nRF9160 Dev Kit Bricked after MODEM update to v1.0.0
Hi, I’m located in Liège, BELGIUM.
Using the nRF9160DK, an orange SIM card, MODEM firmware mfw_nrf9160_0.7.0-15.alpha I managed to make run some sample code:
  • mqtt_simple, using a mosquitto broker on a Ubuntu machine in our premises
  • http_application_update, using an upgrade file uploaded in nrfcloud as the sample guidelines suggest
    • The download hostname « s3.amazonaws.com » could not be resolved.
      So, I directly used the IP address of s3.amazonaws.com (sent back by PING).
      This seemed to be a known problem of the version of the MODEM firmware.
      • Although I added the options « DNS resolver » et donné DNS Sever 1 « 8.8.8.8 » et DNS Sever 2 « 8.8.4.4 », the download hostname « s3.amazonaws.com » could not be resolved
So, as suggested on several posts/tickets in the forum, I updated the MODEM firmware to the latest version v1.0.0 using nRF Programmer. I also updated all the tools, the SEGGER Embedded Studio (4.18 win x64) and the NCS folder to v1.0.0 as suggested in https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/how-to-get-production-version-v1-0-0-to-nrf9160
I can assure you that I always use the “erase all” button in the nRF Programmer before writing an application merged hex file.
Updating the modem firmware started to raise a lot of problems for which I can’t find any solution and so my board is more or less bricked!
  1.  I can’t program the MODEM to back to previous versions. This leads to errors. Whether timeout or another error.
  2.  I can’t run at_client, asset_tracker nor http_application_update.
  • at_client leads to kernel panic.
This kernel panic is referenced in the forum https://devzone.nordicsemi.com/f/nordic-q-a/49264/unable-to-update-firmware-on-nrf9160/196300#196300
I did the upgrade of the modem using the programmer. But I cannot use at_client to check the version.
SPM: NS image at 0xc000
SPM: NS MSP at 0x20023b68
SPM: NS reset vector at 0xe325
SPM: prepare to jump to Non-Secure image.
bsdlib irrecoverable error: 3
ASSERTION FAIL [0] @ ../src/main.c:23
***** Kernel Panic! *****
Current thread ID = 0x20021a80
Faulting instruction address = 0x217c8
  • http_applation_update  leads also to kernel panic
***** Booting Zephyr OS build v1.14.99-ncs2-495-ga8933a2ead01 *****
[00:00:00.007,324] <inf> mcuboot: Starting bootloader
[00:00:00.015,991] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, cop        y_done=0x3, image_ok=0x3
[00:00:00.029,418] <inf> mcuboot: Scratch: magic=unset, swap_type=0x1, copy_done        =0x3, image_ok=0x3
[00:00:00.042,144] <inf> mcuboot: Boot source: primary slot
[00:00:00.054,138] <inf> mcuboot: Swap type: none
[00:00:00.389,068] <inf> mcuboot: Bootloader chainload address offset: 0xc000
[00:00:00.396,789] <inf> mcuboot: Jumping to the first image slot
Flash region            Domain          Permissions
00 0x00000 0x08000      Secure          rwxl
01 0x08000 0x10000      Secure          rwxl
02 0x10000 0x18000      Secure          rwxl
03 0x18000 0x20000      Non-Secure      rwxl
04 0x20000 0x28000      Non-Secure      rwxl
05 0x28000 0x30000      Non-Secure      rwxl
06 0x30000 0x38000      Non-Secure      rwxl
07 0x38000 0x40000      Non-Secure      rwxl
08 0x40000 0x48000      Non-Secure      rwxl
09 0x48000 0x50000      Non-Secure      rwxl
10 0x50000 0x58000      Non-Secure      rwxl
11 0x58000 0x60000      Non-Secure      rwxl
12 0x60000 0x68000      Non-Secure      rwxl
13 0x68000 0x70000      Non-Secure      rwxl
14 0x70000 0x78000      Non-Secure      rwxl
15 0x78000 0x80000      Non-Secure      rwxl
16 0x80000 0x88000      Non-Secure      rwxl
17 0x88000 0x90000      Non-Secure      rwxl
18 0x90000 0x98000      Non-Secure      rwxl
19 0x98000 0xa0000      Non-Secure      rwxl
20 0xa0000 0xa8000      Non-Secure      rwxl
21 0xa8000 0xb0000      Non-Secure      rwxl
22 0xb0000 0xb8000      Non-Secure      rwxl
23 0xb8000 0xc0000      Non-Secure      rwxl
24 0xc0000 0xc8000      Non-Secure      rwxl
25 0xc8000 0xd0000      Non-Secure      rwxl
26 0xd0000 0xd8000      Non-Secure      rwxl
27 0xd8000 0xe0000      Non-Secure      rwxl
28 0xe0000 0xe8000      Non-Secure      rwxl
29 0xe8000 0xf0000      Non-Secure      rwxl
30 0xf0000 0xf8000      Non-Secure      rwxl
31 0xf8000 0x100000     Non-Secure      rwxl
Non-secure callable region 0 placed in flash region 2 with size 32.
