your code have you defined them/their values?
    Simon
  • Hi
    If I understand you correctly, you are proposing to start sending data right away when I get into the BLE_GAP_EVT_CONNECTED event. I tried to do this and the result did not change.
    I have an assumption that the first connection interval is always set to 7.5 ms. Perhaps during the first attempt, the peripheral device substitutes the ideal value of the connection interval to check if it is possible or not. After that, the central device rejects this value and sends back its values ​​for the connection interval at which a stable connection of two devices already occurs.
    Tell me, is this possible? I just have no more options, why I always see the connection interval = 7.5 ms when I first try to connect.
    Concerning the timer and in general the way of counting time. I'll post the main file from the cscs example, where the timer is set up and everything else to display this problem.
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_csc_main main.c
     * @ingroup ble_sdk_app_csc
     * @brief Cycling Speed and Cadence Service Sample Application main file.
     * This file contains the source code for a sample application using the Cycling Speed and Cadence
     * Service.
     * It also includes the sample code for Battery and Device Information services.
     * This application uses the @ref srvlib_conn_params module.
     * This application implements supports for both Wheel revolution Data and Crank Revolution Data.
     * In addition, this application also has support for all 'Speed and Cadence Control Point'.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_err.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_bas.h"
    #include "ble_cscs.h"
    #include "ble_dis.h"
    #include "ble_conn_params.h"
    #include "sensorsim.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "app_timer.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "bsp_btn_ble.h"
    #include "fds.h"
    #include "ble_conn_state.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define DEVICE_NAME                     "Nordic_CSC"                                /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME               "NordicSemiconductor"                       /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_INTERVAL                40                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 25 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define BATTERY_LEVEL_MEAS_INTERVAL     APP_TIMER_TICKS(2000)                       /**< Battery level measurement interval (ticks). */
    #define MIN_BATTERY_LEVEL               81                                          /**< Minimum battery level as returned by the simulated measurement function. */
    #define MAX_BATTERY_LEVEL               100                                         /**< Maximum battery level as returned by the simulated measurement function. */
    #define BATTERY_LEVEL_INCREMENT         1                                           /**< Value by which the battery level is incremented/decremented for each call to the simulated measurement function. */
    #define SPEED_AND_CADENCE_MEAS_INTERVAL 1000                                        /**< Speed and cadence measurement interval (milliseconds). */
    #define WHEEL_CIRCUMFERENCE_MM          2100                                        /**< Simulated wheel circumference in millimeters. */
    #define KPH_TO_MM_PER_SEC               278                                         /**< Constant to convert kilometers per hour into millimeters per second. */
    #define MIN_SPEED_KPH                   10                                          /**< Minimum speed in kilometers per hour for use in the simulated measurement function. */
    #define MAX_SPEED_KPH                   40                                          /**< Maximum speed in kilometers per hour for use in the simulated measurement function. */
    #define SPEED_KPH_INCREMENT             1                                           /**< Value by which speed is incremented/decremented for each call to the simulated measurement function. */
    #define DEGREES_PER_REVOLUTION          360                                         /**< Constant used in simulation for calculating crank speed. */
    #define RPM_TO_DEGREES_PER_SEC          6                                           /**< Constant to convert revolutions per minute into degrees per second. */
    #define MIN_CRANK_RPM                   20                                          /**< Minimum cadence in RPM for use in the simulated measurement function. */
    #define MAX_CRANK_RPM                   110                                         /**< Maximum cadence in RPM for use in the simulated measurement function. */
