NRF9160-DK - LED 4 fails to blink on the kit.
Hi, I am in the initial stages of starting development with nRF9160-DK. At this step, the LED 4 on the board absolutely does not blink. I have tried taking the kit to different places too, for better connectivity but with no luck.
How can I troubleshoot it?
  • Hi, I successfully updated the firmware on the kit. What are the next steps in resolving the connectivity issue?
    How do I check if this has fixed the connectivity issue?
  • Good to hear that you were able to update the FW.
    The next step is to go back to my previous comment, click here. Please follow the instructions I gave there.
  • Hi I tried to follow the steps. The log shows this:
    10:41:32.657
    Application data folder: C:\Users\kbarde\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    10:41:37.382
    Modem port is opened
    10:43:53.345
    Error: 'AT+CFUN=1 ' timed out
    10:43:58.930
    10:45:30.433
    Error: 'AT+CGSN=1 ' timed out
    10:45:40.729
    Error: 'AT+CGSN=1AT+CGMI ' timed out
    10:45:46.125
    Error: 'AT+CGMI ' timed out
    The Terminal output is:
    AT+CFUN?
    ***** Booting Zephyr OS v1.13.99-ncs2 *****
    Secure Boot: configure flash
    Secure Boot: SPU: set region 0 as Secure
    Secure Boot: SPU: set region 1 as Secure
    Secure Boot: SPU: set region 2 as Secure
    Secure Boot: SPU: set region 3 as Secure
    Secure Boot: SPU: set region 4 as Secure
    Secure Boot: SPU: set region 5 as Secure
    Secure Boot: SPU: set region 6 as Secure
    Secure Boot: SPU: set region 7 as Secure
    Secure Boot: SPU: set Flash region 8 as Non-Secure
    Secure Boot: SPU: set Flash region 9 as Non-Secure
    Secure Boot: SPU: set Flash region 10 as Non-Secure
    Secure Boot: SPU: set Flash region 11 as Non-Secure
    Secure Boot: SPU: set Flash region 12 as Non-Secure
    Secure Boot: SPU: set Flash region 13 as Non-Secure
    Secure Boot: SPU: set Flash region 14 as Non-Secure
    Secure Boot: SPU: set Flash region 15 as Non-Secure
    Secure Boot: SPU: set Flash region 16 as Non-Secure
    Secure Boot: SPU: set Flash region 17 as Non-Secure
    Secure Boot: SPU: set Flash region 18 as Non-Secure
    Secure Boot: SPU: set Flash region 19 as Non-Secure
    Secure Boot: SPU: set Flash region 20 as Non-Secure
    Secure Boot: SPU: set Flash region 21 as Non-Secure
    Secure Boot: SPU: set Flash region 22 as Non-Secure
    Secure Boot: SPU: set Flash region 23 as Non-Secure
    Secure Boot: SPU: set Flash region 24 as Non-Secure
    Secure Boot: SPU: set Flash region 25 as Non-Secure
    Secure Boot: SPU: set Flash region 26 as Non-Secure
    Secure Boot: SPU: set Flash region 27 as Non-Secure
    Secure Boot: SPU: set Flash region 28 as Non-Secure
    Secure Boot: SPU: set Flash region 29 as Non-Secure
    Secure Boot: SPU: set Flash region 30 as Non-Secure
    Secure Boot: SPU: set Flash region 31 as Non-Secure
    Secure Boot: configure SRAM
    Secure Boot: SPU: set SRAM region 0 as Secure
    Secure Boot: SPU: set SRAM region 1 as Secure
    Secure Boot: SPU: set SRAM region 2 as Secure
    Secure Boot: SPU: set SRAM region 3 as Secure
    Secure Boot: SPU: set SRAM region 4 as Secure
    Secure Boot: SPU: set SRAM region 5 as Secure
    Secure Boot: SPU: set SRAM region 6 as Secure
    Secure Boot: SPU: set SRAM region 7 as Secure
    Secure Boot: SPU: set SRAM region 8 as Non-Secure
    Secure Boot: SPU: set SRAM region 9 as Non-Secure
    Secure Boot: SPU: set SRAM region 11 as Non-Secure
    Secure Boot: SPU: set SRAM region 12 as Non-Secure
    Secure Boot: SPU: set SRAM region 13 as Non-Secure
    Secure Boot: SPU: set SRAM region 14 as Non-Secure
    Secure Boot: SPU: set SRAM region 15 as Non-Secure
    Secure Boot: SPU: set SRAM region 16 as Non-Secure
    Secure Boot: SPU: set SRAM region 17 as Non-Secure
    Secure Boot: SPU: set SRAM region 18 as Non-Secure
    Secure Boot: SPU: set SRAM region 19 as Non-Secure
    Secure Boot: SPU: set SRAM region 20 as Non-Secure
    Secure Boot: SPU: set SRAM region 21 as Non-Secure
    Secure Boot: SPU: set SRAM region 22 as Non-Secure
    Secure Boot: SPU: set SRAM region 23 as Non-Secure
    Secure Boot: SPU: set SRAM region 24 as Non-Secure
    Secure Boot: SPU: set SRAM region 25 as Non-Secure
    Secure Boot: SPU: set SRAM region 26 as Non-Secure
    Secure Boot: SPU: set SRAM region 27 as Non-Secure
    Secure Boot: SPU: set SRAM region 28 as Non-Secure
    Secure Boot: SPU: set SRAM region 29 as Non-Secure
    Secure Boot: SPU: set SRAM region 30 as Non-Secure
    Secure Boot: SPU: set SRAM region 31 as Non-Secure
    Secure Boot: configure peripherals
    Secure Boot: MSP_NS 200265f0
    Secure Boot: prepare to jump to Non-Secure image
    The AT host sample started
    AT+CFUN?
    +CFUN: 4
    OK
    AT+CFUN=1
    OK
    AT+CFUN=1
    AT+CFUN=1
    AT+CGSN=1
    AT+CGSN=1AT+CGMI
    AT+CGMI
  • The log file is attached here. Please observe that log says "Error: At command timed out"
    Please advise on how to troubleshoot this.
    Thanks.log march 11.docx
  • uicr_tcxo.hexMy apologies for this being so difficult. We are aware that there are some issues, and we working with a solution.
    Can you please try to reset the board and see what this does? After this try power cycling the board once.
    Then, if that does not fix the solution, please program the attached file using:
    nrfjprog --program uicr_tcxo.hex --sectorerase -f nrf91 -r --verify
    This file will fix the config of 32 MHz temperature compensated crystal oscillator (TCXO) in UICR.
    After this, try to run the at_client example one more time.