SRAM region             Domain          Permissions
00 0x00000 0x02000      Secure          rwxl
01 0x02000 0x04000      Secure          rwxl
02 0x04000 0x06000      Secure          rwxl
03 0x06000 0x08000      Secure          rwxl
04 0x08000 0x0a000      Secure          rwxl
05 0x0a000 0x0c000      Secure          rwxl
06 0x0c000 0x0e000      Secure          rwxl
07 0x0e000 0x10000      Secure          rwxl
08 0x10000 0x12000      Non-Secure      rwxl
09 0x12000 0x14000      Non-Secure      rwxl
10 0x14000 0x16000      Non-Secure      rwxl
11 0x16000 0x18000      Non-Secure      rwxl
12 0x18000 0x1a000      Non-Secure      rwxl
13 0x1a000 0x1c000      Non-Secure      rwxl
14 0x1c000 0x1e000      Non-Secure      rwxl
15 0x1e000 0x20000      Non-Secure      rwxl
16 0x20000 0x22000      Non-Secure      rwxl
17 0x22000 0x24000      Non-Secure      rwxl
18 0x24000 0x26000      Non-Secure      rwxl
19 0x26000 0x28000      Non-Secure      rwxl
20 0x28000 0x2a000      Non-Secure      rwxl
21 0x2a000 0x2c000      Non-Secure      rwxl
22 0x2c000 0x2e000      Non-Secure      rwxl
23 0x2e000 0x30000      Non-Secure      rwxl
24 0x30000 0x32000      Non-Secure      rwxl
25 0x32000 0x34000      Non-Secure      rwxl
26 0x34000 0x36000      Non-Secure      rwxl
27 0x36000 0x38000      Non-Secure      rwxl
28 0x38000 0x3a000      Non-Secure      rwxl
29 0x3a000 0x3c000      Non-Secure      rwxl
30 0x3c000 0x3e000      Non-Secure      rwxl
31 0x3e000 0x40000      Non-Secure      rwxl
Peripheral              Domain          Status
00 NRF_P0               Non-Secure      OK
01 NRF_CLOCK            Non-Secure      OK
02 NRF_RTC1             Non-Secure      OK
03 NRF_NVMC             Non-Secure      OK
04 NRF_UARTE1           Non-Secure      OK
05 NRF_UARTE2           Secure          SKIP
06 NRF_TWIM2            Non-Secure      OK
07 NRF_SPIM3            Non-Secure      OK
08 NRF_TIMER0           Non-Secure      OK
09 NRF_TIMER1           Non-Secure      OK
10 NRF_TIMER2           Non-Secure      OK
11 NRF_SAADC            Non-Secure      OK
12 NRF_PWM0             Non-Secure      OK
13 NRF_PWM1             Non-Secure      OK
14 NRF_PWM2             Non-Secure      OK
15 NRF_PWM3             Non-Secure      OK
16 NRF_IPC              Non-Secure      OK
17 NRF_VMC              Non-Secure      OK
18 NRF_FPU              Non-Secure      OK
19 NRF_EGU1             Non-Secure      OK
20 NRF_EGU2             Non-Secure      OK
21 NRF_GPIOTE1          Non-Secure      OK
SPM: NS image at 0x18200
SPM: NS MSP at 0x20026d20
SPM: NS reset vector at 0x1b225
ASSERTION FAIL [0] @ ../src/main.c:33
Current thread ID = 0x20023638
Faulting instruction address = 0x2fa76
  • asset_tracker constantly reboot without entering the non secure main.c
00 0x00000 0x08000      Secu***** Booting Zephyr OS build v1.14.99-ncs2-495-ga89
33a2ead01 *****
01 0x08000 0x10000      Non-Secure      rwxl
02 0x10000 0x18000      Non-Secure      rwxl
Non-secure callable region 0 placed in flash region 0 with size 32.
SPM: NS MSP at 0x2002b4b8
SPM: NS reset vector at 0x14335
Any idea. Now, I can't simply use the board.
Julien