    #define CRANK_RPM_INCREMENT             3                                           /**< Value by which cadence is incremented/decremented in the simulated measurement function. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(500, UNIT_1_25_MS)            /**< Minimum acceptable connection interval (0.5 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(1000, UNIT_1_25_MS)           /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(5000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
    #define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    BLE_BAS_DEF(m_bas);        /**< Battery service instance. */
    BLE_CSCS_DEF(m_cscs);                                                               /**< Cycling speed and cadence service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    APP_TIMER_DEF(m_battery_timer_id);                                                  /**< Battery timer. */
    APP_TIMER_DEF(m_csc_meas_timer_id);                                                 /**< CSC measurement timer. */
    #define MY_TIMEOUT  APP_TIMER_TICKS(1)
    uint16_t time_conn[3];
    APP_TIMER_DEF(m_test_conn_timer_id);
    static uint16_t          m_conn_handle = BLE_CONN_HANDLE_INVALID;                   /**< Handle of the current connection. */
    static sensorsim_cfg_t   m_battery_sim_cfg;                                         /**< Battery Level sensor simulator configuration. */
    static sensorsim_state_t m_battery_sim_state;                                       /**< Battery Level sensor simulator state. */
    static sensorsim_cfg_t   m_speed_kph_sim_cfg;                                       /**< Speed simulator configuration. */
    static sensorsim_state_t m_speed_kph_sim_state;                                     /**< Speed simulator state. */
    static sensorsim_cfg_t   m_crank_rpm_sim_cfg;                                       /**< Crank simulator configuration. */
    static sensorsim_state_t m_crank_rpm_sim_state;                                     /**< Crank simulator state. */
    static uint32_t m_cumulative_wheel_revs;                                            /**< Cumulative wheel revolutions. */
    static bool     m_auto_calibration_in_progress;                                     /**< Set when an autocalibration is in progress. */
    static ble_sensor_location_t supported_locations[] =                                /**< Supported location for the sensor location. */
        BLE_SENSOR_LOCATION_FRONT_WHEEL,
        BLE_SENSOR_LOCATION_LEFT_CRANK,
        BLE_SENSOR_LOCATION_RIGHT_CRANK,
        BLE_SENSOR_LOCATION_LEFT_PEDAL,
        BLE_SENSOR_LOCATION_RIGHT_PEDAL,
        BLE_SENSOR_LOCATION_FRONT_HUB,
        BLE_SENSOR_LOCATION_REAR_DROPOUT,
        BLE_SENSOR_LOCATION_CHAINSTAY,
        BLE_SENSOR_LOCATION_REAR_WHEEL,
        BLE_SENSOR_LOCATION_REAR_HUB
    static ble_uuid_t m_adv_uuids[] =                                                   /**< Universally unique service identifiers. */
        {BLE_UUID_CYCLING_SPEED_AND_CADENCE,  BLE_UUID_TYPE_BLE},
        {BLE_UUID_BATTERY_SERVICE,            BLE_UUID_TYPE_BLE},
        {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
    static void advertising_start(bool erase_bonds);
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in] line_num   Line number of the failing ASSERT call.
     * @param[in] file_name  File name of the failing ASSERT call.
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        pm_handler_on_pm_evt(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
                advertising_start(false);
    /**@brief Function for performing battery measurement and updating the Battery Level characteristic
     *        in Battery Service.
    static void battery_level_update(void)
        ret_code_t err_code;
        uint8_t  battery_level;
        battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
        err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
        if ((err_code != NRF_SUCCESS) &&
            (err_code != NRF_ERROR_INVALID_STATE) &&
            (err_code != NRF_ERROR_BUSY) &&
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(err_code);
    /**@brief Function for handling the Battery measurement timer timeout.
     * @details This function will be called each time the battery level measurement timer expires.
     * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
     *                       app_start_timer() call to the timeout handler.
    static void battery_level_meas_timeout_handler(void * p_context)
        UNUSED_PARAMETER(p_context);
        battery_level_update();
    /**@brief Function for populating simulated cycling speed and cadence measurements.
    static void csc_sim_measurement(ble_cscs_meas_t * p_measurement)
        static uint16_t cumulative_crank_revs = 0;
        static uint16_t event_time            = 0;
        static uint16_t wheel_revolution_mm   = 0;
        static uint16_t crank_rev_degrees     = 0;
        uint16_t mm_per_sec;
        uint16_t degrees_per_sec;
        uint16_t event_time_inc;
        // Per specification event time is in 1/1024th's of a second.
        event_time_inc = (1024 * SPEED_AND_CADENCE_MEAS_INTERVAL) / 1000;
        // Calculate simulated wheel revolution values.
