nRF52840 Dongle Windows 10 driver
I'm using a nRF52840 Dongle with connectivity_4.1.1 in my workstation without problems.
Recently, I deploy my custom application (using the dongle) to a new Windows 10 machine and the default drivers does not allow me to use the dongle.
Please, may I know if there is a distribution for the driver (see picture below) without installing nRF Connect Desktop
Thanks
  • Hello Karl,
    I hope you doing well, actually, in my project, I want to use the nrf52840 dongle for a PC, that doesn't have inbuilt Bluetooth. so I have seen a lot of reference videos for the nrf52840 dongle and they used nrf connect desktop app so after flashing some bootloader code custom dongle board enters into open boot loader mode, then in Bluetooth low energy option asks for a program flash then I gave yes for flashing. now it acts as a dongle so I can scan peripheral devices and connect them. so without using nrf connect app can we do it as an inbuilt Bluetooth and scan it as we do in Windows 10 ??. if yes how do we do that? and also after connecting the peripheral device how can we send that data from the peripheral device to the dongle and print it in a notepad??. I have already raised a query and there is no proper response. I am working on it for 2 months but I couldn't complete it. please help me to resolve this.
    Thank You.
    Karl is out of office this week, so I will handle your question.
    I couldn't find your ticket. Do you have a link?
    I understand what you want to do, but I have to disappoint you. It is not possible to use the nRF52840 dongle as a generic Bluetooth Dongle in Windows. Note that the nRF52840 only has Bluetooth Low Energy, and not Bluetooth Classic (what most audio over Bluetooth uses). Because it is lacking this, Windows will not accept it as a Bluetooth Dongle.
    I have not tested this, but it is possible to use it as a Bluetooth dongle on Linux, but it will only work with BLE devices.
    Even if you have a normal Bluetooth Dongle, it will not out of the box dump that information into a notepad (I assume you mean a .txt document). You would have to write a desktop application that does this.
    Edvin
  • It is not possible to use the nRF52840 dongle as a generic Bluetooth Dongle in Windows. Note that the nRF52840 only has Bluetooth Low Energy, and not Bluetooth Classic (what most audio over Bluetooth uses). Because it is lacking this, Windows will not accept it as a Bluetooth Dongle.
    So, you mean we need to use the nrf connect desktop application and Bluetooth low energy app to scan the peripheral devices right.? if so can we use the Peripheral to central example directly to connect the peripheral device? i tried ble_app_blinky and ble_app_blinky_c examples for LBS so I am sending button state data from ble_app_blinky(peripheral) to ble_app_blinky_c(Central) it's working fine.
    And now I wanted to do for the nrf52832 dev kit to the nrf52840 dongle, yes as of now I can use the ble_app_blinky code for the peripheral to send the button state data to the nrf52840 dongle. but here when i try to flash the dongle from nrf connect desktop app it asks for the flashing, I gave yes and flashed the dongle. so now i want the source file of it because I example I have is usbd_cdc_acm which can send/receive the data. but it didn't act as a dongle like scanning the peripheral devices.
    so please give me the source files of it or tell me if any comfortable examples are available in SDK.
    ok, I got it, if it's possible to send the data to the terminal it's enough.
      Thank You.
    I don't think any of these questions are related to the original question from this post. I can answer this one, but for follow ups, please create a new ticket. Feel free to link to this one for background information.
    Actually, the FW that is flashed on the dongle by nRF Connect for Desktop -> Bluetooth LE is a modified version of the SDK\examples\connectivity\ble_connectivity. This is a proprietary serialization API that windows doesn't know about, so you will never be able to use it as a BLE dongle for the OS. But it is possible to use it for scripting, such as using a python application to send and receive the USB messages to start scanning, connecting and so on (the things that nRF Connect for Desktop does). However, we don't recommend this for production. It is a development tool, and it should only be used for testing. If you want to test it, you can search for pc-ble-driver. There is a .c variant and a python variant. This will be the application that communicates (UART or USB) with the dongle. You will find some information on how to set up and use it on the github repository for pc-ble-driver or pc-ble-driver-py. Just note that this is not something that we officially recommend, and it is a bit difficult to use.
    If there is a particular BLE peripheral that you want to connect to, I suggest you rather write an application for the nRF that will scan for and connect to that particular device. Then you can enable notifications on whatever characteristic you need, and then forward that data to the UART/USB. Then you would need an application (python, for example) running on your computer that takes the data from the COM port, and saves it in a txt file, or prints it to a log, or whatever you want to do with it.
    Edvin
    Thanks for the useful information.
    this is my last question Are there any other ways to send the sensor data from the nrf52832 dev kit to a Bluetooth-less desktop wirelessly.??
    if yes I will raise a new ticket and share the case ID.
    Thank You.
