Hi:
The nRF52840 VDD voltage supply range is 1.7~3.6V
So if we provide 3.3V to VDD, the voltage ripple spec. is still 1.7~3.6V?
Or other spec. that we need follow? (for example +-100mV)
Thank you~~
Hi:
Thank you~~
Large ripple on VDD may impact analog performance (e.g. it can affect radio performance, adc, and clocks), but the chip will be functional within the entire operating conditions of 1.7-3.6V.
As a rule of thumb you should try to have sufficient decoupling to try to reduce ripple to less than 100mV.
Kenneth
Hi Kenneth:
As a rule of thumb you should try to have sufficient decoupling to try to reduce ripple to less than "100mV"
So the 100mV means +-50mV or +-100mv?
Thank you~~
Try to add decoupling so that VDD does not fall with more than 100mV during for instance BLE or GPIO activity, though maximum it should not fall more than 300mV.
So ideally less than +-50mV, and always less than +-150mV.
Kenneth