        p_measurement->is_wheel_rev_data_present = true;
        mm_per_sec = KPH_TO_MM_PER_SEC * sensorsim_measure(&m_speed_kph_sim_state,
                                                           &m_speed_kph_sim_cfg);
        wheel_revolution_mm     += mm_per_sec * SPEED_AND_CADENCE_MEAS_INTERVAL / 1000;
        m_cumulative_wheel_revs += wheel_revolution_mm / WHEEL_CIRCUMFERENCE_MM;
        wheel_revolution_mm     %= WHEEL_CIRCUMFERENCE_MM;
        p_measurement->cumulative_wheel_revs = m_cumulative_wheel_revs;
        p_measurement->last_wheel_event_time =
            event_time + (event_time_inc * (mm_per_sec - wheel_revolution_mm) / mm_per_sec);
        // Calculate simulated cadence values.
        p_measurement->is_crank_rev_data_present = true;
        degrees_per_sec = RPM_TO_DEGREES_PER_SEC * sensorsim_measure(&m_crank_rpm_sim_state,
        &m_crank_rpm_sim_cfg);
        crank_rev_degrees     += degrees_per_sec * SPEED_AND_CADENCE_MEAS_INTERVAL / 1000;
        cumulative_crank_revs += crank_rev_degrees / DEGREES_PER_REVOLUTION;
        crank_rev_degrees     %= DEGREES_PER_REVOLUTION;
        p_measurement->cumulative_crank_revs = cumulative_crank_revs;
        p_measurement->last_crank_event_time =
            event_time + (event_time_inc * (degrees_per_sec - crank_rev_degrees) / degrees_per_sec);
        event_time += event_time_inc;
    /**@brief Function for handling the Cycling Speed and Cadence measurement timer timeouts.
     * @details This function will be called each time the cycling speed and cadence
     *          measurement timer expires.
    static void csc_meas_timeout_handler(void * p_context)
        uint32_t        err_code;
        ble_cscs_meas_t cscs_measurement;
        csc_sim_measurement(&cscs_measurement);
        err_code = ble_cscs_measurement_send(&m_cscs, &cscs_measurement);
        if (m_auto_calibration_in_progress)
            err_code = ble_sc_ctrlpt_rsp_send(&(m_cscs.ctrl_pt), BLE_SCPT_SUCCESS);
                (err_code != NRF_ERROR_RESOURCES)
            if (err_code != NRF_ERROR_RESOURCES)
                m_auto_calibration_in_progress = false;
    static void test_conn_timer_handler(void * p_context)
      time_conn[0]++;
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
      // Initialize timer module.
      err_code = app_timer_init();
      // Create timers.
      err_code = app_timer_create(&m_battery_timer_id,
                                  APP_TIMER_MODE_REPEATED,
                                  battery_level_meas_timeout_handler);
      // Create battery timer.
      err_code = app_timer_create(&m_csc_meas_timer_id,
                                  csc_meas_timeout_handler);
      //My timer
      err_code = app_timer_create(&m_test_conn_timer_id,
                                  test_conn_timer_handler);
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_CYCLING_SPEED_CADENCE_SENSOR);
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling Speed and Cadence Control point events
     * @details Function for handling Speed and Cadence Control point events.
     *          This function parses the event and in case the "set cumulative value" event is received,
     *          sets the wheel cumulative value to the received value.
    ble_scpt_response_t sc_ctrlpt_event_handler(ble_sc_ctrlpt_t     * p_sc_ctrlpt,
                                                ble_sc_ctrlpt_evt_t * p_evt)
        switch (p_evt->evt_type)
            case BLE_SC_CTRLPT_EVT_SET_CUMUL_VALUE:
                m_cumulative_wheel_revs = p_evt->params.cumulative_value;
            case BLE_SC_CTRLPT_EVT_START_CALIBRATION:
                m_auto_calibration_in_progress = true;
                // No implementation needed.
        return (BLE_SCPT_SUCCESS);
     * @details Initialize the Cycling Speed and Cadence, Battery and Device Information services.
        uint32_t              err_code;
        ble_cscs_init_t       cscs_init;
        ble_bas_init_t        bas_init;
        ble_dis_init_t        dis_init;
        ble_sensor_location_t sensor_location;
        nrf_ble_qwr_init_t    qwr_init = {0};
        // Initialize Cycling Speed and Cadence Service.
        memset(&cscs_init, 0, sizeof(cscs_init));
        cscs_init.evt_handler = NULL;
        cscs_init.feature     = BLE_CSCS_FEATURE_WHEEL_REV_BIT | BLE_CSCS_FEATURE_CRANK_REV_BIT |
                                BLE_CSCS_FEATURE_MULTIPLE_SENSORS_BIT;
        // Here the sec level for the Cycling Speed and Cadence Service can be changed/increased.
