Followed steps in stated in read me still unable to compile thingy 52 sdk
I am sorry for the delay.
You may need to rerun the install script after the folder name has been changed, in order for everything to be correctly set up and mapped. Did you do that?
Terje
Have a nice day!!!
Rerun the setup_sdk.bat and after that again rerun make - j in armgcc, still got following error. Please find below cmd prompt log:
Microsoft Windows [Version 10.0.18363.1316]
(c) 2019 Microsoft Corporation. All rights reserved.
C:\Users\SMET>cd..
C:\Users>d:
D:\>cd D:\Megha\Megha_Embedded_System\thingysdkv210\project\pca20020_s132\armgcc
D:\Megha\Megha_Embedded_System\thingysdkv210\project\pca20020_s132\armgcc>make -j
rm -rf _build
process_begin: CreateProcess(NULL, rm -rf _build, ...) failed.
Compiling file: main.c
Compiling file: m_ble.c
Compiling file: m_ble_flash.c
Compiling file: advertiser_beacon_timeslot.c
Compiling file: twi_manager.c
Compiling file: support_func.c
Compiling file: m_environment_flash.c
Compiling file: m_environment.c
Compiling file: m_sound.c
Compiling file: m_motion_flash.c
Compiling file: m_motion.c
Compiling file: m_ui.c
Compiling file: m_ui_flash.c
Compiling file: m_batt_meas.c
Compiling file: drv_gas_sensor.c
Compiling file: drv_ccs811.c
Compiling file: drv_pressure.c
Compiling file: drv_lps22hb.c
Compiling file: drv_humidity.c
Compiling file: drv_hts221.c
Compiling file: drv_ext_light.c
Compiling file: drv_ext_gpio.c
Compiling file: drv_nfc.c
Compiling file: sx150x_led_drv_calc.c
Compiling file: drv_sx1509.c
Compiling file: drv_bh1745.c
Compiling file: drv_color.c
Compiling file: drv_speaker.c
Compiling file: drv_mpu9250.c
Compiling file: drv_motion.c
Compiling file: drv_acc_lis3dh.c
Compiling file: drv_mic.c
Compiling file: inv_mpu.c
Compiling file: inv_mpu_dmp_motion_driver.c
Compiling file: data_builder.c
Compiling file: hal_outputs.c
Compiling file: message_layer.c
Compiling file: ml_math_func.c
Compiling file: mlmath.c
Compiling file: mpl.c
Compiling file: results_holder.c
Compiling file: start_manager.c
Compiling file: storage_manager.c
Compiling file: eMPL_outputs.c
Compiling file: log_nrf52.c
Compiling file: dvi_adpcm.c
Compiling file: drv_audio_coder_adpcm.c
Compiling file: drv_audio_coder_bv32fp.c
Compiling file: drv_audio_dsp.c
Compiling file: drv_audio_pdm.c
Compiling file: ble_advdata.c
Compiling file: ble_advertising.c
Compiling file: ble_conn_params.c
Compiling file: ble_srv_common.c
Compiling file: ble_conn_state.c
Compiling file: ble_tes.c
Compiling file: ble_tcs.c
Compiling file: ble_uis.c
Compiling file: ble_tms.c
Compiling file: ble_tss.c
Compiling file: nrf_drv_common.c
Compiling file: nrf_drv_gpiote.c
Compiling file: nrf_drv_twi.c
make (e=2): The system cannot find the file specified.
make: *** [clean] Error 2
make: *** Waiting for unfinished jobs....
Please suggest further solution.Thanks in advance for your valuable assistance.
Megha Choudhari
I have tried make -j two three times. Please find below log:
rm -rf _build
Compiling file: nrf_drv_pwm.c
Compiling file: nrf_drv_pdm.c
Compiling file: nrf_drv_clock.c
Compiling file: nrf_drv_saadc.c
Compiling file: nrf_saadc.c
Compiling file: nfc_launchapp_msg.c
Compiling file: nrf_drv_rng.c
Compiling file: nfc_launchapp_rec.c
Compiling file: nfc_uri_msg.c
Compiling file: nfc_uri_rec.c
Compiling file: nfc_ndef_msg.c
Compiling file: nfc_ndef_record.c
Compiling file: nfc_text_rec.c
Compiling file: app_button.c
Compiling file: hal_nfc_t2t.c
Compiling file: app_error.c
Compiling file: app_scheduler.c
Compiling file: app_timer.c
Compiling file: nrf_assert.c
Compiling file: retarget.c
Compiling file: led_softblink.c
Compiling file: low_power_pwm.c
Compiling file: fstorage.c
Compiling file: fds.c
Compiling file: app_util_platform.c
Compiling file: sdk_mapped_flags.c
Compiling file: nrf_queue.c
Compiling file: RTT_Syscalls_GCC.c
Compiling file: SEGGER_RTT.c
Compiling file: SEGGER_RTT_printf.c
Compiling file: softdevice_handler_appsh.c
Compiling file: softdevice_handler.c
Compiling file: system_nrf52.c
Compiling file: nrf_log_frontend.c
Compiling file: nrf_log_backend_serial.c
Compiling file: nrf_dfu_flash_buttonless.c
Compiling file: ble_dfu.c
Compiling file: ble_bas.c
Compiling file: nrf_dfu_settings.c
Compiling file: crc32.c
Compiling file: nrf_strerror.c
Assembly file: gcc_startup_nrf52.S
rm -rf _build
Linking target: nrf52832_xxaa_s132.out
make[1]: Entering directory `D:/Megha/Megha_Embedded_System/thingysdkv210/project/pca20020_s132/armgcc'
Preparing: nrf52832_xxaa_s132.bin
Preparing: nrf52832_xxaa_s132.hex
text data bss dec hex filename
186240 380 19780 206400 32640 _build/nrf52832_xxaa_s132.out
make[1]: Leaving directory `D:/Megha/Megha_Embedded_System/thingysdkv210/project/pca20020_s132/armgcc'
Is this means Thingy52 sdk compiled successfully? Kindly confirm.
Megha Choudhari
Please confirm also, If I dumped this hex file in nRF52832DK, can it work?
Because, I have dumped this hex through nRF Connect but not able scan in Thingy App.
Waiting for your suggestions earliest.
Megha Choudhari
I suspect the error message might be problems with running the rm command. What output do you get from the following command?
rm --version
The hex file is built for the Thingy:52, not for the nRF52832 DK. You should not expect the firmware to work on the DK. This is because buttons, LEDs and other peripherals are connected at different GPIO pins or not existing at all on the DK. Also, for instance clock sources may differ. In general, different boards require different configuration of the project. You should test the project on a Thingy:52.
Terje
