After some weeks of inactivity and moving my desk to an other address, the nRF connect application is not running and show a white screen for all applications except for Toolchain Manager ?
What's the problem ?
Hi Simon,
I have for the second time uninstall nrfconnect 3.6 for desktop, jlink drivers and install again this version but I obtain the same result a white screen !
I have also try to uninstall the 3.6.0 version, Jlink drivers and install the nrfconnect 3.2.0 version ( the one I had before moving the PC and It's always white screen.
In the mean time I've install nrfconnect 3.6 for desktop and the jlink driver on an other PC and it work, so for now I can work.
But I already need to work from my own pc, so what can be the problem?
Best regards
Jiemde
I'll forward your feedback to the developer, and get back to you when if I get any insight on the problem.
Simon
I got some more insight into this. I will try to convey what the developer told me.
The whitescreen is most likely related to jlink, since Toolchain Manager does not have that problem which doesn't use device selector menu.
To downgrade jlink requires change in the registry, and it does not seem like you did that, but when you upgrade it, this is not necessary. What version of jlink are you using? The newest one? Make sure you install the newest one, or the one that comes with the nRF Connect for Desktop app.
To use an older version of nRF Connect for Desktop is not that easy, since you will get the last version of all the apps, which are not compatible.
Some other causes to this may be:
Also could you provide me the "system report" from nRF Connect for Desktop?
Simon
Hi Nordics, I'm also having the same problem, did anyone of you find the solution? thanks in advanced !!
