nRF5340 FOTA upgrade over Bluetooth
I couldn't launch FOTA upgrade over Bluetooth for nRF5340 PDK. I followed this guide developer.nordicsemi.com/.../ug_nrf5340.html to fulfil FOTA upgrade for nRF5340 PDK. I used /home/roman/nordic/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr sample and modified it according to the guide (merely added CONFIG_MCUMGR_SMP_BT=y in prj.conf file). I built this sample and flashed it to nRF5340. A added a minor change to print new line and built it again. I uploaded a file /home/roman/SeggerProjects/smp_svr/build_nrf5340pdk_nrf5340_cpuapp/zephyr/app_update.bin to a mobile phone. After that, I launched an app nRF Connect for Mobile, connected to nRF5340 PDK (Zephyr). See screenshots.
I opened DFU, located uploaded app_update.bin and selected Test and Confirm option.
And after it, I only saw the next screen:
You can see a Log file from nRF Connect for Mobile:
nRF Connect, 2020-07-07
Zephyr (EB:F6:DA:7F:DA:51)
V	11:07:33.807	Connecting to EB:F6:DA:7F:DA:51...
D	11:07:33.807	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D	11:07:35.281	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	11:07:35.281	Connected to EB:F6:DA:7F:DA:51
D	11:07:35.285	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
D	11:07:35.307	wait(1600ms)
V	11:07:36.910	Discovering services...
D	11:07:36.910	gatt.discoverServices()
D	11:07:36.929	[Callback] Services discovered with status: 0
I	11:07:36.929	Services discovered
V	11:07:36.949	Generic Attribute (0x1801)
- Service Changed [I] (0x2A05)
   Client Characteristic Configuration (0x2902)
- Client Supported Features [R W] (0x2B29)
- Database Hash [R] (0x2B2A)
Generic Access (0x1800)
- Device Name [R] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84)
- SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48)
D	11:07:36.950	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
I	11:07:40.131	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms)
V	11:08:02.048	[McuMgr] Connecting...
D	11:08:02.051	[McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
D	11:08:02.117	[McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
I	11:08:02.122	[McuMgr] Connected to EB:F6:DA:7F:DA:51
D	11:08:02.125	[McuMgr] wait(1600)
V	11:08:03.733	[McuMgr] Discovering services...
D	11:08:03.759	[McuMgr] gatt.discoverServices()
I	11:08:03.802	[McuMgr] Services discovered
V	11:08:03.819	[McuMgr] Primary service found
I	11:08:03.826	[McuMgr] Service Changed characteristic found on a bonded device
D	11:08:03.831	[McuMgr] gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
V	11:08:03.836	[McuMgr] Enabling indications for 00002a05-0000-1000-8000-00805f9b34fb
D	11:08:03.849	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x02-00)
I	11:08:03.936	[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 02-00
I	11:08:03.961	[McuMgr] Service Changed notifications enabled
V	11:08:03.965	[McuMgr] Requesting new MTU...
D	11:08:03.968	[McuMgr] gatt.requestMtu(515)
I	11:08:04.027	[McuMgr] MTU changed to: 65
D	11:08:04.031	[McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
V	11:08:04.035	[McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
D	11:08:04.037	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I	11:08:04.657	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
I	11:08:04.667	[McuMgr] Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
D	11:08:04.713	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11)
D	11:08:04.715	[McuMgr] [Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11)
D	11:08:05.189	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDED (12)
I	11:08:05.190	Device bonded
D	11:08:05.206	[McuMgr] [Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDED (12)
I	11:08:05.210	[McuMgr] Device bonded
I	11:08:05.557	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms)
I	11:08:05.558	[McuMgr] Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms)
And a debug output from smp_svr sample to UART:
*** Booting Zephyr OS build v2.3.0-rc1-ncs1  ***
[00:00:00.006,011] <inf> smp_sample: os_mgmt_register_group()
[00:00:00.006,042] <inf> smp_sample: img_mgmt_register_group()
[00:00:00.006,042] <inf> smp_sample: stat_mgmt_register_group()
[00:00:00.006,042] <inf> smp_sample: start_smp_bluetooth()
[00:00:00.009,429] <inf> smp_bt_sample: smp_bt_register()
[00:00:00.009,460] <inf> smp_sample: build time: Jul  6 2020 23:40:42
[00:00:00.025,054] <inf> smp_bt_sample: Bluetooth initialized
[00:00:00.048,461] <inf> smp_bt_sample: Advertising successfully started
[00:00:12.934,600] <inf> smp_bt_sample: Connected
And nothing happened after it even I was waiting for a long time.
