SDK UART coexistence example problem
I am trying to follow the tutorial SDK UART coexistence example, but it seems like the last step cannot be completed. As you can see, that .hex file does not exist in the folder. Do you have any suggestion?
Thanks.
  • Hi Marry,
    I'm happy to help!
    If you're programming light_switch_client_nrf52832_xxAA to your nRF52833 DK you will get problems, as that project is for the nRF52832, and should be used if your board is a nRF52 DK. Instead, you should use light_switch_server_nrf52833_xxAA, which is for the nRF52833 DK. The hardware and layout of the DKs are different, so the buttons and LEDs are connected to different GPIOs, and as such, the buttons and LEDs on the nRF52833 DK will not work as expected with a project for another DK. For instance, LED 1 is P0.13 on the the nRF52833 DK, while on the nRF52 DK LED 1 is P0.17. If you want to, you can find the tables for the buttons and LEDs here and here for the nRF52833 DK and nRF52 DK respectively.
    Thank you, and have a great day yourself!
    Marte
  • Hi!
    Thank you, again extremely helpful answer! The only difference is that I was using SDK Mesh version 3.2.0. And there was no support for this board. But now I had a look over the newer version and I see that they support nrf52833_xxAA. I will try this now, thank you!! First place
  • Hi ! I have some updates and a question about my progress.
    I installed  SDK Mesh 4.2.0 and SDK 17.0.2, so that I can run the nRF52833 example.
    Unfortunately I get this error and it happens for all projects in my newer Mesh folder.
    Do you have any idea why this happens? It's an unmodified version, downloaded from the official website.
    As a note, I have included the correct path from Options - Building - global macros. Slight smile
    Thank you in advance!
  • Hi Marry,
    The examples in nRF5 SDK for Mesh v4.2.0 are built for nRF5 SDK v16.0.0, so I can't guarantee that they'll work with v17.0.2. When I tested the coexistence example I used SDK Mesh v4.2.0 and SDK v16.0.0, and it worked, so switching to 16.0.0 might fix your problem.
    If you want to use v17.0.2 you should look at the release notes for v17.0.2 as well as the migration guide in order to figure out what was changed between the two releases. Someone had a similar problem when trying to build an example built for v17.0.0 with v17.0.2, so you could try out the solution by Simon to that problem, which can be found here.
    Marte
  • Hello! And thank you very much for the quick reply!
    I tried with SDK16 and I have the same error unfortunately - and it persits for every project in the Mesh folder. Very strange.
    I have the same set-up as you. I wonder if I missed other setting from SES. But from my perspective, it should be fine.