        cscs_init.csc_meas_cccd_wr_sec  = SEC_OPEN;
        cscs_init.csc_feature_rd_sec    = SEC_OPEN;
        cscs_init.csc_location_rd_sec   = SEC_OPEN;
        cscs_init.sc_ctrlpt_cccd_wr_sec = SEC_OPEN;
        cscs_init.sc_ctrlpt_wr_sec      = SEC_OPEN;
        cscs_init.ctrplt_supported_functions = BLE_SRV_SC_CTRLPT_CUM_VAL_OP_SUPPORTED
                                               | BLE_SRV_SC_CTRLPT_SENSOR_LOCATIONS_OP_SUPPORTED
                                               | BLE_SRV_SC_CTRLPT_START_CALIB_OP_SUPPORTED;
        cscs_init.ctrlpt_evt_handler            = sc_ctrlpt_event_handler;
        cscs_init.list_supported_locations      = supported_locations;
        cscs_init.size_list_supported_locations = sizeof(supported_locations) /
                                                  sizeof(ble_sensor_location_t);
        sensor_location           = BLE_SENSOR_LOCATION_FRONT_WHEEL;                 // initializes the sensor location to add the sensor location characteristic.
        cscs_init.sensor_location = &sensor_location;
        err_code = ble_cscs_init(&m_cscs, &cscs_init);
        // Initialize Battery Service.
        memset(&bas_init, 0, sizeof(bas_init));
        // Here the sec level for the Battery Service can be changed/increased.
        bas_init.bl_rd_sec        = SEC_OPEN;
        bas_init.bl_cccd_wr_sec   = SEC_OPEN;
        bas_init.bl_report_rd_sec = SEC_OPEN;
        bas_init.evt_handler          = NULL;
        bas_init.support_notification = true;
        bas_init.p_report_ref         = NULL;
        bas_init.initial_batt_level   = 100;
        err_code = ble_bas_init(&m_bas, &bas_init);
        // Initialize Device Information Service.
        memset(&dis_init, 0, sizeof(dis_init));
        ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, MANUFACTURER_NAME);
        dis_init.dis_char_rd_sec = SEC_OPEN;
        err_code = ble_dis_init(&dis_init);
    /**@brief Function for initializing the sensor simulators.
    static void sensor_simulator_init(void)
        m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
        m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
        m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
        m_battery_sim_cfg.start_at_max = true;
        sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
        m_speed_kph_sim_cfg.min          = MIN_SPEED_KPH;
        m_speed_kph_sim_cfg.max          = MAX_SPEED_KPH;
        m_speed_kph_sim_cfg.incr         = SPEED_KPH_INCREMENT;
        m_speed_kph_sim_cfg.start_at_max = false;
        sensorsim_init(&m_speed_kph_sim_state, &m_speed_kph_sim_cfg);
        m_crank_rpm_sim_cfg.min          = MIN_CRANK_RPM;
        m_crank_rpm_sim_cfg.max          = MAX_CRANK_RPM;
        m_crank_rpm_sim_cfg.incr         = CRANK_RPM_INCREMENT;
        m_crank_rpm_sim_cfg.start_at_max = false;
        sensorsim_init(&m_crank_rpm_sim_state, &m_crank_rpm_sim_cfg);
        m_cumulative_wheel_revs        = 0;
    /**@brief Function for starting application timers.
    static void application_timers_start(void)
        uint32_t csc_meas_timer_ticks;
        // Start application timers.