If I use another mobile app - nRF Toolbox, then I have a more meaningful warning to add Init file, which I don't have and about which there's nothing in the guide.
Can you point me what I should do to realise FOTA upgrade? Maybe I didn't find some appropriate guides, because the guide here developer.nordicsemi.com/.../ug_nrf5340.html is so short and general.
  • I would suggest that you also try Device Manager instead of nRF Connect Mobile. Not sure if will solve the situation though.
    https://github.com/NordicSemiconductor/Android-nRF-Connect-Device-Manager
  • Good evening, Simon!
    Basically I followed this guide developer.nordicsemi.com/.../ug_nrf5340.html
    Firstly, according to "SMP Server Sample" (developer.nordicsemi.com/.../README.html I connected nRF52840 DK through USB, opened serial terminal "minicom -b 115200 -8 -D /dev/ttyACM0" and built and flashed MCUboot, using the following commands:
    west build -b nrf52840dk_nrf52840 -d build_mcuboot bootloader/mcuboot/boot/zephyr
    west flash -d build_mcuboot
    UART output after it:
    [00:00:00.003,143] <inf> mcuboot: Starting bootloader
    [00:00:00.009,460] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    [00:00:00.019,714] <inf> mcuboot: Boot source: none
    [00:00:00.025,238] <wrn> mcuboot: Failed reading image headers; Image=0
    [00:00:00.032,775] <err> mcuboot: Unable to find bootable image
    Secondly, I located "/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr" example, added the line "CONFIG_MCUMGR_SMP_BT=y" to "prj.conf", open nRF Connect SDK Project from SEGGER Embeded Studio for ARM (see a screenshot below). And finally, I built and run the project: Build -> Build and Run.
    [00:00:00.003,204] <inf> mcuboot: Starting bootloader
    [00:00:00.009,613] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    [00:00:00.019,866] <inf> mcuboot: Boot source: none
    [00:00:00.025,482] <inf> mcuboot: Swap type: none
    [00:00:00.294,433] <inf> mcuboot: Bootloader chainload address offset: 0xc000
    [00:00:00.302,276] <inf> mcuboot: Jumping to the first image slot
    uart:~$
    Thirdly, I modified the example "SMP Server Sample" and merged a blinky example ("/ncs/zephyr/samples/basic/blinky") to clearly show the difference after upgrading new firmware. I built it and uploaded it to a mobile phone.
    And finally, I launched "nRF Connect for Mobile" app (Version 4.24.1) on the mobile phone, scanned, connected to my device with name "Zephyr", taped DFU, located new app_update.bin file and chose "Test and Confirm". After upgrading the firmware I could see a blinking led on the board.
