Programming custom NRF52832 board using SWD interface
Hello NRF,
I have a custom board with NRF52832, and exposed the SWDIO, SWDCLK, GND, VDD, RESET pins for programming the board through the NRF52-DK board.
I started with a sample peripheral_uart, connected the NRF52-DK board to my PC, and managed to BUILD and RUN the sample application.
I verified that the app is working, by connecting to the UART service advertised by this app (on NRF52-DK) through another device that has NRF-TOOLBOX and used the UART service to query the NRF UART (NRF52-DK board) and managed to read write and verified the same over the console.
Now, I want to program my custom board, instead of the NRF52-DK board. Based on some suggestions on this site, I connected the
NRF52-DK        CUSTOM_BOARD
SWDIO             SWDIO
SWDCLK          SWDCLK
GND-DET         GND
VTG                 VDD/3V3
I then powered my board and then tried the BUILD and RUN option on the SEGGER.
It seems like my custom board is not getting programmed.
I would like to know :
1. Do I have to first program a bootloader on to my custom board. If so, please advise a boot loader that I can download from your site (if possible) and the steps to program the same on to my custom board.
2. How to program the compiled/build binary/hex files on to my custom card? Just BUILD and RUN would download the binary on to the connected custom board, instead of the NRF52-DK board? (because my custom board is connected through the SWD port and GND detected?) If BUILD and RUN wouldn't work, where can I find the compiled binary or hex file where I can program the same on to the custom board , perhaps by using command line nrfjprog tool???
3. I believe the peripheral_uart has it's pin definitions, for the RX, TX, LEDs etc. Since my custom board pin assignments might be different from that of the NRF52-DK, where can I find these definitions, so I can go map the pins?
All I need is to demonstrate this peripheral_uart app on my custom nrf52832 board, where I will connect a serial port on to its RX/TX to a putty terminal (on my pc) and then able to rx/tx data back and forth with the other connected device (NRF toolbox -> UART).
I appreciate your help in this regard.
regards,
Dinesh.
  • Hello Simon,
    At the moment, I am using NRF5 SDK with NRF52832 device, and the uart_peripheral sample app.
    Please kindly advise, where I can find the LF clock definition in ,
    1. NRF5 SDK
    2. NRFConnect SDK (NCS)
    I shall try both the options, and make sure the hardware works fine. Then I can make a choice, based on the features available on each option.
    Thank you for your help.
    regards,
    Dinesh.
  • Hello Simon,
    I connected the NRF52-DK to the Sparkfun dev kit, as per your instructions. (My custom design is based on the Sparkfun dev kit design).  You can check their schematics here,
    sparkfun-nrf52832-breakout.sch
    Based on their schematics (which is what my current designs are based on), both the 32MHz and 32KHz crystals are connected.
    I am using nRF Connect v3.6.1 and nRF Connect SDK v1.4.2 and peripheral_uart project.
    Even with this Sparkfun development board, I am unable to get the peripheral_uart project up and running, whereas I have verified that the Sparkfun board is working through a different (Arduino) toolchain/IDE.
    Please advise, what could be the problem here. I see that both the crystals are connected. When I BUILD & RUN from the SES, there is no error thrown, and looks like the flashing goes smoothly.
    I believe, if I can get this dev kit to work with the SES + peripheral_uart project, then I can simply get my custom hardware to work with the SES + perhipheral_uart as well.
    Looking forward to hearing back from you soon.
    regards,
    Dinesh.
  • Hi
    1. In the nRF5 SDK you can edit the following defines in the project's sdk_config.h header file to these values to enable the RC oscillator and calibration.
    // <h> Clock - SoftDevice clock configuration
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    // <o> NRF_SDH_CLOCK_LF_ACCURACY  - External clock accuracy used in the LL to compute timing.
    // <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
    // <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
    // <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
    // <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
    // <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
    #ifndef NRF_SDH_CLOCK_LF_ACCURACY
    #define NRF_SDH_CLOCK_LF_ACCURACY 1
    2. In NCS, you need to go to the "Configure NCS project" option in the Project dropdown folder in SES and change the Clock control source to use the RC oscillator instead of external crystal.
    Please note that if you've followed the sparkfun schematics you should have this external crystal however, so this should not be the issue it seems. Are you able to run the example project on the nRF52 DK?
    Are you using the toolchain manager in nRFConnect to set up the nRFConnect SDK, or do you refer to the getting started guide? I would recommend using the toolchain manager for new users, as this is easier to get started with. When opening the SES IDE, how do you open the project. Please note that you should "Open nRFConnect SDK project" in "File" when opening new projects in NCS.
    Simon
  • Hello Simon,
    I managed to program the Sparkfun dev board and get it up and running.
    What I had to do was to select nrf52_sparkfun as the Board Name, instead of nrf52dk_nrf52832.
    nRF Connect -> Tool Chain Manager ->  nRF Connect SDK v1.4.2 -> Open IDE
    Then I use,
    File -> Open nRF Connect SDK project -> fade led (projects) , nrf52_Sparkfun (Board Name) , 1.4.2 (nRF Connect SDK Release), 1.4.2 (nRF connect Tool chain version)
    So, on the Sparkfun dev kit, nothing is connected, all GPIOs are open, only the rx/tx are connected to a serial2uart cable. Their definitions are, P0.27 -> TX and P0.26 -> RX
    I still don't understand, if the circuit is not connected to any other peripheral, what would be the different settings in terms of selecting the Board (nrf52DK vs nrf52_sparkfun) that makes the board work only when you select the nrf52_sparkfun?
    Next, I will try to program my custom board with nrf52_sparkfun as the Board selected. But this still puzzles me, what would prevent the app (uart_peripheral) work only with the nrf52_sparkfun Board selection, instead of the nrf52DK.
    regards,
    Dinesh.
  • Hi
     I think this is the reason, the Nordic Development Kits use P0.06 and P0.08 for UART by default for instance. It is generally important to select the correct board files for the board you're using. If your custom board is a replica of the Sparkfun board then selecting the sparkfun board should be fine, but we generally suggest creating board files for custom boards.
    Simon
