nRF5340 FOTA upgrade over Bluetooth
I couldn't launch FOTA upgrade over Bluetooth for nRF5340 PDK. I followed this guide developer.nordicsemi.com/.../ug_nrf5340.html to fulfil FOTA upgrade for nRF5340 PDK. I used /home/roman/nordic/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr sample and modified it according to the guide (merely added CONFIG_MCUMGR_SMP_BT=y in prj.conf file). I built this sample and flashed it to nRF5340. A added a minor change to print new line and built it again. I uploaded a file /home/roman/SeggerProjects/smp_svr/build_nrf5340pdk_nrf5340_cpuapp/zephyr/app_update.bin to a mobile phone. After that, I launched an app nRF Connect for Mobile, connected to nRF5340 PDK (Zephyr). See screenshots.
I opened DFU, located uploaded app_update.bin and selected Test and Confirm option.
And after it, I only saw the next screen:
You can see a Log file from nRF Connect for Mobile:
nRF Connect, 2020-07-07
Zephyr (EB:F6:DA:7F:DA:51)
V	11:07:33.807	Connecting to EB:F6:DA:7F:DA:51...
D	11:07:33.807	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D	11:07:35.281	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	11:07:35.281	Connected to EB:F6:DA:7F:DA:51
D	11:07:35.285	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
D	11:07:35.307	wait(1600ms)
V	11:07:36.910	Discovering services...
D	11:07:36.910	gatt.discoverServices()
D	11:07:36.929	[Callback] Services discovered with status: 0
I	11:07:36.929	Services discovered
V	11:07:36.949	Generic Attribute (0x1801)
- Service Changed [I] (0x2A05)
   Client Characteristic Configuration (0x2902)
- Client Supported Features [R W] (0x2B29)
- Database Hash [R] (0x2B2A)
Generic Access (0x1800)
- Device Name [R] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84)
- SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48)
D	11:07:36.950	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
I	11:07:40.131	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms)
V	11:08:02.048	[McuMgr] Connecting...
D	11:08:02.051	[McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
D	11:08:02.117	[McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
I	11:08:02.122	[McuMgr] Connected to EB:F6:DA:7F:DA:51
D	11:08:02.125	[McuMgr] wait(1600)
V	11:08:03.733	[McuMgr] Discovering services...
D	11:08:03.759	[McuMgr] gatt.discoverServices()
I	11:08:03.802	[McuMgr] Services discovered
V	11:08:03.819	[McuMgr] Primary service found
I	11:08:03.826	[McuMgr] Service Changed characteristic found on a bonded device
D	11:08:03.831	[McuMgr] gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
V	11:08:03.836	[McuMgr] Enabling indications for 00002a05-0000-1000-8000-00805f9b34fb
D	11:08:03.849	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x02-00)
I	11:08:03.936	[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 02-00
I	11:08:03.961	[McuMgr] Service Changed notifications enabled
V	11:08:03.965	[McuMgr] Requesting new MTU...
D	11:08:03.968	[McuMgr] gatt.requestMtu(515)
I	11:08:04.027	[McuMgr] MTU changed to: 65
D	11:08:04.031	[McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
V	11:08:04.035	[McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
D	11:08:04.037	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I	11:08:04.657	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
I	11:08:04.667	[McuMgr] Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
D	11:08:04.713	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11)
D	11:08:04.715	[McuMgr] [Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11)
D	11:08:05.189	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDED (12)
I	11:08:05.190	Device bonded
D	11:08:05.206	[McuMgr] [Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDED (12)
I	11:08:05.210	[McuMgr] Device bonded
I	11:08:05.557	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms)
I	11:08:05.558	[McuMgr] Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms)
And a debug output from smp_svr sample to UART:
*** Booting Zephyr OS build v2.3.0-rc1-ncs1  ***
[00:00:00.006,011] <inf> smp_sample: os_mgmt_register_group()
[00:00:00.006,042] <inf> smp_sample: img_mgmt_register_group()
[00:00:00.006,042] <inf> smp_sample: stat_mgmt_register_group()
[00:00:00.006,042] <inf> smp_sample: start_smp_bluetooth()
[00:00:00.009,429] <inf> smp_bt_sample: smp_bt_register()
[00:00:00.009,460] <inf> smp_sample: build time: Jul  6 2020 23:40:42
[00:00:00.025,054] <inf> smp_bt_sample: Bluetooth initialized
[00:00:00.048,461] <inf> smp_bt_sample: Advertising successfully started
[00:00:12.934,600] <inf> smp_bt_sample: Connected
And nothing happened after it even I was waiting for a long time.
If I use another mobile app - nRF Toolbox, then I have a more meaningful warning to add Init file, which I don't have and about which there's nothing in the guide.
Can you point me what I should do to realise FOTA upgrade? Maybe I didn't find some appropriate guides, because the guide here developer.nordicsemi.com/.../ug_nrf5340.html is so short and general.
  • I am not aware of any such solutions when using NCS (the nRF5340 only supports NCS, not the nRF5 SDK), but I would be surprised if it wasn't/or is being worked on.
    But I will investigate/ask internally and get back to you.
    Simon
  • Thank you, Simon!
    Is Nordic Semiconductor going to provide a solution of OTA DFU for nRF5340? I am absolutely sure that it's vitally necessary! We will not release our devices without such functionality. I hope that your colleagues will present the sample soon. Also, thank them for their effort.
    I’m eager to receive your response and the OTA DFU example for nRF5340.
    Simon, hello again!
    I used nRF Connect SDK when I built and run a provided example and not nRF5 SDK. This is example github.com/.../smp_svr. So, it means that NCS supports OTA DFU properly and a problem is not that nRF5340 supports only NCS and not nRF5 SDK, the problem is that the example doesn't work in the case of specifically nRF5340. It seems that I didn't understand why you mentioned nRF5 SDK.
  • Okay, I am really sorry for the confusion. My bad. I was not aware that nRF Connect for Mobile supported the mcumgr SMP/Bluetooth Protocol.
    I read your previous answer more thoroughly and saw that you were indeed able to perform a DFU with NCS, nRF52840, and the nRF C. app.
    I just took a look at the features of the app as well, and it said the following: "Supports McuMgr,profile that lets the user control and update Zephyr-based devices".
    So I will now investigate the issue regarding nRF5340, and why it doesn't work with that device specifically.
    Again, sorry for the inconvenience.
    Simon
  • I was not able to upload a sample to neither the nRF52840 nor the nRF5340, and I guess there is something wrong with the nRF Connect mobile app. The developer(s) responsible for that app are currently on vacation, so I'm not sure what's causing this.
    However, you said you were able to make it work using the nRF5280 DK, could you provide me in details all the steps for that. Such that I have a reference to look at when investigating the issues with the nRF5340 DK.
    Simon