    *** Booting Zephyr OS build v2.3.0-rc1-ncs1  ***        |  Cannot open /dev/ttyACM0!  |
    [00:00:00.003,143] <inf> mcuboot: Starting bootloader        |                             |
    [00:00:00.009,582] <inf> mcuboot: Primary image: magic=good, swap_type=0x2, copy_done=0x1, image_ok=0x1                +-----------------------------+
    [00:00:00.019,805] <inf> mcuboot: Boot source: none
    [00:00:00.025,421] <inf> mcuboot: Swap type: none
    [00:00:00.294,281] <inf> mcuboot: Bootloader chainload address offset: 0xc000
    [00:00:00.302,124] <inf> mcuboot: Jumping to the first image slot
    [00:00:30.927,429] <inf> smp_bt_sample: Connected
    [00:00:47.563,385] <inf> mcumgr_flash_mgmt: Erased 0x2d000 bytes of image slot
    [00:00:47.739,257] <inf> mcumgr_flash_mgmt: Erased 0x1000 bytes of image slot trailer
    uart:~$ *** Booting Zephyr OS build v2.3.0-rc1-ncs1  ***
    [00:00:00.009,643] <inf> mcuboot: Primary image: magic=good, swap_type=0x2, copy_done=0x1, image_ok=0x1
    [00:00:00.019,836] <inf> mcuboot: Boot source: none
    [00:00:00.025,451] <inf> mcuboot: Swap type: test
    [00:00:17.743,133] <inf> mcuboot: Bootloader chainload address offset: 0xc000
    [00:00:17.750,946] <inf> mcuboot: Jumping to the first image slot
    [00:00:17.692,169] <inf> smp_bt_sample: Connected
    [00:03:16.260,620] <wrn> bt_att: Unhandled ATT code 0x1d
    [00:03:17.310,913] <inf> smp_bt_sample: Disconnected (reason 0x13)
    [00:03:17.311,889] <inf> smp_bt_sample: Advertising successfully started
    uart:~$
    You can see output of "west status" command:
    === status of manifest (nrf):
    HEAD detached at v1.3.0
    nothing to commit, working tree clean
    === status of zephyr (zephyr):
    HEAD detached at bbd71e23a2
    === status of mcuboot (bootloader/mcuboot):
    HEAD detached at e81a207
    === status of mcumgr (modules/lib/mcumgr):
    HEAD detached at refs/heads/manifest-rev
    === status of nrfxlib (nrfxlib):
    HEAD detached at 3d0d9a5
    === status of cmock (test/cmock):
    === status of unity (test/cmock/vendor/unity):
    === status of mbedtls-nrf (mbedtls):
    === status of cmsis (modules/hal/cmsis):
    === status of canopennode (modules/lib/canopennode):
    === status of ci-tools (tools/ci-tools):
    === status of civetweb (modules/lib/civetweb):
    === status of fatfs (modules/fs/fatfs):
    === status of hal_nordic (modules/hal/nordic):
    === status of hal_st (modules/hal/st):
    === status of libmetal (modules/hal/libmetal):
    === status of lvgl (modules/lib/gui/lvgl):
    === status of mbedtls (modules/crypto/mbedtls):
    === status of net-tools (tools/net-tools):
    === status of open-amp (modules/lib/open-amp):
    === status of loramac-node (modules/lib/loramac-node):
    === status of openthread (modules/lib/openthread):
    === status of segger (modules/debug/segger):
    === status of tinycbor (modules/lib/tinycbor):
    === status of tinycrypt (modules/crypto/tinycrypt):
    === status of littlefs (modules/fs/littlefs):
    === status of mipi-sys-t (modules/debug/mipi-sys-t):
    === status of nrf_hw_models (modules/bsim_hw_models/nrf_hw_models):
    === status of edtt (tools/edtt):
    And this is a log from nRF Connect for Mobile of the upgrading process.
    nRF Connect, 2020-07-17
    Zephyr (D6:C4:F9:A2:02:AD)
    V	20:24:24.894	Connecting to D6:C4:F9:A2:02:AD...
    D	20:24:24.894	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	20:24:25.182	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	20:24:25.182	Connected to D6:C4:F9:A2:02:AD
    D	20:24:25.183	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    V	20:24:25.201	Discovering services...
    D	20:24:25.201	gatt.discoverServices()
    I	20:24:25.577	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D	20:24:25.796	[Callback] Services discovered with status: 0
    I	20:24:25.796	Services discovered
    V	20:24:25.814	Generic Attribute (0x1801)
    D	20:24:25.815	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    I	20:24:25.898	Connection parameters updated (interval: 50.0ms, latency: 0, timeout: 5000ms)
    V	20:24:32.251	[McuMgr] Connecting...
