Dear Members,
How can I define my solder mask properly ?
Is my solder mask definition correct ?
Please have a look on my screen shot, thanks
On the PCB
The design rules from datasheet,
PCB rules on my altium,
Thanks for your information.
Dear Members,
On the PCB
it is best to give the specs to manufacturer. They probably charge you 2$ for engineering fee but they will callibrate the mask for you.
Can I calibrate myself in Altium ? is solder mask at top solder (solder mask expansion ==>Specify expansion value?
Screen shot
Thanks
I can not see solder mask between pad, is that ok ? will it make a solder bridge? thanks
Hi, I think the rule you're looking for (corresponding to what is mentioned in the datasheet design rules) is solder mask expansion - set that to 0.1mm.
The rule in your screenshot - MinimumSolderMaskSliver - is determined by what your manufacturer is able to do. If they're not able to meet the mask expansion rule while also masking between the pads, then it's simply not possible to mask between the pads.
Not having a mask sliver between the pads could increase the risk of making a solder bridge, but it might also be fine. I've made a few boards without any mask at all, and if you don't use too much solder/paste it should stick nicely to each pad without shorting between them. But the manufacturer should be able to take a look at it and tell you if it's going to be fine or not.
