Secure Bootloader does not start application
Hello community!
I have curious problems with the bootloading process in SDK 17.0.2. What I am trying to do is the following:
1. Create a bootloader settings page with nrfutil 6.1.0:
nrfutil settings generate --family NRF52840 --application APP.hex --application-version 0 --bootloader-version 0 --bl-settings-version 2 BLS.hex
2. Merge the secure bootloader (UART DFU version), the settings page, the application (ble_app_blinky) and the softdevice (s140 version 7.2.0) together:
mergehex --merge BL.hex BLS.hex SD.hex --output BL_BLS_SD.hex
mergehex --merge BL_BLS_SD.hex APP.hex --output Production.hex
3. Erase flash and program the nrf52840 with the merged hex file:
nrfjprog --family nrf52 --recover
nrfjprog --reset --program Production.hex
4. Restart the board.
My expectation: After the restart, the application should start running.
What happens:  The bootloader gets stuck in DFU mode.
At the same time, I also check the memory layout with the desktop application nRF Connect - Programmer. It shows the following weird image:
Flash programmed with merged hex files I read the following values when I hover over the different sections (from bottom to top):
1. Region name: MBR or Application / Address range: 0x00000000 - 0x00000AFF / Size: 2816 bytes
2. Region name: Application / Address range: 0x00000FF8 - 0x0002663F / Size: 153160 bytes
3. Region name: Application / Address range: 0x00027000 - 0x0002CB27 / Size: 23336 bytes
4. Region name: Bootloader / Address range: 0x000F8000 - 0x000FD83F / Size: 22592 bytes
5. Region name: MBR Parameters / Address range: 0x000FE000 - 0x000FE32F / Size: 816 bytes
6. Address range: 0x000FF000 - 0x000FF32F / Size: 816 bytes
Out of curiosity, I decide to test the DFU process to see what happens. I proceed to send the DFU zip file via UART:
nrfutil pkg generate --hw-version 52 --sd-req 0x0100 --application-version 0 --application APP.hex --key-file private_key.pem app_dfu_package.zip
nrfutil dfu serial -pkg app_dfu_package.zip -p COM5 -b 115200
It works fine and the application starts running. But, when I check the memory layout again, this is the ugliness that greets me (bottom to top):
Flash after a DFU process1. Region name: MBR or Application / Address range: 0x00000000 - 0x00000AFF / Size: 2816 bytes
3. Region name: Application / Address range: 0x00027000 - 0x0002CB1F / Size: 23328 bytes
4. Region name: Application / Address range: 0x0002D000 - 0x00032B1F / Size: 23328 bytes
5. Region name: Bootloader / Address range: 0x000F8000 - 0x000FD83F / Size: 22592 bytes
6. Region name: MBR Parameters / Address range: 0x000FE000 - 0x000FE05B / Size: 92 bytes
7. Address range: 0x000FE25C - 0x000FE32F / Size: 212 bytes
8. Address range: 0x000FF000 - 0x000FF05B / Size: 92 bytes
9. Address range: 0x000FF25C - 0x000FF32F / Size: 212 bytes
I have to add to the story that I have successfully implemented a similar bootloading process before, but that time I was using SDK 15.0.0 (now 17.0.2), secure bootloader with BLE DFU (now UART DFU), and probably an older version of the nRF Command Line Tools.
Please help me find what the problem is!
  • Sorry, I have to clarify my last sentence about successfully implementing a similar bootloading process before. It was the UART bootloader indeed that I used (in SDK 15.0.0), not the BLE bootloader.
    It looks like your setup should work. Perhaps you have a too old version of nrfutil? Since it was working in SDK15.0.0. Does your nrfutil output this warning when you generate the settings?
    Note: Generating a DFU settings page with backup page included.
    This is only required for bootloaders from nRF5 SDK 15.1 and newer.
    If you want to skip backup page generation, use --no-backup option.
    If not, try to update to nrfutil v6.1.0. You can find the executable here: https://github.com/NordicSemiconductor/pc-nrfutil/releases
    or you can use python pip:
    pip install nrfutil
    Let me know if upgrading nrfutil doesn't work, and we will look deeper into this.
    Edvin
  • Hi, thanks for your fast reply! My wording might have been confusing, but if you look at the second sentence in my post, it says:
    I mean, it was a previously developed product that I used SDK 15 and an older version of nrfutil. And, in that product, everything worked just fine.
    Anyway, I have just found another clue! I get the following message in the desktop nRF Connect v3.6.1 - Programmer:
     Error, Overlapping data
    I get this message when I try to program the merged Production.hex file by clicking the menu option "Add HEX file", then choosing Production.hex. It fails to open the hex file. However, if I choose the four hex files separately, in that case I do not get any error messages, but the flash looks the same erroneous after programming it with the option "Erase & write".
     Yes. Sorry. I missed that part when I started looking for possible issues.
     So before you upload the merged .hex file into nRF Connect for Desktop -> Programmer, is the window to the right completely empty before you do this?
    If not, try to click the "-" signs that appear when you hover your mouse over the regions in the right hand window before you drag and drop your merged .hex file into the programmer app:
    Edvin
  • Yes, the right hand window is empty in the beginning. Here is how it looks in full window:
    Overlapping data error
    Notice the red text at the bottom of the window.
    Below is a full window image about how it looks when I choose the files separately:
    Without error overlapping data
    Even though this setup does not trigger an error message, I do not believe this is how it should look. There are three black sections on the image although there should only be two: one for the MBR parameters page and one for the bootloader settings page. I don't know where the extra section comes from...