    D	20:24:32.256	[McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
    D	20:24:32.342	[McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
    I	20:24:32.346	[McuMgr] Connected to D6:C4:F9:A2:02:AD
    D	20:24:32.352	[McuMgr] wait(300)
    V	20:24:32.659	[McuMgr] Discovering services...
    D	20:24:32.670	[McuMgr] gatt.discoverServices()
    I	20:24:32.683	[McuMgr] Services discovered
    V	20:24:32.688	[McuMgr] Primary service found
    V	20:24:32.696	[McuMgr] Requesting new MTU...
    D	20:24:32.701	[McuMgr] gatt.requestMtu(515)
    I	20:24:32.900	[McuMgr] MTU changed to: 252
    D	20:24:32.911	[McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
    V	20:24:32.918	[McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
    D	20:24:32.924	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
    I	20:24:32.999	[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 01-00
    I	20:24:33.010	[McuMgr] Notifications enabled
    V	20:24:33.016	[McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
    D	20:24:33.021	[McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
    I	20:24:33.029	[McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 00-00-00-02-00-01-00-00-BF-FF
    A	20:24:33.036	[McuMgr] "Operation: READ
    Flags: 0
    Length: 2
    Group Id: 1 (IMAGE)
    Sequence Num: 0
    Command Id: 0 (STATE)
    Message: {}" sent
    I	20:24:33.301	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-F4-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-30-64-68-61-73-68-58-20-33-35-84-93-1A-03-FC-33-28-E0-77-2F-9C-37-3A-29-FD-CB-FD-14-B0-71-63-67-E8-20-3D-11-6C-BA-DB-F5-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-BF-64-73-6C-6F-74-01-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-30-64-68-61-73-68-58-20-33-35-84-93-1A-03-FC-33-28-E0-77-2F-9C-37-3A-29-FD-CB-FD-14-B0-71-63-67-E8-20-3D-11-6C-BA-DB-F5-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F4-66-61-63-74-69-76-65-F4-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75
    I	20:24:33.353	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 73-00-FF
    A	20:24:33.371	[McuMgr] "{"images":[{"slot":0,"version":"0.0.0","hash":"MzWEkxoD/DMo4HcvnDc6Kf3L/RSwcWNn6CA9EWy62/U=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false},{"slot":1,"version":"0.0.0","hash":"MzWEkxoD/DMo4HcvnDc6Kf3L/RSwcWNn6CA9EWy62/U=","bootable":true,"pending":false,"confirmed":false,"active":false,"permanent":false}],"splitStatus":0}" received
    V	20:24:33.382	[McuMgr] Uploading firmware...
