Hi
Asset Tracker Build error:
How to install the missing module required for 'cbor'?
I have installed the nRF Connect SDK 1.3 via Toolchain Manager.
Hi
It should work out of the box using NCS 1.3 and the tooclahin manager on Windows. The cbor module is shipped together with all other modules in the toochain manager, and does not need special handling. You should see the module under v1.3.0\toolchain\opt\bin\Lib\site-packages\cbor. Can you try to install the toolchain again and see if the issue persists?
Hi Einar
It is working now after I removed the NCS 1.3 and re-installing it again (updating the toolchain does not work although I can see the modules under v1.3.0\toolchain\opt\bin\Lib\site-packages\cbor).
Thanks.
hi Einar,
i have the same question with NYP, i can see the cbor under that dir, but still compile asset tracker prokect can't be compiled
I was able to fix this by adding
