How do I get putty to receive output from the Thingy91? I see output in the LTE Link Monitor with the following prj.conf config:
What sample/application are you running on the nrf9160? I assume it's the default firmware and that there are some issues with the AT commands? If that's the case, take a look at this case: https://devzone.nordicsemi.com/f/nordic-q-a/57788/serial_lte_modem-sample-sending-at-commands-to-modem-using-putty-or-teraterm-does-not-work/234474#234474
I'll provide you with some generic guides as well, how to get respectively serial and RTT logging to work with the Thingy:91. The below steps assumes you have the possibility to program the Thingy:91.
To get serial logging to work with Thingy:91
To get RTT logging to work with Thingy:91
https://devzone.nordicsemi.com/f/nordic-q-a/61864/unable-to-use-rtt-in-nrf91
Simon