        err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
        csc_meas_timer_ticks = APP_TIMER_TICKS(SPEED_AND_CADENCE_MEAS_INTERVAL);
        err_code = app_timer_start(m_csc_meas_timer_id, csc_meas_timer_ticks, NULL);
    /**@brief Function for handling the Connection Parameter events.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail configuration parameter, but instead we use the
     *                event handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
        ble_conn_params_init_t connection_params_init;
        memset(&connection_params_init, 0, sizeof(connection_params_init));
        connection_params_init.p_conn_params                  = NULL;
        connection_params_init.first_conn_params_update_delay = FIRST_CONN_PARAMS_UPDATE_DELAY;
        connection_params_init.next_conn_params_update_delay  = NEXT_CONN_PARAMS_UPDATE_DELAY;
        connection_params_init.max_conn_params_update_count   = MAX_CONN_PARAMS_UPDATE_COUNT;
        connection_params_init.start_on_notify_cccd_handle    = m_cscs.meas_handles.cccd_handle;
        connection_params_init.disconnect_on_fail             = false;
        connection_params_init.evt_handler                    = on_conn_params_evt;
        connection_params_init.error_handler                  = conn_params_error_handler;
        err_code = ble_conn_params_init(&connection_params_init);
        ret_code_t err_code = bsp_indication_set(BSP_INDICATE_IDLE);
        // Prepare wakeup buttons.
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising");
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
    uint16_t min_int_upd, max_int_upd, slave_conn_upd, conn_sup_upd;
      ret_code_t err_code = NRF_SUCCESS;
        case BLE_GAP_EVT_CONNECTED:
        app_timer_start(m_test_conn_timer_id, MY_TIMEOUT, NULL);
        NRF_LOG_INFO("Connected");
        case BLE_GAP_EVT_CONN_PARAM_UPDATE:
        min_int_upd = p_ble_evt->evt.gap_evt.params.conn_param_update.conn_params.min_conn_interval;
        max_int_upd = p_ble_evt->evt.gap_evt.params.conn_param_update.conn_params.max_conn_interval;
        slave_conn_upd = p_ble_evt->evt.gap_evt.params.conn_param_update.conn_params.slave_latency;
        conn_sup_upd = p_ble_evt->evt.gap_evt.params.conn_param_update.conn_params.conn_sup_timeout;
        time_conn[1] = time_conn[0];
        NRF_LOG_INFO("Min int upd = %d, Max int upd = %d, Slave latency = %d, Conn sup time = %d", min_int_upd, max_int_upd, slave_conn_upd, conn_sup_upd);
        if (max_int_upd > 6)
                                           BLE_HCI_REMOTE_DEV_TERMINATION_DUE_TO_LOW_RESOURCES);
        time_conn[2] = time_conn[0] - time_conn[1];
        NRF_LOG_INFO("CONN_PARAM_UPDATE = %d, DISCONNECTED = %d", time_conn[1], time_conn[2]);
        app_timer_stop(m_test_conn_timer_id);
        time_conn[0] = 0;
        NRF_LOG_INFO("Disconnected");
          ble_gap_phys_t const phys =
            .rx_phys = BLE_GAP_PHY_AUTO,
            .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
        uint32_t ram_start = 0;
        // Enable BLE stack.
     * @param[in]   event   Event generated by button press.
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
            case BSP_EVENT_WHITELIST_OFF:
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Clear bond information from persistent storage.
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
        if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
            err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    /**@brief Function for application main entry.
        bool erase_bonds;
        // Initialize.
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        sensor_simulator_init();
        conn_params_init();
        peer_manager_init();
        // Start execution.
        NRF_LOG_INFO("Cycling Speed and Cadence example started.");
        application_timers_start();
        advertising_start(erase_bonds);
        // Enter main loop.
        for (;;)
            idle_state_handle();
    I want to clarify about the part of the code that is described in the BLE_GAP_EVT_CONN_PARAM_UPDATE event.
    I make the disconnection in this way, because it is during the second connection that a stable connection occurs and you can already begin to transfer data. Just during the shutdown, I clearly observe how much time it takes to complete the connection.
    If disconnection is not done, then another 3 reconnections occur with the parameters of the connection interval equal to 997.5 ms.
    The time obtained using the timer, I also observe with an oscilloscope, so the time display is correct.
    I experimented with chips BT840F (analog nRF52840) and nRF52832 (on nRF52832 DK) and an example of ble_app_cscs. The results were getting exactly the same.
    Below is the result that I did on nRF52832:
    Thank you in advance
    Did you check the return values from sending the notifications (or start sending data function).
     It is the central that decides the connection interval on connection, not the peripheral, so it will be 7.5ms when first connecting.
    I think the reason of your delay might be that you haven't enabled notifications correctly. You will have to do this from your central (phone). How and when do you do this?
    Also what app are you using on your phone? I suggest using the nRFConnect app if you aren't already.
    Simon
