Debugging, NRF_LOG, Segger Embedded Studio Problems
I saw something in the list that might help but I have learned that if I go there I lose all the work I did to get here
I am having major problems with Segger Embedded Studio
  • NRF_LOG_x does not print either through the UART and putty OR RTT in SES [Manually set in the sdk_config.h file] since CMSIS Wizard is not present
  • The CMSIS Configuration Wizard is NOT present in my Tools.xml
  • Debug breakpoints are not hit unless it is in the main() part of main.c and when hit not in the code, only if a debug window to the left of the code
  • I can step line by line if I start and use F10/F11 from the start (do not use F5 and a break point) but never once I use F5 and a break point.
The only thing I can think of is that somehow the installation of SES got really corrupted or I am missing a major step. I have no idea how to fix.
Yet the code I have does partially run - it advertises, gets connected to, responds to service discovery, gets two characteristic descriptors enabled but then when I try and write from the client the write times out. I am not surprised that there are issues with the code as I have ported a SoftDevice only project from nRF51 and Keil.
But being unable to debug or even print to RTT (this is new for me) or via the UART and putty (the latter worked fine in the Keil project) is not helping.
Any help would be great. (Yes I have seen the debugging video and that's how I know my Tools.xml is corrupt).
  • Okay, I misunderstood then. But it's a step in the right direction at least.
    brianreinhold said:
    I turned off that auto CR thing in the FPRINTF
     I assume you're referring to the NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED define in your sdk_config.h file here, correct?
    Simon
  • Yes I meant I have  NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED 0.
    What I did validate is that in the existing hts example, with optimization 'none' I could not hit a break point in the event handler. With optimization '0' I could.
    I have tried lots of things - none  have worked
    Started with porting Keil project to Segger but there are confusions in the tutorial - it mixes nrf52 stuff with nrf51. Found a post on this site that clarified some of those problems and stated why the tutorial did not work. I have not yet gotten that to work. I find inconsistencies in the nrf51.c file, one has an include file that does not exist, the other doesn't have it. The two files are of very different size.
    Its been so frustrating I am tossing out everything, restarting with a copy of the ses hts example for SDK 17+ and converting over to my project step by step. It will probably take several days but if I had done that from the start, I would be well ahead of where I am now. Its been about two weeks.
  • Hi
    I understand your frustration, and I'm sorry you've had this much trouble with porting your project. I have reported a request to update this tutorial, but can't guarantee anything I'm afraid. Do you per chance have a link to the clarifying post? Thank you for your feedback!
    Simon
  • I do not have a link - but its on this site. Found it by doing google searches.
    I still have not been able to do a successful port. I have, however, been able to take my code directly and substitute it into an existing Segger example hts project after getting the logging parameter correct in the SDK_config.h file and the optimization parameters correct (not NONE). That is what I tried first and could not debug or print. After being able to debug and print it turned out that I did not manage to remove all the SDK components and some were getting run and competing with my own handling of events through the sd_ble_evt_get() function. The SDK was still running it's own handler. I still don't know how that was happening but I solved it by removing these two calls
    nrf_sdh_ble_enable(&ram_start);
    NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ...)
    and just calling
    nrf_sdh_enable_request();
    nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start);
    sd_ble_enable(&ram_start);
    in the ble_stack_init() function. I still have not cleared up everything in my mind (not sure what these 'observers' are and what the nrf_sdh_senable_request() does). Now that I have something working as in the Keil s130 nrf51 case on the nrf52840 I can systematically remove stuff I think I don't need and make sure it still works.
    Would still like to be able to do the port, though. Would be nice to have a 'free' Segger project for my nrf51 instead of using the size-limited version. Project still fits though.
  • I still can't get rid of the extra LF in my NRF_LOG statements (using putty via a UART). Latest SDK 17.0.2.
    I have the FPRINTF on in SDK_config.h (I think if I did not the build would fail - didn't need it in SDK 12.3.0 using Keil).
    I have
    • NRF_FPRINTF_ENABLED 1
    • NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED 0
    • NRF_LOG_BACKEND_UART_ENABLED 1
    • NRF_LOG_ENABLED 1
    When I copy the log output from putty to Notepad++ and display all characters I see two LF
    My actual log statements are the same as in the Keil 12.3.0 project and look like this:
    NRF_LOG_DEBUG("Main start GHS\r\n");
