Testing of Current time service
I am unable to test current time service example.I followed all the steps mentioned to test CTS Example.But, below are the log messages:
Again if I try to reset and try to connect to the device.The log messages are as below:
Please suggest me to rectify the errors and also the right way to test CTS example with 1SDK and mobile application.
Thanks & Regards,
Swathi P.
  • Hi Swathi,
    The disconnection reason is the service is not found on the server. You can use the nRF Connect mobile to configure GATT server as the following to test with the example.
    -Amanda H.
    Thank you.Your reply has helped me in testing CTS example.I was success  to connect,bond and discover service and print data on UART.But,If I try to delete bond information and try to scan and connect it is showing below log info and unable to discover service.
    If I erase the kit and then download after deleting bond information then it is working fine.Is CTS service always looking for whitelisted devices?Can you please explain me what exactly it does when we delete bond information on nRF Connect for mobile.
    In my project I cannot frequently erase and download.so please let me know if there is other way to Connect,pair and bond  and discover service after deleting bond information.
    Thanks & Regards,
    Swathi P
  • Hi Swathi,
    You can do Button 2 long push: Turn off whitelist during advertising or scanning. Please see the BSP BLE Button Assignments. Or You may add the following event handling to the PM callback in peer_manager_handler.c if you want to allow repairing like this:
    and have a loop to go through m_whitelist_peers[] array to check if there is an element inside that array is equal to m_peer_id. If not then you add it as a new node into the array like this:
    -Amanda H.
    Thank you for your suggestion.I have tried adding the below statements in main.c pm_evt_handler()
    I just replaced both the cases in pm_evt_handler.Even after deleting bond information I am able to connect by pairing.
    Is it not that pm_evt_handler in main.c you were talking about?
    I didn't find any PM callback  in peer_manager_handler.c.Can you give me the function name?
    Thanks & Regards,
    Swathi P.
  • Hi Swathi,
    case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED is in main.c.
    case PM_EVT_CONN_SEC_CONFIG_REQ is in peer_manager_handler.c Line 370. You can press Ctrl+Shift+f in Segger to search "PM_EVT_CONN_SEC_CONFIG_REQ".
    -Amanda H.
« 2 3 4 5 6 »