    V	20:27:41.948	[McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
    D	20:27:41.951	[McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
    I	20:27:41.956	[McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 02-00-00-32-00-01-00-00-BF-67-63-6F-6E-66-69-72-6D-F4-64-68-61-73-68-58-20-A4-6A-65-82-BA-42-64-1E-DC-61-C2-D3-32-43-B2-58-BA-0C-47-BE-0E-71-96-A8-4B-F5-1F-89-FA-51-28-82-FF
    A	20:27:41.961	[McuMgr] "Operation: WRITE
    Flags: 0
    Length: 50
    Group Id: 1 (IMAGE)
    Sequence Num: 0
    Message: {"confirm":false,"hash":"pGplgrpCZB7cYcLTMkOyWLoMR74OcZaoS/UfifpRKII="}" sent
    I	20:27:42.250	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 03-00-00-F4-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-30-64-68-61-73-68-58-20-33-35-84-93-1A-03-FC-33-28-E0-77-2F-9C-37-3A-29-FD-CB-FD-14-B0-71-63-67-E8-20-3D-11-6C-BA-DB-F5-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-BF-64-73-6C-6F-74-01-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-30-64-68-61-73-68-58-20-A4-6A-65-82-BA-42-64-1E-DC-61-C2-D3-32-43-B2-58-BA-0C-47-BE-0E-71-96-A8-4B-F5-1F-89-FA-51-28-82-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F5-69-63-6F-6E-66-69-72-6D-65-64-F4-66-61-63-74-69-76-65-F4-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75
    I	20:27:42.288	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 73-00-FF
    A	20:27:42.297	[McuMgr] "{"images":[{"slot":0,"version":"0.0.0","hash":"MzWEkxoD/DMo4HcvnDc6Kf3L/RSwcWNn6CA9EWy62/U=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false},{"slot":1,"version":"0.0.0","hash":"pGplgrpCZB7cYcLTMkOyWLoMR74OcZaoS/UfifpRKII=","bootable":true,"pending":true,"confirmed":false,"active":false,"permanent":false}],"splitStatus":0}" received
    V	20:27:42.306	[McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
    D	20:27:42.310	[McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
    I	20:27:42.338	[McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 02-00-00-02-00-00-00-05-BF-FF
    A	20:27:42.343	[McuMgr] "Operation: WRITE
    Flags: 0
    Length: 2
    Group Id: 0 (OS)
    Sequence Num: 0
    Command Id: 5 (RESET)
    Message: {}" sent
    I	20:27:42.399	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 03-00-00-02-00-00-00-05-BF-FF
    A	20:27:42.408	[McuMgr] "{}" received
    D	20:27:47.568	[Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0)
    E	20:27:47.568	Error 8 (0x8): GATT CONN TIMEOUT
    I	20:27:47.568	Disconnected
    D	20:27:47.608	[McuMgr] [Callback] Connection state changed with status: 8 and new state: 0 (DISCONNECTED)
    W	20:27:47.632	[McuMgr] Error: (0x8): GATT CONN TIMEOUT
    I	20:27:47.637	[McuMgr] Disconnected
    D	20:27:47.658	[McuMgr] gatt.close()
    V	20:27:47.668	[McuMgr] Connecting...
    D	20:27:47.672	[McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
    D	20:27:47.684	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    D	20:28:17.698	[McuMgr] [Callback] Connection state changed with status: 133 and new state: 0 (DISCONNECTED)
    W	20:28:17.711	[McuMgr] Error: (0x85): GATT ERROR
    W	20:28:17.721	[McuMgr] Connection attempt timed out
    D	20:28:17.730	[McuMgr] gatt.close()
    D	20:28:17.740	gatt.close()
    D	20:28:17.742	wait(200)
    V	20:28:17.944	Connecting to D6:C4:F9:A2:02:AD...
    D	20:28:17.945	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	20:28:18.243	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	20:28:18.243	Connected to D6:C4:F9:A2:02:AD
    D	20:28:18.332	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    V	20:28:18.338	Discovering services...
    D	20:28:18.338	gatt.discoverServices()
    I	20:28:18.640	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D	20:28:18.866	[Callback] Services discovered with status: 0
    I	20:28:18.866	Services discovered
    V	20:28:18.882	Generic Attribute (0x1801)
    D	20:28:18.883	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    I	20:28:18.969	Connection parameters updated (interval: 50.0ms, latency: 0, timeout: 5000ms)
    I archived smp_svr project and modified smp_svr which was merged with blinky example.
    smp_svr.zipsmp_svr_modified.zip
    I recorded a video to demonstrate the upgrading process to you.
    I hope that I didn't skip anything. If you need some extra explanation from my side, just tell me.
  • Thank you, Lukáš! Is it an Android library or an application, which implements about the same functionality as nRF Connect for Mobile? Unfortunately, I couldn't find a way how to easily run it on my mobile, there's no ".apk" file. Should I download Android Studio and build this app myself to try? Sorry for a foolish question, but I didn't catch an idea of how to try your suggestion.
