nrf24l01+, pcb mifa antenna design
Hello guys,
I tried to design a pcb antenna for a nrf24l01+, since my company doesnt allow to buy cheap smd breakout board version from china anymore
The pcb stats of the producer:
  • 2-layer FR4 1.55mm (61.023mil)  thickness, εr = 4.6
  • Copper thickness, 35μm (1.378mil)
What I used:
This results into following desgin block:
The antenna area is clear of any signals aswell as ground on top or bottom layer.
Since I have absolutly zero experience with RF antenna design I would like to have some opinions regarding my design.
Thanks so far,
Joe
  • I adjusted the width of all traces to the pads width without spacing violations.
    Thank you so much for guiding me through this.
    Not really looking forward to solder this since 0402 is really painful.
    Anyway I going to give reply when everything is tested and working perfectly obviously.
  • Remove some of the ground plane around the matching network components to reduce capacitance to ground, like this (inside the black rectangle)
    Then you're good
  • Actually it's pretty easy if you don't use a soldering iron.  Ideally you never ever use a soldering iron with SMT parts.  The thermal stresses from the iron can easily cause the parts to crack and this creates some really difficult to find failures.
    Easiest approach is just buy a stencil and paste the board, then hand place the parts and use a hot air reflow gun.
    You can get the hot air gun for about $150. You need a good set of fine tweezers (digikey or mouser carry these), you need a syringe of type 3 lead free no-clean paste (chipworks on mouser or digikey). I normally preheat the board to 100C on a cast iron hotplate on its lowest setting with a nonstick surface. Then reflow gun with low airflow set to about 320C and just work it till you see everything flow and center.
    You can get an inexpensive stencil here: https://www.oshstencils.com/
    For this board you can probably do a polyimide  stencil, but most of my work is finer pitch so I generally go for the stainless steel stencil.  You will have to create the windowpane pattern for the nRF in you ECAD software everything else can probably use the mask  or copper pad layer for the stencil pattern.
    You can get a very nice reflow gun here: https://www.sra-solder.com/
    The Aoyue brand is very reliable.
    If your eyes are still good you should be able to place the parts without a microscope.  Though an inexpensive stereo microscope on a boom is an invaluable tool for electronics work.
    This company has high quality and inexpensive scopes: https://www.amscope.com/
    I still hand place all my prototype boards and most of the stuff that has to go through certification.  I can easily build up a complicated board in an hour to two vs. a week for a quick turn CM and I do it at a fraction of the cost.  Once I prove out a design then I can turn it over to my contract manufacturer.
  • Good catch! I had forgotten you did that in the reference design.
  • And so JoE1205 is clear on this, you remove the ground pour on just the top layer (not the bottom layer) and only in that little rectangle.  You'll have to remove those two ground vias in the rectangle too.
