After some weeks of inactivity and moving my desk to an other address, the nRF connect application is not running and show a white screen for all applications except for Toolchain Manager ?
What's the problem ?
Hi Simon, It's because I just try what I use before.
To be more precise I use "Power Profiler" and "Programer" and they screen are white.
So you say that the solution is to use the "Getting Started Assistant" ?
Is there a tutorial for that?
Best regards
Jiemde
Jean-marie said:So you say that the solution is to use the "Getting Started Assistant" ?
No, you should not use the "Getting Started Assistant" since it's deprecated. Use instead the Toolchain Manager (recommended) or install it manually.
Jean-marie said:I have about 300 units of nRF52832 to flash but I cannot !!
Is it possible to have support for resolving that ?
I would really like to get to the bottom of this. In this ticket, it seems like the customer was able to resolve this by downgrading to JLink 6.54c, could you try the same?
Regarding flashing the units. This can be achieved by installing the nRF Command Line Tools and using the nrfjprog executable (nrfjprog --program <name>.hex --sectorerase). You will find the hex file in <application>/build/zephyr/merged.hex (if multiple/child images) or <application>/build/zephyr/zephyr.hex (if single image)
Best regard,
Simon
Hi Simon,
I have downgrading to JLink 6.54c but nothing change !
Is it also possible to downgrade the nRF Connect 3.6.0 to 3.2.0 ?
I don't understand why I had using the nRF Connect software at the beginning of september without problem and now, after moving the pc, it refuse to work ?
Hope you have a solution.
best regards, Jiemde
I will talk to some of the developers of the nRF Connect for Desktop app tomorrow and ask what may be the reason for the white screen.
Simon
I talked to one of the developers and got a suggestion: "try to uninstall nrfconnect for desktop, jlink drivers and install the latest 3.6.0 again"
Simon
